Old 06-14-2004, 08:03 PM   #6316
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Originally posted by RC Old Man
Off topic question......
I keep seeing these big schotty diode's in heat shrink on every ones car who makes them?
Could be several things:
1. A schottky diode from novak, that is equal to the power of 5 regular diodes (the little round can ones)
2. An in-line wire harness thing made for the GT7 (not sure what is it, I run Ko stuff)
3. The KoPropo Hyper Booster, although, this will say Hyper Booster on one side of it.
=MisFitz= NuKe is offline   Reply With Quote
Old 06-15-2004, 07:41 AM   #6317
Send a message via ICQ to MattW
Adrian, You sure you don't mean that you shouldn't run Power caps with the Keyence?? Keyence supply you with a Diode in the box.
Novak Seem to need big Diodes, and supply one as a wiring harness and shrinkwraped with the latest Gt7's.
MattW is offline   Reply With Quote
Old 06-15-2004, 06:45 PM   #6318
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I have a question about the Schumacher Mission S1.
I just bought one second hand, built in as-new condition and have discovered it was built with a few problems...
I have fixed up most of the issues, but just discovered the belt going to the rear wheels is really, really tight. So tight there is only a few MM of movement in the belt, and I can see how it would effect the car by wasting energy.
I cannot see a tension adjuster for this belt, is there anything else i should look out for to rectify this problem? Or perhaps it is normal?
I will dismantle the rear end tonight and see if I can see anything that may be causing the problem..
Cheers
James
v0rtex is offline   Reply With Quote
Old 06-15-2004, 06:50 PM   #6319
Matt Howard's Avatar
Default Re: Check this out
. Some of the fast guys showed up. Most importantly Scooby Horton "The Fast Guy" LOL.
Scooby's fast? Next time you see him tell him that Matt Howard said he's slow
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-15-2004, 07:57 PM   #6320
Send a message via Yahoo to the shoe
james these cars come with a 20 tooth and a 17 tooth pulley to drive the rear belt and the layshaft mounts are turned around whene you change from one to another. So look at that to be a cause .
the shoe is offline   Reply With Quote
Old 06-16-2004, 04:08 AM   #6321
I don't think it's even possible to build the car with 20t pulley and layshaft mounts in 17t position... although I have to admit I never tried really hard
The rear belts on Mission just are tight, that's the way they come.
You can use RW diff pulley (machined pulley that Schumacher sells) to make it looser. Some people have used Xray rear belt. I personally feel that it isn't such a big issue at all, I couldn't see the difference on the track when I switched to RW pulleys, although the car became a lot more free when turned by hand.
olev is offline   Reply With Quote
Old 06-16-2004, 05:11 AM   #6322
OK, thanks guys.
Looks like it is all in the right place, and i think it may only be the rear diff is slightly too tight, plus as its almost new still has some bedding in to do I guess.
Cheers for the help, none the less
James
Old 06-16-2004, 06:56 AM   #6323
STLNLST's Avatar
Trader Rating: 19 (100%+)
We have the Speedworld cup this weekend and we have Schuie driver's in three classes so we'll see what happens.
Mo-Mod and 19turn
Maurer- 19 turn (i think)
Cop- 19 turn (I think)
Me-mod and stock.
It should be pretty fun. I'm going with Mo's basic oneway set up in stock and for Mod I'm going with the spool set up that we have been running.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-16-2004, 12:10 PM   #6324
Originally posted by AdrianM
Someone's been watching too many Hugh Grant movies...
LOL, belter.
RC-Drift.com is offline   Reply With Quote
Old 06-16-2004, 01:10 PM   #6325
Trader Rating: 240 (99%+)
Long time no see Matt!
I'll let him know!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 06-16-2004, 11:00 PM   #6326
I will be there clint.
Jay Dub is offline   Reply With Quote
Old 06-17-2004, 12:11 AM   #6327
AN
Adrian can you post or e-mail (arvidrc@hotmail.com) the PW base setup for asphalt tracks (rubber tiers)?
/AN
AN is offline   Reply With Quote
Old 06-17-2004, 02:02 AM   #6328
Hi
Does someone know whats wrong with the Schumacher site because I can't open it anymore.
EZ man is offline   Reply With Quote
Old 06-17-2004, 02:10 AM   #6329
pheyhoe's Avatar
R/C Tech Charter Subscriber
same here.....
just wont access it.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 06-17-2004, 06:27 AM   #6330
PW
PW's Avatar
Send a message via AIM to PW
Hey guys....Schumacher UK is in the process of changing there in-house network (new everything) as well as launching an "ALL NEW WEBSITE" on a new server.
It will be SOOOO much better and will be well worth the wait
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
