Old 06-14-2004, 01:50 PM   #6301
PW
PW's Avatar
Send a message via AIM to PW
Thats pretty funny!!
Oh yeah, I will head over on Friday sometime
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-14-2004, 02:03 PM   #6302
mo
mo's Avatar
Originally posted by PW
This is an English thread on an english site talking about an english company......What the heck is going on here
Well then Bob's your uncle. Don't throw a wobbly or you might spend a penny on yourself. Keep your pecker up!
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-14-2004, 02:30 PM   #6303
AdrianM's Avatar
Someone's been watching too many Hugh Grant movies...
Adrian Martinez
Old 06-14-2004, 02:51 PM   #6304
speedxl's Avatar
R/C Tech Charter Subscriber
PW
I guess I'll see you guys there I'll bring my mi2 let you look it over. Tim said he will let me use the carpet towers.
I drove his car and like it with the pdub equipment. not being used to his car i was able turn lap times 2 to 3 tenths faster than with my own mi2.
Car had more feed back and alot more consistan with the pdub chassis!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-14-2004, 02:53 PM   #6305
PW
PW's Avatar
Sounds good Hector
Paul Wynn
Old 06-14-2004, 03:16 PM   #6306
Regional Moderator
Racer_Chick's Avatar
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Hey Troy - Does that mean you found a new ride in the Taco Bell car? lol.
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline   Reply With Quote
Old 06-14-2004, 03:16 PM   #6307
AdrianM's Avatar
Ok...I'm as guilty as anyone but lets get back on track...
The new machined Mi2 pulleys are in and are very nice. They make the car obscenely free.
The guys at the Reedy Race figured out a few things....
1. The PW base setup works everywhere and is almost perfect or at least a really good starting point.
2. The lower camber link hole on the rear hub carrier is good when you need to get more rear rotation to get into and out of corners.
3. Don't get too crazy with the shock oil. Stay in the 35wt - 50wt range on asphalt.
4. Don't go too stiff on springs. 20lb to 15lb in front and 10-15 in the rear is a good range to stay in for asphalt.
5. Tamiya shocks with the 3 hole piston and Schu shocks with the 3 hole vari-piston and the same wt. oil run exactly the same on the track. The only difference is the Tam shocks are easier to build and bleed. That said we will have new shocks for the Mi2 and R12 by late summer. They will be a top cap, bladder design like the Tam shocks but with a few very significant improvements (less static friction, ball grippa lower cup, metal one piece top caps, Ti shafts with a new low friction coating, o-ring metal threaded preload adjuster and more...)
Adrian Martinez
Old 06-14-2004, 03:25 PM   #6308
Trader Rating: 244 (99%+)
Off topic question......
I keep seeing these big schotty diode's in heat shrink on every ones car who makes them?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 06-14-2004, 03:30 PM   #6309
AdrianM's Avatar
I think KO. Its always their drivers that seem to have them. Mo might know...they seem to be a west coast thing.
Note that you CANNOT run Schottky's on a Keyence. If you do you will blow high speed fets. The instructions tell you not to run them and they will void the warranty.
Adrian Martinez
Old 06-14-2004, 03:38 PM   #6310
speedxl's Avatar
adrian actually ko has a hyperfet thinga makigger they sell but the thing this guy is talking about novak is selling aswell you solder it to the speedo like a cap.
all it is, is a schotty diode rapped nicely. so like if you have a car like a 12 scale or limited room to install a diode on the motor you would use this.
Old 06-14-2004, 06:05 PM   #6311
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Adrian, those shocks sound awesome, you can already backorder me a set !!!!
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-14-2004, 06:13 PM   #6312
Default Check this out
Another practice run at Hobby town.
Started with a new setup for the MI2 and a Brand New R12Team. Some of the fast guys showed up. Most importantly Scooby Horton "The Fast Guy" LOL. This will be a good test for the new setup and new car!
19 turn open:
WOW what a difference. The new setup was great! Car turned in much better had more grip and carried better overall corner speed. Qualified 4th with 23 laps. Scooby ran a 25 on foams the other 2 in front of me ran 24's. I stayed true to my rubber tires. Finished the main in 4th not a bad day at all!
Mod Nitro:
Another WOW actually a HOLY [email protected]#$! This car is awesome. I ran Paul Winn's setup from the winternats with a few changes on Foam tires. First round I ran a 24! Scooby was scrambling!!! He also ran a 24. Second round I ran a 25! Scooby was worried now cause he still ran a 24. Third round I decided to sit out and watch Scooby, save my car for the main. He ran a 23. So I TQ'ed!!!! 10min main. I got a good start and was running second. The leader clipped a pipe and I drove right by, never looked back. I drove safe and not aggressive. I finished with 7 laps on the field!!!!!! After the race Scooby and I took a few more laps and this time I decided to POUR it ON!!!!! WOW! Needless to say he was impressed and so was I. Now this was with a $99 omega .12 motor running on YS 20/20 airplane fuel!!! New motor and some race fuel, this thing will be SMOKIN!!!!!!!!!!!
Thanks to all!
Fred Perkins
Old 06-14-2004, 06:28 PM   #6313
Regional Moderator
Fred - I'm pretty sure those are the ones from Novak that you have to run with the GT7. I'm not positive, though.
Old 06-14-2004, 06:39 PM   #6314
Thanks guys and girls!
Old 06-14-2004, 07:08 PM   #6315
STLNLST's Avatar
Trader Rating: 21 (100%+)
Are there any heat sinks for the Keyence around the office somewhere? I don't have one for the speedo you sent out the last time. We have the Speedworld cup coming up this weekend. Mo and I will keep you guys posted on how everyone is doing.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
