Old 06-05-2004, 08:53 PM   #6211
Trader Rating: 28 (100%+)
Hey Guys,
I just received my P-dub chassis and top deck(3mm) and was wondering if the guys running it are putting 1mm spacers to bring the roll centers{front and rear} back to stock.The stock chassis and riser plate are 4mm total.So the chassis and a 1mm spacer should get me back to where I started.Or have you been running with the new roll center change with the P-dub chassis?Btw,the chassis is very nice.The one I have is a prototype but should be pretty close to what the production chassis is.Stiff!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-05-2004, 11:50 PM   #6212
UCHEATULOSE's Avatar
GT racer superior hobbies in orlando florida ships every day and have a fully stocked hobby shop. robby is the on site hobby shop for the snowbirds every year. he has everything related to r/c and than some! give him a call..ask for robby,ken or mike bruce. they know the schumacher car inside and out!
http://www.superiorhobbies.com/
1-407-834-9299 open monday through saturday closed on sundays..
UCHEATULOSE is offline   Reply With Quote
Old 06-06-2004, 07:16 AM   #6213
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by racenut123
Hey Guys,
where were you yesterday? Mo and I had our oneway set up's dialed yesterday. We were trying two different set up's and they were both dialed. The P-dub chassis is stiff and nicely made. I ran one at the Reedy and liked it. See you in two weeks if you're racing the Speedworld Cup.
To everyone that thinks you have to have Tamiya Shocks on your car in order to go fast.....boy are you wrong. Mo had a box stock car with the exception of the newer lowered carpet towers (which you can buy right now) and his car was on rails. Tamiya shocks are just easy as heck to bleed.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-06-2004, 07:52 AM   #6214
Hey Clint!
What about now?Are you still running it? Yesterday, my ride to speedworld fell through.Could not convince him to go. I am making arrangements to go to the speedworld cup.
I need to know in all honesty how many sets of tires I will need for the whole weekend.You think one set a round/main to be truely competitive?or could I use them at least twice?I am talking about the Sorex 36r's.Could you kick down what setup you guys were running with the oneway? And did you like it over the spool setups?Jaime and I are gonna come out on the wendsday before speedworld cup to practice.
Team I'm Over It
Old 06-06-2004, 10:04 AM   #6215
Can't answer your question, but just to correct a misunderstanding that seems to be common - using 1 mm thicker chassis with 1 mm thinner risers does not result in stock roll centre, because the upper inner pivot points will be 1mm higher than stock. The only way to get stock roll centres is to run stock risers (and to be totally correct, 1mm lower ride height). Or make new shock towers with 1 mm lowered upper arm pivot points.
olev is offline   Reply With Quote
Old 06-06-2004, 03:00 PM   #6216
olev,
Thanks for clearing that up.I was practicing today and after cafefully examining the chassis,I figured out almost the same thing except for the ride height change with the thicker chassis.That helps a bunch!
Team I'm Over It
Old 06-06-2004, 04:07 PM   #6217
Trader Rating: 58 (100%+)
Default shocks
can someone give me the Tamiya Part # for the shocks u guys are running on the car?
gporta77 is offline   Reply With Quote
Old 06-06-2004, 05:49 PM   #6218
GT Racer's Avatar
Ok. Thanks a lot for the information!
GT Racer is offline   Reply With Quote
Old 06-06-2004, 06:11 PM   #6219
mo
mo's Avatar
Racenut, running stock or 19 turn, you should be just fine with 2 sets of 36's for the whole weekend.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-06-2004, 06:50 PM   #6220
STLNLST's Avatar
Hey Clint!
The sorex tires are not one run and done tire's. There will never be a time you would have to run a new set every round. I'm using two for stock and two for mod....if even that. I'll post the oneway set up on Javier's site after the game. I can't say if it's better than the spool because we ran these set up's in the stock class and I wouldn't attempt to run that class without a oneway. Tire wear is better without a spool. Between Mo and I we will get you dialed. What class are you running at the Speedworld Cup?
Old 06-06-2004, 07:01 PM   #6221
P2
P2's Avatar
Trader Rating: 15 (100%+)
Mo,
What's the difference between Xenon grey and purple inserts. Which one has more air gap and when whould you choose one over the other.
Thanks,
Paul - that old dude
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 06-06-2004, 07:18 PM   #6222
Thats a total relief! Thanks guys! Btw,I think I am running Stock or 19turn. How was the car in stock clint?I loved it when I ran it last.But its been awhilesince 19turn has taken off around here.
Team I'm Over It
Old 06-06-2004, 08:07 PM   #6223
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
So...who is running what at the upcoming on-raod Nationals???
Myself, I am thinking of either Mod or 19 Turn.
=MisFitz= NuKe is offline   Reply With Quote
Old 06-06-2004, 11:05 PM   #6224
STLNLST's Avatar
Mo and I decided to skip the nats and save a little money. Good luck to you at the nats.
Old 06-06-2004, 11:06 PM   #6225
STLNLST's Avatar
The car was dialed. Motor will be the biggest thing at the cup. All of the regulars seem to have their cars on rails.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
