Old 07-04-2004, 08:06 AM   #6421
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by markg
OK...stupid question time...what's a Pdub chassis? How does it differ from the stock one?? I've just finished building my new MI2 and hope to run it next weekend for some practice. I'm going to give the spool a try to see how she runs...
Thanks.
Mark
The P-dub chassis is a thicker (3mm) after market chassis offered for the car. It doesn't have the option of positioning the batteries like the stock chassis. I got to run this chassis at the reedy race and I loved it. It's a cool upgrade. I feel it will be killer on carpet with foams due to it's thickness. Good luck with the new car and go have some fun.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-04-2004, 09:42 AM   #6422
Trader Rating: 28 (100%+)
The P-dub chassis is awsome.I run mine on asphalt with the stock upper deck.With the p-dub upper deck it will be awsome for carpet.
The stock chassis works well too,just like the option to run a stiffer chassis.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 07-04-2004, 07:46 PM   #6423
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I am just wondering if I possibly have a problem with my Schumacher Mission S1, as I am getting some strange handling problems..
Initially, I bought the car in as-new condition but second hand and built by the previous owner. It had some minor problems when it was built, like the owner had rushed the build or something. I have fixed up these problems now anyway.
Now the handling of the car is all over the place, mainly it is very very taily and has massive snap oversteer.
I thought it was the surface I was racing on, but it was driveable at the start of the day, but by the end, it would spin out as I turned into any fast corners, slide was uncontrollable and sudden. Surface was a concrete tennis court, i was running yellow springs on the front and rear, no swaybars, with 24mm CS27's all round. Front was running std ball diff, no spool or one way. Diffs were a little crunchy..
The tires i was running were pretty well stuffed, so I endulged in a new set of CS22's, rebuilt the front and rear diffs, and headed back out to the track. This track is a faster track, with an older surface that usually provides plenty of grip for the other guys.
This was also very taily and spinning easier, with the same yellow springs front and rear. Remember, I had NEW CS22's front and rear.
Meet was rained out, so headed home.
Next day, swapped the front springs for harder Red springs, appeared to help the problem somewhat, but it would still suddenly spin, especially turning around a left hand turn. If i stayed into the power, it would spin into a donut, pivoting on the front left wheel asif that wheel was locked from turning. It would do this with the body shell on or off.
All the time i did not change the shock pistons or oil, i am not sure what either of these are setup with (oil weight, or piston holes).
Motor is a Peak Hellfire rebuildable 27t stock, nicd 1700's and gp 3300's (mmm, punchy). Problem was also occuring with previous motor, a tamiya super stock (23turn).
Weight balance could be the cause, it is probly mile out, but I dont see how that could cause it to be as far out as it is.
I will rebuild the shocks also, make sure they are configured all identically.
v0rtex is offline   Reply With Quote
Old 07-04-2004, 08:08 PM   #6424
move you shocks on the shock tower...
i had hardly any steering, and was told to move the fronts shocks to the outer hole..which caused a heap of oversteer...i have moved to the 4th hole out...and it turns fine now..
NismosR34 is offline   Reply With Quote
Old 07-04-2004, 08:16 PM   #6425
Cool, that makes sense. They are as upright as possible front and rear now (ie in the outer holes).
As an aside, would starting from the center hole be the best place to start or from the inner hole when tuning the car on race day?
Old 07-04-2004, 08:21 PM   #6426
Trader Rating: 244 (99%+)
Also play with the weight distribution. I.E. Moving the front arms all the way Forward and the rears all the way forward. a good start with the shock's is 40wt. 3hole piston and blue shuie springs. I used to run 6 deg castor and 2 in on the shocks front and rear.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 07-04-2004, 09:01 PM   #6427
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The car seems awefully stiff. Like RC Old man says, try a lighter spring, BTW, the reds are lighter then the Yellow,
I think from the top of my head...
Black = 6lbs
Grey = 10lbs
Blue = 15lbs
Red = 20lbs
Yellow = 25lbs ?
The best setups I ever drove with the old car were with blues or reds depending... Start with the blues all around, and go from there.
Also check your droop, my car liked little droop in the rear < off power
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 07-04-2004, 09:05 PM   #6428
Its possible the springs i have are not schumacher ones, the yellows were the softest springs I have, and some fluro green ones are rock hard. The reds were noticibly more firm than the yellow springs, both by squeezing them between fingers and in the car...
Old 07-04-2004, 10:33 PM   #6429
i got yellow ones, and they seem pretty hard, and i got some grey looking ones...
im using the grey ones all round,
Old 07-05-2004, 12:31 AM   #6430
oooo bugger
Old 07-05-2004, 12:50 AM   #6431
Ooops, bad luck dude.
Metro Hobbies in Melbourne have Schumacher parts in stock, I have bought from them in the past and been very impressed with thier service
Old 07-05-2004, 02:54 AM   #6432
yeah
getting some bits i need of a mate...so i should have it running soon...
Old 07-05-2004, 06:35 PM   #6433
Trader Rating: 74 (100%+)
Default spinning out
Votex,
if you are running the Mission, check the lower pivot ball for the culprit of your freaked handling. I have had them freak my day upside down. This is how I checked mine. use a 2.5mm driver, spin the lower ball and watch the hub, if it dances, its bent. CHances are they are bent... Schumacher has ti ones, and hardened ones call Paul @ Schumacher, he can help.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 07-06-2004, 07:43 AM   #6434
AdrianM's Avatar
Here's my new body painted by Lynn Munno...
Adrian Martinez
Old 07-06-2004, 10:28 AM   #6435
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
nice!
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
