Old 05-18-2004, 05:08 AM   #6106
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally posted by mo
RC Old Man; the .8 shims were on top of the stock riser plate.
Besercoe: the most likely reason the bellcrank broke would be that the servo saver spring may be overtightened. Try backing it off a bit. I've never heard of one of those breaking.
Where are you trying to get traction? Off power, On power or all around?
thanks mo
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 05-19-2004, 03:14 PM   #6107
Trader Rating: 237 (99%+)
When you assemble the Tamyia shocks do you use the Tamyia parts or do you put schumacher ends on them? Also what are the yellow springs that come with the shocks? And what length do you make them?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 05-19-2004, 03:15 PM   #6108
Trader Rating: 28 (100%+)
Default cvd's
What are most of you running in the front for CVD's when you run a spool setup?Ti,steel,plastic?I have Ti in the front and there is alot of wear after 2 runs with a spool.these were test runs.No board slaps or anything.Any tips or suggestions?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-19-2004, 03:18 PM   #6109
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
which part is wearing??
I use Ti all the way around.
=MisFitz= NuKe is offline   Reply With Quote
Old 05-19-2004, 03:27 PM   #6110
mo
mo's Avatar
On the Tamiya shocks, I am using all Tamiya hardware. Not sure what the length is but it doesn't really matter as long as there long enough to set your droop to where you want it.
I am using Ti cvd's in the front and kit plastic in the rear. They are all holding up quite well.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-19-2004, 03:31 PM   #6111
AdrianM's Avatar
I run the Steel MIP CVD's...no visable wear.
PW runs the TiR ones, has no visable wear and he runs tons with the spool.
Adrian Martinez
Old 05-19-2004, 03:44 PM   #6112
Thanks MO!
on the cvd's I use TI and just change the blades. Although I think the diff slots have streched alittle but I have to measure them to be certain.
Old 05-19-2004, 04:03 PM   #6113
Its the bone where the pin goes through.I must be doing something wrong....The hole is enlarged
Adrian,what cvd's from mip are they?Are they specific for schumacher cars? Anyways I will have to order some new bones soon.Also are the narrow rear belts gonna be in soon?
Team I'm Over It
Old 05-19-2004, 04:37 PM   #6114
Send a message via ICQ to MattW
racenut, how long have you had the tir driveshafts?
The steel MIP shafts are available from Schumacher, with a Schumacher part number.
MattW is offline   Reply With Quote
Old 05-19-2004, 05:01 PM   #6115
racenut, in the hole there is a metal insert, if that fell out, then the pin is going to bounce around and wallow out that hole, happened to me in oklahoma this past weekend. on the TiR ones that is.
Old 05-19-2004, 06:15 PM   #6116
Thanks Mike.I noticed the insert just right now.I am gonna have to swap out my rear ti to the front and order some of the Mip Steel versions.
Team I'm Over It
Old 05-20-2004, 05:25 AM   #6117
The bushed Tir driveshafts should be fine in the front with a spool. My old set in my mission ran for ages with a spool and a one way, and the mission front suspecsion goemetry put massive stresses and loads on driveshafts. The Mi2 should be much easier on CVD's, so you should be ok. That said, if you are getting too much wear then yeah i guess you're going to have to change.
Old 05-20-2004, 08:00 AM   #6118
STLNLST's Avatar
Trader Rating: 17 (100%+)
I have been using steel fronts and the stock plastic in the rear since I got the car and it's been holding up well with the spool. I even ran the spool with plastic fronts and got away with it for a race or two before they broke. The steel should be just fine.
Good luck to every shuie driver going to the Reedy race next week. I'll see ya'll sometime next week.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-20-2004, 08:04 AM   #6119
I will order the Mips today.thanks guys! I was actually able to re-sleeve the bone with some small gauge metal tubing.We'll see how long it holds up.Looks bullit proof though.
Team I'm Over It
Old 05-20-2004, 06:42 PM   #6120
PW
PW's Avatar
Send a message via AIM to PW
I think it's important to use steering stops on your steering blocks. I glue a small 1mm, 1.5mm or 2mm shim onto the steering block depending on the track layout. This will help the car in the corners as well as help prolong the life of the CVDs
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
