Schumacher Corner
#6541
my upgraded Mi1
carbon chassis
alloy diff mounts front and rear
alloy layshafts
one way diff
spur gear adaptor
threaded alloy shocks waiting to be built
carbon chassis
alloy layshafts
one way diff
spur gear adaptor
#6542
ahahhaa enough spare parts aye??
#6543
and more
#6545
lol
got 12 purple ones with my screws and stuff..
#6546
you got to spread them out indivually and neat. then take a picture of your screw with wheel nuts!
#6547
oh come on, i just packed them away
#6548
since i got the new chassis (carbon)
i get majout glitching when car is more than a meter away, and even when i hold the car and just full throttle it, the front wheels go from side to side...not just 1mm, but sometimes near full lock
i am running a 16t motor, futaba 330 esc
Hitec HS-311 standard servo, a hitec HP 2RNB i think it says...RX....
i never had the glitching problem before with the old S1 chassis...i have checked all the wires, screws blah blah, but nothen..
the RX is so big, i have had to move the small esc to the top deck for now..
any idea's
any idea's
#6550
nismos mount the reciver with the crystal outward and use 2 layers of double stick tape. also take the motor out and put a layer of double stick tape on the chasiss right where the endbell is.
By the way if you using surface mounted caps on the motor you will need to solder three caps this will solve the problem.
they have poor contacts and thus the glitching!
Also make sure your atenna is not touching the chassis.
#6552
Team Schmacher showing'em the back side !!! Way to go!!
#6553
selling off a heap of parts on ebay aat the moment
mission partshttp://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=34063&item=5910773 557&rd=1
