Old 07-26-2004, 08:29 AM   #6616
speedxl's Avatar
R/C Tech Charter Subscriber
cool beans! thanks Adrian!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 07-26-2004, 04:07 PM   #6617
AdrianM's Avatar
Default New Mi2 Parts
U2781 - Speed Secrets Shock Mount
U2782 - 2.5mm Carbon Fixed Battery Position Teemu Chassis
The Teemu Chassis puts the battery in the all the way back and all the way in battery position.
More details in the June newsletter:
http://www.racing-cars.com/images/pd...newsletter.pdf
Adrian Martinez
Old 07-26-2004, 04:31 PM   #6618
King-G's Avatar
Send a message via ICQ to King-G
Check out the new alloy rear hubs...we just recieved some of the first batch...
Purpleonium is so sweet! they have a vertical ball stud design, with 2 separate mounting positions (inner and outer), ballstud can be shimmed up to raise rear roll centre in small increments..
I quickly measured the geometry in comparison to the std rear hubs, the inner most hole, without spacers equals the std R/C Height...
the main difference in geometry is an increased distance between the axle and outer Lower Hingepin, so that the hingepin sits closer to the wheel (like another manufacturers design which many drivers have opted to use =)...
These new hubs allow the car to rotate quicker, without sacrificing rear end grip. so I have been told, I'm yet to test them ontrack for myself.
The trickest part of their design is the plastic Hingepin insert that allows toe angle to be changed outboard included are 0, 1 and 2 degree inserts.
horn.
Pics to follow
King-G is offline   Reply With Quote
Old 07-26-2004, 04:35 PM   #6619
King-G's Avatar
also the new T.L chassis is very nice...ultra stiff!...and very narrow~!..10mm less width than std, with cells moved back and all the way in towards the centreline of the chassis it has nice static balance, ..only 30 grams of weight was needed with my setup to get perfect pinpoint and tweakstation level.
The new chassis handled very nicely on track, very fluid no fuss transitioning, and held great cornerspeed due to less chassis flex over standard.
I felt it was easier to drive closer to the limit, more consistent and faster to boot.
I do miss the option of moving battery location, but so far so good.
Old 07-26-2004, 05:15 PM   #6620
what sort of after market parts is there for the Mi1?
NismosR34 is offline   Reply With Quote
Old 07-26-2004, 05:20 PM   #6621
King-G's Avatar
Tons of parts available for the Mission...alloy layshaft mounts, diff mounts, bulkheads, hubs, Ti this Ti that...you name it...
go to the online catalogue on the schumacher website.
http://www.secureonlineshopping.biz/schumacher/main.asp
Old 07-26-2004, 07:51 PM   #6622
AdrianM's Avatar
King-G - The URL you posted works fine but good ole www.racing-cars.com will take you to the same place.
If you are in the USA and what to got directly to the USA site you can type www.schumacherusa.net.
Adrian Martinez
Old 07-26-2004, 07:52 PM   #6623
AdrianM:
Does the Team run
exclusively or is there a condition when the stock setup is better?
My Mi2 is scheduled to arrive Wed after being backordered and I plan to run stock on asphalt until winter when I will go to the above setup for indoors but I was wondering when the stock setup may excel over the lower shocks and narrow chassis.
LeadFoot is offline   Reply With Quote
Old 07-26-2004, 08:08 PM   #6624
AdrianM's Avatar
The shock mount is new...we will use it as soon as we get them (2 weeks)
The Chassis is in use by almost all Euro Team members. At this time most US drivers prefer the Stock 2mm tray chassis in the Middle/Middle or 1 Step Forward/Middle positions. This is for High grip racing where most Euro racing is medium to low grip.
Also Teemu moves weight (to make the minimum 53oz) around on the car to get what he wants. Instead of moving the batts he will move his weight forwards or back to get more or less steering. Both are valid ways of achieving the same end.
At most club races no one weighs cars and everyone is under weight so I personally run an underweight car and move the batts.
Adrian Martinez
Old 07-26-2004, 11:19 PM   #6625
Originally posted by PW
hatebreed....The purpose of the lower towers is to allow for a lower mounted body for carpet racing with foam tires. We have found that the car works great with these towers on all surfaces so we run them all the time. The stock shocks have to be shorten 4mm to use the lower towers (2mm off ball-cup/2mm off shock shaft). The lower towers also make it easy to put tamiya shocks on the car
Paul,
So are the Tamiya shockes better on all surfaces then the kit ones? And which would you recommmend for running on the rug? Thanks and congrats.
Also which chassis would you recommend for carpet?
Brian
Brian Anthony is offline   Reply With Quote
Old 07-26-2004, 11:24 PM   #6626
i already have
alloy layshaft mounts, diff mounts, threaded shocks, etc
im talking about non schuey parts..
like 3rd party chassis etc,
i see there is a BMI chassis i think for the pro4, do they make one for the mission,
im not intending of buying one, just wanna know what other brands make stuff for Mi1
Old 07-26-2004, 11:40 PM   #6627
speedxl's Avatar
nismos they dont but look in the p-dub site they will hook you up.
http://www.pdubracing.com/home.htm
Old 07-26-2004, 11:42 PM   #6628
but thats for the mi2 yer..
or are the lower chassis the same or something?
Old 07-27-2004, 12:10 AM   #6629
speedxl's Avatar
nismos I am not sure but the new car is kick a$$ if you sell the one you have now get the Mi2 you be happy!
Old 07-27-2004, 12:13 AM   #6630
yeah maybe,
gunna spend a while this weekend maybe, see if i can stop the glitching,
gunna buy some good ds tape, some zip ties, and other bits and pieces,
also gunna buy a new motor, im starting to think maybe its my motor making it glitch??.....something about RF noise..?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
