Old 08-16-2004, 04:07 PM   #6871
King-G's Avatar
Send a message via ICQ to King-G
close ratter, what I am suggesting is using the kit supplied 2mm spacer plate, then using some washers like motor washers, or the Tamiya spacer set to raise the hingepin mounts a little further...but do it in small increments (.5mm is a substantial change in roll centre when adjusted from the lower arm rather than the camber links.
start with no shims under the front arm blocks....and 1mm under the rear arm blocks.
the camber links should start with the kit suggested upper inner front and upper middle rear positions.
King-G is offline   Reply With Quote
Old 08-16-2004, 04:45 PM   #6872
MI2
MI2's Avatar
Default mission sst
do you guys know how to stop the battery from falling out when racing in the mission sst
MI2 is offline   Reply With Quote
Old 08-16-2004, 05:49 PM   #6873
Send a message via AIM to Adam Hartzell
PW--After talking to Hector, he is my PRC team mate, he convinced me to get an mi2. I was just wondering where I can get one of thoes P Dub chassis for carpet.
Adam Hartzell is offline   Reply With Quote
Old 08-16-2004, 07:02 PM   #6874
PW
PW's Avatar
Send a message via AIM to PW
Adam....That's great to hear
The P-Dub chassis was put on hold do to a supply problem and just recently they have made progress in getting everything back up and rolling. They can be found at www.pdubracing.com
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-16-2004, 07:07 PM   #6875
Thanks, I'll try the kit chasis first but it may have more flex than I want.
Old 08-17-2004, 07:50 AM   #6876
Default A BIG THANKS
Just like too thank all the guies at schumacher, for all the help,and a special thanks to the man him self P (DIDDY) ,P DUB.I never seen such great support from any other company.You guies keep it up SCHUMACHER FO LIFE
layedbackpimp is offline   Reply With Quote
Old 08-17-2004, 04:20 PM   #6877
edseb's Avatar
Heh guys. Am in the process of getting a Mi2. I'll probably use it at SoCal in stock and 19t. Got a good set up for me to start? Thanks.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 08-17-2004, 04:41 PM   #6878
AdrianM's Avatar
eseb - Call Team Orion and ask for Pat McCarson He runs his Mi2 at SoCal all the time in Pro Mod and does really well.
Don Vinkemulder is another excellent local Schu Pilot. Donnie has been making the rounds at the local parking lot races and isn't at SoCal as often as he used to be.
Mark Franko is one of Donnie's buds and is also a very good driver.
Adrian Martinez
Old 08-17-2004, 04:45 PM   #6879
edseb's Avatar
I see Don V now and again. I don't know him personally, but his cars always look pretty dialed. Thanks.
Carl Hyndman
Old 08-17-2004, 05:44 PM   #6880
MI2
MI2's Avatar
i would like to know how to stop the battery from falling out in the mission sst could any one help me thanks
Old 08-17-2004, 05:45 PM   #6881
AdrianM's Avatar
Don V is one of the nicest guys you ever met. Next time you see him say hello. He will do his best to get you dialed in.
Adrian Martinez
Old 08-17-2004, 05:59 PM   #6882
AdrianM's Avatar
Mi2 - I have had it happen to me twice in 2 years with the Mission. Both times were during truly horrendous crashes. It is pretty much impossible on the Mi2 due to how deep the batts sit in the tray.
Try gluing a strip of carbon or fiberglass to the chassis on the outer edge of the chassis against the battery. You only need to make it as wide as the center 4 cells to keep them from popping out. I saw a guy that did this at the Nats in 2003 and it seem to stop the problem.
You can also remove the battery posts and cut slots so you can tape you cells in a'la Tamiya 415. Be sure to round the edges of the slots or the tape will get cut if you crash.
Of course the best solution is not to crash
Adrian Martinez
Old 08-17-2004, 06:03 PM   #6883
MI2
MI2's Avatar
thanks for the info but i'm not the best driver so i crash alot so i will try the two first suggestiont
Old 08-17-2004, 06:55 PM   #6884
coastaltony's Avatar
Default Re: A BIG THANKS
Originally posted by
layedbackpimp
I sat
down with you in your a/c'd pit
trailer, telling you to be
COOL.
You was cool! GOOD GOING
FURM!
Coastal Racing is on
it!
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 08-17-2004, 07:39 PM   #6885
STLNLST's Avatar
Trader Rating: 21 (100%+)
Are any of the guys using the Futaba 3pk? I'm thinking of trying out a whole new radio. Is the M-8 still the radio of choice?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
