Old 07-21-2004, 07:30 AM   #6556
ALLRIGHT!!
thanks speedxl, i did what you said, and no glitching now..
thanks mate..
NismosR34 is offline   Reply With Quote
Old 07-21-2004, 10:10 AM   #6557
speedxl's Avatar
R/C Tech Charter Subscriber
nismos did you do it all at once or just the cap trick!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 07-21-2004, 05:44 PM   #6558
i didnt do the caps
Old 07-21-2004, 07:41 PM   #6559
speedxl's Avatar
what fixed it i just like to keep notes so when someone else asks
Old 07-21-2004, 07:44 PM   #6560
i layed the RX down on the bottom deck with antenna going straight to the holder, so its not touching the chassis, i used 2 layers of tape, i put the esc on top deck, and i put some tape on the chassis near the end bell,
seems to be no glitching now..
Old 07-21-2004, 08:35 PM   #6561
speedxl's Avatar
would have rather esc on the chassis and reciver side ways. hey it works!
Old 07-21-2004, 11:16 PM   #6562
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Default setup
Guys,
I'm running on ashphalt, using either CS27's or sorex 32's.
Diffs at both ends,
sway bar at the front.
I can't for the life of me get enough rear end grip.
Turn in is great, high and low speed.
Rear grip is ok on high grip, but on switchbacks, or chicanes especially low speeds, the things wants to swap ends all the time....
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 07-21-2004, 11:21 PM   #6563
id say try a softer springs?
Old 07-21-2004, 11:22 PM   #6564
stulec52's Avatar
been through the range of springs.
Associated, and Tamiya, on TRF Blue shocks.
www.tamiyaclub.com/
Old 07-21-2004, 11:24 PM   #6565
maybe put the rear shocks on lowest shock hole?, so they look like this rear on,
Old 07-21-2004, 11:25 PM   #6566
stulec52's Avatar
yeah, I tried that too and that got me the closest so far.
Only thing is you get down to less than 5mm ride height if you go too far.
oh, and good pic by the way !!
www.tamiyaclub.com/
Old 07-21-2004, 11:29 PM   #6567
good pic??
oh you mean the /.......\ ??
below 5 mm when doing that?..i dont, i had mine right down, and with a medium spacer i was sitting at about 5.5mm at rear..
and 5m in front
Old 07-21-2004, 11:36 PM   #6568
speedxl's Avatar
stule how much caster and front toe do you have? How much rear toe?
Old 07-22-2004, 07:22 AM   #6569
PW
PW's Avatar
Send a message via AIM to PW
stulec52....It sounds like your front shocks may be layed in to much on the front end in relation to the rear shocks. Also check that you don't have to much drag brake due to running a stock motor or 19turn, if so then bump up your throttle trim slightly.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-22-2004, 07:23 AM   #6570
AdrianM's Avatar
Stule - Call Schu UK 1604 790 770. Ask to speak with Chris Ashton. He will get you sorted out with the rear grip issue. It seems that the rear grip issues are purely a British Isles thing. Everywhere else on earth we are raising the rear roll center to get rid of rear grip and to get more rear rotation in corners.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jaw8850
SEO by vBSEO 3.5.0
