Old 06-08-2004, 12:27 AM   #6241
Originally posted by STLNLST
To everyone that thinks you have to have Tamiya Shocks on your car in order to go fast.....boy are you wrong. Mo had a box stock car with the exception of the newer lowered carpet towers (which you can buy right now) and his car was on rails. Tamiya shocks are just easy as heck to bleed. [/B]
What length's were the shocks overall front/rear.
adyb is offline   Reply With Quote
Old 06-08-2004, 12:39 AM   #6242
SpeedTech's Avatar
Hi Guys,
Just a quick note, we have titanium screw kits available for the Schumacher Mi2 now. Check it out in The Racer's Corner and click on the titanium screw kit menu.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-08-2004, 06:59 AM   #6243
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'll take the shocks off today and post the length of the front and rear for you when I get off of work.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-08-2004, 07:15 AM   #6244
Trader Rating: 58 (100%+)
Default parts
is there a website where you guys are ordering parts for the schue? thanks
gporta77 is offline   Reply With Quote
Old 06-08-2004, 07:36 AM   #6245
speedxl's Avatar
R/C Tech Charter Subscriber
Mo when they say to take the roll center plate and cut it down how because i tried fitting up on top of the supension blocks and there is no room to install a nut to hold it down.
Sorry to ask the question because I really havent seen pauls and troys car up close in detail!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-08-2004, 09:11 AM   #6246
Send a message via ICQ to MattW
If you have mid corner push it is worth lifting the rear inner hinge pin blocks. We have been running anywhere around 1.2mm higher. This "Frees up" the rear of teh car and so gives more mid corner steering.
MattW is offline   Reply With Quote
Old 06-08-2004, 09:40 AM   #6247
speedxl's Avatar
matt I'll try that next because I just took out the roll plates upfront and installed 1mm shimm upfront.
I am guessing you set up might be an in between which I will actually try this wednesday night;. but I am going to try my shim set up first.
Pluss I am waiting for the socalled carpet shock towers which have different camber link locations.
Old 06-08-2004, 09:55 AM   #6248
mo
mo's Avatar
adyb: I believe my shock are 63.5mm, front and rear.
speedxl: you just cut the front the the riser plat off so that it braces across the two front suspension mounts. Then just use a longer screw to go through it all and put a nut on.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-08-2004, 10:27 AM   #6249
speedxl's Avatar
Thanks i got hold of old man troy s. he explained to make a somewhat stut brace.
when i was doing it i didnt have enough space under the steering mchanisim so i was like wtf! but troy explained that only use the bolts and brace across the front two mount! thanks mo!
Old 06-08-2004, 10:30 AM   #6250
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Hector, if you gonna be down @ Coral Springs either Wed or Saturday, I can show you my car.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-08-2004, 10:42 AM   #6251
speedxl's Avatar
It would be nice if you came down on wednesday and run with me and furman. I know if I call mike dobbs he'll come down.
let me know if you are comming for sure !
Old 06-08-2004, 10:42 AM   #6252
Trader Rating: 28 (100%+)
Hey Mo,
Did you remove the riser plate from both the front and rear or just the front?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-08-2004, 12:17 PM   #6253
I have been running 3 washers under the rear blocks, and 2 washers under the front. So that woulld be a similar balence to what you have by removing and then shimming the front.
Old 06-08-2004, 12:34 PM   #6254
speedxl's Avatar
racenut the mod only involves the front.
matt thanks i know about this method even though i have done the on my demon. I run for warpspeed who also makes parts for the mi2 is making me 1mm roll plates and a thicker chassis.
once I get those I'll try and get you a pic so if your intrested!
Old 06-08-2004, 01:15 PM   #6255
mo
mo's Avatar
Originally posted by racenut123
Hey Mo,
Just the front riser is removed.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
