Old 08-10-2004, 08:25 PM   #6826
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by AdrianM
Someone call me and let me in on it...lol!
I'll make that call in the morning....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-10-2004, 08:26 PM   #6827
STLNLST's Avatar
19 turn Saturday nationals at Speedworld this weekend.
Old 08-10-2004, 08:51 PM   #6828
Thank you.
Vector is offline   Reply With Quote
Old 08-10-2004, 09:05 PM   #6829
HarshGuy's Avatar
Originally posted by bigdog
Harshguy- you shut up to So the next time we are in the same heat is a two lap lead big enough for you to win a race or should I give you three!!
Three would be great! ...hey I'm working on some graphics for when you get your team website up, here's one concept:
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-10-2004, 11:03 PM   #6830
STLNLST's Avatar
LOL you are the man. I will bow down to the King of cyber laughter.
Old 08-12-2004, 09:13 AM   #6831
PW
PW's Avatar
Send a message via AIM to PW
New In Stock
U2782 Teemu Chassis
U2741 Alloy rear hubs
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-12-2004, 01:04 PM   #6832
Trader Rating: 28 (100%+)
For the guys who have the new alloy rear toe uprights,how do you get the different toe settings?I hear there is an insert in the block that changes the toe?Does it also matter by changing the inboard block to gain even more or less toe? And finally are the hub similar in geometry as the stock hubs? axle height etc?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 08-12-2004, 01:18 PM   #6833
AdrianM's Avatar
Schu USA will be closed Friday due to a hurricane coming through. Its not as bad is it sounds....
I just hope the rain is gone by Sunday so I can race...lol!
Adrian Martinez
Old 08-12-2004, 05:10 PM   #6834
King-G's Avatar
Send a message via ICQ to King-G
Racenut, the new alloy rear hubs have different geometry to the kit hubs, in that the distance between the lower hingepin and the axle is greater by 1.5mm. I was told this proved effective in allowing the car to rotate better.
also the ballstud heights are different to standard, also the fact that they are mounted vertically, allowing fine tuning of rear roll centre height.
the plastic inserts allow outboard toe adjustment in 1 degree increments..I am currently running the 0 degree insert, with 2 degree inboard (alloy mounts)...Next to try 1.5 degree inboard (kit mounts) with 1 degree hub inserts.
I've had the hubs on my car for around 3 weeks now, very pleased with their effect, both visually and on track!.
http://www.imagefile.net/MI2/toe_insert.jpg
King-G is offline   Reply With Quote
Old 08-12-2004, 06:12 PM   #6835
STLNLST's Avatar
racenut- if you aren't going to get the rear hubs before the next night race in Modesto (next weekend) Mo and i will be down there again and you can take a look at our cars. The car felt great with the spool set up I had on the car. The spool is easier to drive and is faster than the oneway. (I never thought I'd say that in this life time) We are going to have a blast next weekend if you show up this time....LOL
Old 08-12-2004, 09:51 PM   #6836
I have been waiting to try the spool setup again. Last time Modesto raced I was out of town.So Jaime and I are gonna come out next weekend. Is the turn-in the same as the oneway in your opinion? I have got my oneway car really good and very consistant.I can imagine the spool would be super consistant and easy to drive to boot.
King g- the aluminium inner hingepin mounts I noticed are not the same geometry as the plastic mounts.Can someone show or explain how these are to mount to the chassis so I get 2 degrees of rear toe?
Team I'm Over It
Old 08-12-2004, 11:14 PM   #6837
racenut- dont wait to put the setup on just do it. In modesto I ran the oneway car and the spool car back to back and the spool was faster weird but the car was hooked!
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 08-12-2004, 11:19 PM   #6838
STLNLST's Avatar
This is the way my rear end is set up right now and I really like it. The It's stable and has nice steering with a spool.
Old 08-12-2004, 11:25 PM   #6839
STLNLST's Avatar
The turn in is pretty good once you find a decent set up. Hopefully Wittman will be back out there. He really helped me get the car where it is right now. I got the car to rotate without having to add anti-squat in the rear. It's going to be fun nextweekend. Good luck and bring some ponies.
Old 08-13-2004, 06:21 PM   #6840
mo
mo's Avatar
I picked up one of the new Airtronics synthesized receivers and will be trying it out tomorrow, along with the new Keyence Rapida speedo. Here is a pic of the electronics layout on my car.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
