Old 06-06-2004, 11:42 PM   #6226
Schrijver99's Avatar
Default Re: shocks
Originally posted by gporta77
can someone give me the Tamiya Part # for the shocks u guys are running on the car?
This is what i have on my MI2
1x TRF Aluminium Fluorine Coated set of 4 nr 53571
2x TRF414 Ball Connector King Pin Set 50986
Schrijver99 is offline   Reply With Quote
Old 06-07-2004, 05:25 AM   #6227
HarshGuy's Avatar
Originally posted by =MisFitz= NuKe
So...who is running what at the upcoming on-raod Nationals???
Myself, I am thinking of either Mod or 19 Turn.
As far as I know me & Dal are flying up together, I believe Jim Rose is going up and James *might* go.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-07-2004, 08:33 AM   #6228
mo
mo's Avatar
Originally posted by P2
Mo,
What's the difference between Xenon grey and purple inserts. Which one has more air gap and when whould you choose one over the other.
Thanks,
Paul - that old dude
P2, the purple inserts are softer and thicker than the grey. I use the purple in Sorex 32 but I cut about 5mm out of the circumference to make them tight on the rim and give almost the same air gap as the greys. Grey is what I normally run in 36's all the time. Billy is out of them right now though and the Red inserts seem to be a good alternative. Matt H ran them this weekend and they worked well.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-07-2004, 08:40 AM   #6229
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Paul and I tried the black inserts in some older 36s, and they were freakin' stuck. Altough I noticed that the tires were overheating slightly by the end of each run (they should though, being softer and having that, what I think is a pretty good sized airgap).
=MisFitz= NuKe is offline   Reply With Quote
Old 06-07-2004, 10:31 AM   #6230
mo
mo's Avatar
If you want to see the setup that was on my car in stock this weekend you can go to www.gearchart.com or http://www.gearchart.com/setup/setup...ock%201way.pdf , to go directly to it.
It was a rent-a-ride this weekend. Two different people ran it during the races and both loved it. It was the first time either of them had driven the car and it qualified 3rd, about a second off tq and would have finished 1st or 2nd but the guy driving the main had a couple big crashes including one on the last lap, about 5 feet behind the leader and ended up 5th.
Old 06-07-2004, 10:54 AM   #6231
Trader Rating: 28 (100%+)
Thats great to hear Mo. I was wondering if you could convert that file into a jpg.I cant get my acrobat/pdf reader to work for the life of me. Clint said the car was really good this weekend. It's too bad Dujuan wont convert.Or will he?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-07-2004, 11:03 AM   #6232
I'm bored...
James Nguyen is offline   Reply With Quote
Old 06-07-2004, 11:04 AM   #6233
mo
mo's Avatar
edit: nevermind
Thanks James.
Old 06-07-2004, 11:10 AM   #6234
Thanks guys.
Mo,
Would the oil be similar in the TRF shocks?
Team I'm Over It
Old 06-07-2004, 11:12 AM   #6235
HarshGuy's Avatar
What's it doing? ...I had someone at the track tell me that they couldn't get the pdf's to work either ....can you give me some specifics so I can try and find out what's up?
Old 06-07-2004, 11:15 AM   #6236
I actually have it working now Harsh.Its my puter,not the site.
Team I'm Over It
Old 06-07-2004, 11:22 AM   #6237
mo
mo's Avatar
speedxl, your pm mailbox is full so I'll answer your question here.
The car is box stock, except for the carpet shock towers, 1way and gear adapter. It has the stock 2mm chassis. I have not run the p-dub chassis yet. The car had good steering everywhere.
racenut; I think the piston/oil combo should be really clost with the TRF shocks and 3 hole pistons.
Old 06-07-2004, 12:16 PM   #6238
speedxl's Avatar
R/C Tech Charter Subscriber
Thanks Mo I am just having that darn mid corner push and its peeing me off.
I have been running mod with it and it isnt from overdriving its like the cars legs are giving out in mid corner!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-07-2004, 01:14 PM   #6239
mo
mo's Avatar
You can try going to a softer front sway bar or a longer rear camber link. Both should help with mid corner steering.
Old 06-07-2004, 07:49 PM   #6240
STLNLST's Avatar
Trader Rating: 21 (100%+)
Thanks guys.
Mo,
I was running the Tamiya shocks with the same weight oil as Mo with the 3 hole pistons. The set up was slightly different but the lap times were pretty much the same as Mo's set up. I feel that Mo's set up will be the way to go since you can't get the parts that I was testing out on my car.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
