Old 06-01-2004, 04:31 PM   #6181
AdrianM's Avatar
Troy has the low towers, TiR CVD's, and a TiR Screw kit...I think thats it.
Adrian Martinez
Old 06-01-2004, 05:40 PM   #6182
Mo- PM me your address so I can send your tire warmers back. I forgot again like an idiot. I'm going to try and go to the speedworld cup. I'm looking into it.
Fartwright is offline   Reply With Quote
Old 06-01-2004, 07:27 PM   #6183
Send a message via Yahoo to the shoe
Troy post your setups from Strickland so i can see how different mine is from yours. I need to change servos, i still can't keep it on center. found out the hard way NEVER fallow Sherif Mike too closely,right into a pipe. I even took the inside line stright into the pipe a foot away from the corner!
the shoe is offline   Reply With Quote
Old 06-02-2004, 01:15 AM   #6184
heavy's Avatar
Trader Rating: 20 (100%+)
Default Re: Ok so this is the Schumacher thread cool here's my question....
Originally posted by Mabuchi540
The MI2 is one of my choices for my first onroad car after a 12 year break from RC. Here in NZ I would be running it in 540 stock (Mabuchi or Johnson 540's only and 1500 unmatched pack is the rule).
I have no idea as a starting point for the spur and pinion combo needed so suggestions would be greatly appreciated. I hope it's not one of these cars that can reach the ratios you need but the motor plate doesn't allow it.
Oh and can the MI2 take standard spurs such as Associated and Duratrax as I have a bunch of those?
Buy the Schumacher 83t or 86t spur and you will get teh ratio you need for 540. Or buy the gear adaptor and you can use your Kimborough etc gears but you will want to be in the 84 kind of area
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 06-02-2004, 10:41 AM   #6185
speedxl's Avatar
R/C Tech Charter Subscriber
thanks for the help adrian!
you will be talking to me soon
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-02-2004, 12:52 PM   #6186
turbodog's Avatar
Thanks UCHEATULOSE, our cars were really good at Strickland. Ed's car was really close to mine except I'm running a 2.5 chassis and tamiya shocks. From running the schuie shocks and tamiya shocks back to back on asphault I really couldn't tell a difference. But the tamiya shocks are very easy to build right out of the package where the schuie shocks take a little more work to get them smooth. Look for a new schuie shock in the hopefully near future.
I'll get you a setup tomorrow shoe, one that doesn't include shadow driving.
Troy Schafer
turbodog is offline   Reply With Quote
Old 06-02-2004, 12:56 PM   #6187
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Troy, is the setup close to what you have been running ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-02-2004, 01:11 PM   #6188
speedxl's Avatar
tim come down this weekend or tonight and run with us we have been running mod. me and furman bowser and dobbs,we need some more cars to pass see ya.
By the way i am working on the shuey!
Old 06-02-2004, 01:49 PM   #6189
TimPotter's Avatar
Hector, my car is working pretty good. I cannot make it down there on wed nights. I may be able to come down on Sunday, but whenever I come down there you guys don't run mod( has been a while). And besides that, all that will happen is I will get hacked by You. j/k
Upgrade those drive axels, and put the steering limiters in... you will be good. BTW, what shock towers you running ? And get yourself one of those now famous PDub Bumpers
Old 06-02-2004, 05:52 PM   #6190
UCHEATULOSE's Avatar
NOT EVEN CLOSE ICE CREAM BOY!
full set of ceramic bearings, tamiya shocks,new chassis 2.5 mm and god knows what else! paul has officialy rubbed off on him,lol.
oh yeah adrian i forgot..i'm sending you 4 oval bodies for some paint work! lol
i'm not sure how to navigate the schuy web site but troy should post that as a basic outdoor set up..it looked so easy to drive fast..i figure if ed can go fast anyone can.. he he
UCHEATULOSE is offline   Reply With Quote
Old 06-03-2004, 03:03 AM   #6191
Crashmaster's Avatar
Sorry to be a pain guys, but I am setting up my mates mission for him. I was wondering if you could tell me where to find a general alround setup for his car, as I haven't got a clue where to look
Thanks for the help
Crashmaster
Crashmaster is offline   Reply With Quote
Old 06-03-2004, 07:19 AM   #6192
PW
PW's Avatar
Send a message via AIM to PW
Thanks for the help
Crashmaster
adrian@schumacherusa.net or paul@schumacherusa.net
Please give track details.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-03-2004, 07:28 AM   #6193
AdrianM's Avatar
UCHEAT - Sorry.... he didnt have any of that stuff last time I saw his car...i didn't know.
Adrian Martinez
Old 06-03-2004, 08:20 AM   #6194
turbodog's Avatar
Tim-yes same setup I've been running.
Spool/battery forward & in
Front
Stock sway bar
4* caster/1.3 camber/5mm ride height/2mm droop
lower wishbone middle
low shock towers
upper shock mount 2nd hole in / lower outer hole
linkage upper row third hole in
shocks 40wt-3 hole piston-AE blue spring-63mm length
removed front riser plate (add 1mm spacer when running 2mm chassis)
Rear
Stock rear sway bar
1mm anti squat/1.5* toe in/1* camber/5.5 ride height/3.5 droop
lower wishbone forward
low shock tower
upper shock mount 2nd hole in/ lower 2nd hole in
linkage upper row middle hole
shocks 40wt-3 hole-AE blue spring- 63.5mm length
Troy Schafer
Old 06-03-2004, 09:34 AM   #6195
mo
mo's Avatar
Thanks for the help
Crashmaster
There are some setups on www.gearchart.com and www.mo-net.ws .
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
