Old 04-30-2004, 05:53 PM   #6031
Trader Rating: 28 (100%+)
Default Oneway setup
Front,
Trf Shock 3 hole piston 40 wt.
Ae blue spring
Carpet tower inner upper camber position
Outer shock tower hole/ outer arm hole.
63mm shock length
1 degree camber
4 degree Block carrier.
Arm mounted in back position
Droop 5mm
Middle holes on steering rack.
Oneway diff.
Stock swaybar
5mm ride height
Rear
Carpet tower
TRF shock 3 hole piston 40 wt.
63.5 mm shock length
2nd to outer hole on tower for shock/2nd hole from out on arm fro shock.
Upper middle for camber link on tower
Farthest hole out on rear upright.
1.5 degree toe.
4.5mm droop
Middle arm mounting.
5mm ride height
Sorry guys couldnt fill out the pdf sheet.Something is wrong with the puter.Harsh could you fill one out for me?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-01-2004, 04:37 PM   #6032
HarshGuy's Avatar
Mo, your car looked good, hook us up with the setup
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-01-2004, 06:59 PM   #6033
Man today was a good day for my Mi2.Car was very fast and although qualifying was a little rough,and the car the car was good enough to win,its was me who couldnt keep it together.Lead the A main for quite a bit and a mistake and a wrong choice in tires for the main would leave me a very close second.Oh well,I cant complain.I am actually really happy it was good.Will see how it does in Modesto tomorrow.
Team I'm Over It
Old 05-01-2004, 07:19 PM   #6034
STLNLST's Avatar
Trader Rating: 19 (100%+)
what about my car... These Quantum 2's suck. I saw four lrp's go to crap today with mine being one of them. I'm putting the keyence back in for next weekend. MI2 was rocking today. Next weekend should be great with everyone coming out.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-01-2004, 08:05 PM   #6035
Oasis's Avatar
Trader Rating: 36 (100%+)
And still no speedworld win..
Oasis is offline   Reply With Quote
Old 05-01-2004, 09:25 PM   #6036
STLNLST's Avatar
wins are over ratted..... I'm having fun and that's what counts.......right????? This was probably one of my best chances but things happen for a reason and I think that reason is for my win to come with all of the local bigshots at the track and my bay area hommies. So hopefully next weekend I can make this happen.
Racer X- Did any of those changes help the car out some? Rich had some killer motor in the main. See you next weekend.
Old 05-01-2004, 10:23 PM   #6037
HarshGuy's Avatar
Clint, your car looked good, hook us up with the setup
Old 05-02-2004, 12:42 AM   #6038
STLNLST's Avatar
It's on the gear chart page already.
Old 05-02-2004, 04:35 AM   #6039
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Has it been easy to get MI2 parts? My Pro 4 has been a total pain in the rear to get parts and I'm starting to get a little pissed about it. Next car I buy I want to get parts easily. I don't mind ordering them but it would be nice if they were in stock.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-02-2004, 06:08 AM   #6040
Oasis's Avatar
STLNLST if I did not think "it" was past due I would not rib you about it..
Old 05-02-2004, 08:54 AM   #6041
STLNLST's Avatar
wyd- parts are out there for the car as the car gets more and more popular. If ordering isn't a problem (if your LHS doesn't stock the car) you can order directly from Schumacher. The guys there are friendly and race the car as well so if you have a set up question when you place your order they can help you out. There is also a ton of set up help on this thread. Everyone is sharing set up advice so no matter what type of track you race on....there's a good basic set up on here for you to start with.
xxxkat- It's more than past due but if I keep trying it will happen sooner or later You're still coming up for the Speedworld cup right?
Old 05-02-2004, 07:03 PM   #6042
Trader Rating: 17 (100%+)
Racenut had MOTAH!!!! WOW! I saw him pull the 2nd place guy by 3 car lengths on the straight! HOLY COW!
Too bad the "Handle" went away at the end. How was round 2?
Art
Advil is offline   Reply With Quote
Old 05-02-2004, 07:25 PM   #6043
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
PW's car was absolutely AWESOME today. He had his main covered.... Teemu was fast too, car was a little loose in the last main, which BTW was pretty rough considering the players.
Thanks for the help Paul....
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-02-2004, 08:03 PM   #6044
Thanks Art!
The car was a pleasure to drive on Saturday,too bad it was to a second place finish when I should have handled buisness and won! Talk about choking.
Round 2 at Modesto Hobbies went well again.Didnt have the tire thing down in the first round.But in the second round I set new TQ by over a whole lap.Also set the fastest lap time in expert stock.Whose says shaft cars out accelerate belt cars!That was an intense battle between Jim Rose and I for about 4 minutes and I was still able to Tq.In the 3rd round I got taken out in the first lap which allowed Jim to set a new Tq by 3 tenths of second. Had to go home before the mains but all in all,for its first outing,the car was really good.Thanks Schumacher!
Team I'm Over It
Old 05-02-2004, 08:38 PM   #6045
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
**cough**cough**KO ALL THE WAY **cough**
=MisFitz= NuKe is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
