Old 05-24-2004, 07:08 AM   #6136
speedxl's Avatar
R/C Tech Charter Subscriber
pw whats up! You too adrian., and the scumacher crew.
Hey paul i ran the car set up to the assembly instructions and didnt like it.
2 laps all it took. I went ahead and tried pw settings with the schuey shocks 3 holes and 45wt oil. I also ran it with the stock blue springs. car felt like it had a little too much roll I think the associated springs will be the the ticket. the big thing I'll diffenatly need to do is the spool.
car needs it. ( when are you guys comming out with one)
PW also main question I have . Is the car supposed to make wierd noise under accelleration while turning in sweeper
seems like a squeeking /clicking noise i dont know if its the plastic axles. also I did glue a shim on the steering as i did on my demon it seemed to quite it down.
By the way the car is a blast with a 10t single
ran it on the lay out from the state race the car was very planted.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 05-24-2004, 04:55 PM   #6137
PW
PW's Avatar
Send a message via AIM to PW
Hey Hector....Welcome to Schumacher Corner!!!
Yes, the spool makes a big difference Unfortantely Schumacher doesn't make a purpose built spool. We are running the front diff minus the diff balls with header card glued to the rings. Look in the manual for spool assembly, but just add the header card to the rings and face them toward the pulley.
I must admit that the stock driveshafts wont cut it with a spool and recommend Schumacher MIP or Ti-Racing CVDs.
Welcome to MOD racing
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-24-2004, 06:11 PM   #6138
rcshark's Avatar
Send a message via Yahoo to rcshark
will the universal drives off my axis work on the mi2. or do i need to ordor them with the kit?
rcshark is offline   Reply With Quote
Old 05-24-2004, 06:21 PM   #6139
PW
PW's Avatar
rcshark....They will fit, but you will have to keep an eye on the universal hitting the inside of the steering block.
Paul Wynn
Old 05-24-2004, 06:25 PM   #6140
Originally posted by TimPotter
Ohh...
http://www.pdubracing.com/home.htm
Anyone know when the chassis will be released?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-24-2004, 06:27 PM   #6141
PW
PW's Avatar
The graphite is delayed until the second week of june Chassis kit/towers should be ready by June 15.
Paul Wynn
Old 05-24-2004, 06:42 PM   #6142
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
adrian- hey thanks for the set-up for tqs it really help thanks
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 05-25-2004, 09:28 AM   #6143
speedxl's Avatar
thanks paul!
but still the all important question about all the wierd squeaking noises sounds like i need to oil the cvd's.
hey guess you have someone new chasing after you
Old 05-25-2004, 12:26 PM   #6144
rcdougie's Avatar
Hector has a Schumacher????
rcdougie is offline   Reply With Quote
Old 05-25-2004, 12:51 PM   #6145
I got myself a Mi2 yesterday, have been running X Rays for the past 2 years.. the car looks really good, but i have some questions: the 2 pulleys that comes with the kit, 17 and 20, most people seems to run the 20t pulley, i`m going to run stock, on carpet (rubber tires) wouldnt the 17t pulley be the best thing? (more acceleration etc)
cant wait to try this baby on the track!
Hatebreed is offline   Reply With Quote
Old 05-25-2004, 01:17 PM   #6146
Trader Rating: 239 (99%+)
Stay with the 20 unless the track is VERY tight.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 05-25-2004, 02:00 PM   #6147
PW
PW's Avatar
Hatebreed....We have found that the 20pulley works best for most tracks, but if you only race one track all the time then you should try both and decide with is better for you and the track you race on.
rcdougie....Hector won the Mi2 in the Florida State Series raffel. Look out series racers
Hector....Not sure about that noise, my car doesn't do it
Paul Wynn
Old 05-25-2004, 02:16 PM   #6148
AdrianM's Avatar
Hector - You have a loose nut behind the wheel.
Adrian Martinez
Old 05-25-2004, 02:58 PM   #6149
lmunno's Avatar
Send a message via AIM to lmunno
And I just thought he had alot of loose screws!!!
lmunno is offline   Reply With Quote
Old 05-25-2004, 06:27 PM   #6150
PW
PW's Avatar
Well it's time for the Reedy Race!!!! I will be flying out tomorrow afternoon to meet up with the rest of the team. If I have access to a PC (hint to Schumacher...LOL) I will try and give updates, but if not I'm sure Adrian will keep things rolling here
Paul Wynn
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
