Old 08-08-2004, 02:24 PM   #6796
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Default tqs racing
the mi2 wins again at tqs hobbies coming form behind (next to last,got taking out)and winning. I was the only one with an mi2 with all x-rays,losi,tc3's in the A main expert stock. The car is working perfect. I used a diffrent set up then normal trying out a spool I am glad to be running this car mi2
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 08-08-2004, 02:42 PM   #6797
STLNLST's Avatar
Trader Rating: 21 (100%+)
Default Re: tqs racing
congrats on the win.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-09-2004, 02:16 AM   #6798
Can you please advise when / if the PW chassis and top deck will be released?
My friend received the new thick chassis and top deck for his xray, and it made a huge difference, car looked soo stable and was able to transition so fast. the flex in the MI2 is one of the things i would like to cure, the car always feel a little unstable under foot, this is racing single digit mods, on foams outdoor asphalt.
is the 2.5mm teemu chassis stiff enough
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-09-2004, 09:20 AM   #6799
Super Moderator
Tony Rivas's Avatar
Default Re: Re: tqs racing
thanks STLNLST
Old 08-09-2004, 09:31 AM   #6800
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
I was very impressed with the Mi2 at the Roar On Road Nats in Portland. Those cars rocked in all 3 classes!
My question is...my local track may be moving to carpet....how much time have you guys got on carpet with the Mi2? What are any equipment changes (chassis) need for carpet? Any info on that would be great.
Jeff
Jeff Werner is offline   Reply With Quote
Old 08-09-2004, 09:36 AM   #6801
Super Moderator
Trader Rating: 17 (100%+)
Foam tire outdoor setup is finally coming around. My car was silly hooked yesterday. Too bad I broke a front arm....oh wait make that FOUR front arms. I have to say that was the worst day of racing I have endured. My car was soooo good and I would just rub a pipe a little and rip off the front end. I will admit one of the arms was my fault, RCOldman was about 10 feet in front of me and hit a pipe and I remember thinking, OH MAN NOT HIM TOO and i parked my car right next to his. talk about a brain fart.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-09-2004, 11:00 AM   #6802
AdrianM's Avatar
We ran at the Snowbords and the Carpet Nats. We got the cars running pretty well but we do have a lot more time with the car on asphlat than on carpet.
That said we should not have any problems at all in getting the car hooked up on asphalt. If I were getting a car setup for carpet/foam I would get the following parts:
U2714 and U2715 Low Shock towers. There is no body height rule at most foam tracks so these let you slam the body so it looks right with 57mm trued foams.
U2744 Alloy gear adapter so you can run 64 pitch
U2765 and U2766 Carbon arms...stiffer is better on carpet.
U2696 MIP steel dogbones to upgrade the stock plastic drive shafts.
Remove you riser plates and cut the front one to make a strap to tie toget the tops of the front arm mount. This strengthens the front of the chassis in crashes.
You need to run orange/double pinks (Trinity Cyan) in front and double pinks (Trinity Magenta) in rear.
As far as special stuff for carpet thats it. Cartwright uses the stock chassis on carpet right now.
Adrian Martinez
Old 08-09-2004, 01:35 PM   #6803
mo
mo's Avatar
Hey Adrian, is Take Off still working on carpet foams or are they just sticking to the nitro car foams. The nitro foams have been working great for me on the R12.
Our carpet season doesn't start until October. I can't wait to see what the car can do.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-09-2004, 01:54 PM   #6804
AdrianM's Avatar
I haven't checked with them recently. I will shoot them an email about it.
Adrian Martinez
Old 08-09-2004, 02:02 PM   #6805
Trader Rating: 244 (99%+)
Well,
Thanks to all who helped out this weekend, Billy Spence - SMC, Angelo - Trinity, Kevin Boyle - ORL2 Assistant director, and any one else I missed.
The MI2 Was dialed! Was on a A Main run in stock when I broke the car. DOH! qualified 4th in the B. in the main got hit at the start and ended up dead last! worked my way through the field and showed them how it's done by lapping the field and winning the B.
In mod I qualified 4th as well and was running 2nd when I dumped. come to find out after the start I was hit and the belt came off the lower tentioner. It was rubbing the bearing which caused me to dump! Still finished 4th.
All in all not a bad weekend concidering my misfortune on friday morning. IF any one hasn't tryed T.M. Racing Foam tires TRY THEM!!! I used one set all day and they are still good enough to run another weekend!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 08-09-2004, 02:06 PM   #6806
Regional Moderator
kansasracer's Avatar
Adrian,
Do you have any more info on the carpet mod that you mentioned below? I am running on carpet and don't have any of the special stuff yet (Shane from Fastlane ordered it from you today) but didn't know about the riser plate mod....
Thanks!!
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 08-09-2004, 03:25 PM   #6807
AdrianM's Avatar
Its pretty simple. If you take the riser plate off and hit the front of the car on the track you will break your chassis. The forward front arm mounts will rip out of the chassis. To stop this from happening cut the riser plate into a strap to tie together the tops of the forward front arm mounts. Now it strengthens the chassis just like if it were mounted in the stock position but now you can lower you roll centers for carpet.
Adrian Martinez
Old 08-09-2004, 07:14 PM   #6808
will the new rear hubs be in this week?
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 08-09-2004, 09:22 PM   #6809
Regional Moderator
Adrian...thanks.
Old 08-09-2004, 11:22 PM   #6810
bigdog, i ordered a set today,,they are in now,,,
welcome back
rich
gdcopbadcop is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
