Old 05-20-2004, 05:51 PM   #6121
Trader Rating: 28 (100%+)
Thanks Paul,thats an excellent idea.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-20-2004, 05:58 PM   #6122
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Hey Paul, did you get my email, I have not seen a reply.
Also, I got the parts, those pinions looks NICE!
=MisFitz= NuKe is offline   Reply With Quote
Old 05-20-2004, 06:08 PM   #6123
PW
PW's Avatar
Send a message via AIM to PW
Mike...You got mail! The pinions have been really good
racenut123....If you use the alloy TakeOff shims it will make it easier to remove them once they are glued The plastic shims wont come off once they are glued I normally like the 1.5mm shim for most tracks.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-20-2004, 06:22 PM   #6124
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Just got my PDUB Bumper for my Mi2, good way to spend 10 bucks.... It's lighter, alittle wider and stiffer then the kinda squishy one that comes with the kit.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-20-2004, 06:23 PM   #6125
TimPotter's Avatar
Ohh...
http://www.pdubracing.com/home.htm
Old 05-22-2004, 08:53 AM   #6126
HarshGuy's Avatar
Selling a Schumacher Mi2 rolling chassis w/tons of parts, car is 1 month old, more information here: http://www.gearchart.com/scheuy
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-22-2004, 03:04 PM   #6127
Oh man, why are you leaving us???
Old 05-22-2004, 05:10 PM   #6128
STLNLST's Avatar
Trader Rating: 21 (100%+)
That's too bad.....
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-22-2004, 05:24 PM   #6129
coastaltony's Avatar
Can anyone here give me a Freq. setting tip for running a Monster Stock with a Zero Extreme 2002 ESC ?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 05-22-2004, 06:04 PM   #6130
HarshGuy's Avatar
Just can't get the car to work for me as well as the losi, might have to do with having the Losi for 2 years now ....but I've got such limitted time and with the Swr cup next month, ROAR nats in July and Losi Race in August I gotta go with what works best for me now. So I figure probably best to try and sell the Scheuy while it's still "new"
Old 05-22-2004, 09:42 PM   #6131
STLNLST's Avatar
you should be fine running the speedo at the P5 setting. The freq. on it is 1.5
Old 05-24-2004, 12:28 AM   #6132
I was extremely please with the car yesterday, i ended up running both arms in the rear position, with short and low camber links, the car was very locked in, too much in fact, i think with maybe a different body (Running Strat 2) and rear foams on front it will be awesome (currently running 35F and 37R)
Is there a toe-in block that will give less than 1.5 deg of rear toe? i think less toe would also be good.
Car is feeling better and better every meeting, i have been able to drop my PB by just over 5 seconds, but i think there is still a few seconds left in the car. i am comfortably in the top 10, but the leaders are about 7 seconds in front of me, with more low speed steering i think i will be right with them. Currently using 2 degree caster, i heard that the menace caster blocks give zero caster this will aid in low speed turn in right?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-24-2004, 04:43 AM   #6133
STLNLST
Thanks, P-5, 1.5 it is.
Old 05-24-2004, 06:37 AM   #6134
STLNLST's Avatar
STLNLST
No problem.
Old 05-24-2004, 07:06 AM   #6135
AdrianM's Avatar
Guys...if your car feels too stuck try the upper row of camber link holes. We have never come across a situation where we needed the lower row of holes on rubber out doors or on carpet with foams.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
