Old 07-09-2004, 06:38 AM   #6466
PW
PW's Avatar
Send a message via AIM to PW
Troy will be down in south FL for the State Race
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-09-2004, 07:11 AM   #6467
Originally posted by NismosR34
are the alloy layshaft mounts worth getting for the mission s1?
and also the alloy diff mounts?
I'd say yes for the layshaft mounts and no for the diff mounts.
Plastic layshaft mounts are likely to melt when the layshaft bearing seizes, that's the only reason I'd suggest them. Then again, it is probably cheaper to have a pair of plastic mounts in your pit box than buy the alloys...
Diff mounts - the alloy ones are heavier (over 5 gram per pair, IIRC) and the added stiffness, if any, isn't worth mentioning. If you don't have weight problems, have too much money and like the purple color, then by all means use them. I had pretty much all the alloy you could get for Mission and in the end used only the layshaft mounts.
olev is offline   Reply With Quote
Old 07-09-2004, 07:22 AM   #6468
AdrianM's Avatar
Either is good. I run the plastic 20T pulley because for the local Stock and 19T racing I do I feel the car is even more free spinning with it. PW and all the other team drivers run alloy becuase they run Mod all the time and the alloy pulley is tougher.
That said PW has run the stock plastic pulley in Mod but you have to keep an eye on it because it will wear faster than in Stock/19T racing.
Adrian Martinez
Old 07-09-2004, 05:07 PM   #6469
[quote I'd say yes for the layshaft mounts and no for the diff mounts.
Diff mounts - the alloy ones are heavier (over 5 gram per pair, IIRC) and the added stiffness, if any, isn't worth mentioning. If you don't have weight problems, have too much money and like the purple color, then by all means use them. I had pretty much all the alloy you could get for Mission and in the end used only the layshaft mounts.[/quote]
ok, there like $40AU for a pair, weight is not a issue...no serious racing down here in tasmania
all the alloy..nah, was just thinking layshafts mounts for added stiffness
what else is good to upgrade on a stock mission S1??
thakns
NismosR34 is offline   Reply With Quote
Old 07-09-2004, 07:50 PM   #6470
heavy's Avatar
Trader Rating: 20 (100%+)
Best upgrades for a stock mission would be
1. The grey belts
2. The RW diff pulleys - these make an incredible difference
3. Depending on how often you need to change ride height for different tracks setups etc then teh screw down shock bodies would be next on teh list.
4. I personally believe teh best remedy for siezed up layshaft bearings is a bit of a maintenance program - I have been racing Mission since they first appeared and have never had that problem,
5. The diff mounting bearings on teh other hand are a problem area and if you can afford it get some of the Tamiya or Yokomo blue sealed bearings - you wont be sorry.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 07-09-2004, 10:19 PM   #6471
yeah i heard the grey belts are good
i reckon ill get the grey belts, the layshaft mounts in alloy..mainly cause i run around a carpark, and i want the extra stiffness..plus they look cool..
what are RW pulleys??
are they the alloy ones??
also i read that the CF top deck will stiffen out the car...
is it worth paying like $70+ au for one??
Old 07-10-2004, 02:28 AM   #6472
heavy's Avatar
Don't worry about the extra stifness of teh top deck - are you running on foams or rubber tyres ?
The S1 is a great car in it's own right and in some conditions even better than the Carbon Pro,
The RW pulleys replace the front and rear diff pulleys. They are CNC machined delrin and much more precise than the moulded pulleys resulting in them being very slightly smaleer and better fitting teh belts. This makes the belts that much looser bot still not slipping of course. Also the delrin does not pick up crud like the standard pulleys do so less maintenance.
Old 07-10-2004, 03:40 AM   #6473
ahhhh ok
i think ill got the belts and pulleys as first upgrade then
thanks
Old 07-10-2004, 11:15 AM   #6474
Send a message via Yahoo to the shoe
Raced my mission with those and the alloy layshaft mounts That is all that is needed althought there is a roll center spacing kit that is nice to have.
Adran will the alloy layshaft pullys fit the MI@??
the shoe is offline   Reply With Quote
Old 07-10-2004, 03:55 PM   #6475
STLNLST's Avatar
Trader Rating: 19 (100%+)
I had a great day racing today. I tested with different bodies today and I'm right back where I belong.....running a Stratus. The car just feels a bit more planted to me with the stratus instead of the Mazda 6. It just fits my driving stlye better. I ran Mo's set up with a couple of changes. I am now ready to get that first win at my home track. The car is easy to drive and I can put it anywhere I want (except in the winner's circle at speedworld)
PW- Good luck to you guys next weekend at the nats. Have fun and I'll chat with you when you get back.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-10-2004, 04:58 PM   #6476
well my rear belt snapped...so this is the time to get the new grey belts i think...
Old 07-11-2004, 09:43 AM   #6477
STLNLST's Avatar
Mo won the gas sedan class last night at our yearly Revo race on his first time out with the R12.
Schumacher will be turning some heads in gas sedan at the up coming Paris race this year.
Old 07-11-2004, 10:39 AM   #6478
John_S's Avatar
i wudnt run a grey belt in modefied as i found otu today i delamenated it and it flipped over and jsut turned into a skipping rope pretty much also broke a wishbone and my steering arm and i was having interfeirence troubles all day which i narowwed down to a motor after trying 3
John_S is offline   Reply With Quote
Old 07-11-2004, 01:52 PM   #6479
coastaltony's Avatar
The new car held it's
own this weekend at the rain
shortened "state race" in Coral
Springs.
Keep it up!
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 07-11-2004, 06:51 PM   #6480
PW
PW's Avatar
WOW....Sounds like everyone had a great weekend!!!!
Paul Wynn
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
