Old 04-28-2004, 08:03 AM   #6001
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Cole, I had my car for a couple months, Have run at least 40 packs through it.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-28-2004, 08:46 AM   #6002
mo
mo's Avatar
mattcaney, check out www.gearchart.com for some good setups.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-28-2004, 12:43 PM   #6003
Cole - if you want to keep some parts then front C-hubs, front lower arms and driveshafts (if you will be running plastic ones) are the things that will most likely break when scuffing the boards.
I have run 2 races with my MI2, ~20 packs with practice, no problems besides broken diff screw (probably my fault, I overtightened it while trying to get normal diff to act more like a spool) and one front driveshaft (when running an actual spool and hitting a wall _hard_). Shafts got replaced by metal ones after that. But I have seen others break the C-hubs and lower arms, so it can be done
C-hubs with different caster angle are nice to have anyway, as it is also a tuning aid. The stock 4 degree pieces will be available as alloy too, but I don't know if they are available yet.
olev is offline   Reply With Quote
Old 04-28-2004, 01:49 PM   #6004
Send a message via Yahoo to the shoe
matt we started a thread here called Mission I&II set-ups look there also.
the shoe is offline   Reply With Quote
Old 04-28-2004, 02:13 PM   #6005
forty6's Avatar
Originally posted by the shoe
matt we started a thread here called Mission I@II set-ups lokk there also.
Shouldn't it be Mission I & II?
Just messin' w/ ya.
forty6 is offline   Reply With Quote
Old 04-28-2004, 02:43 PM   #6006
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Originally posted by Cole Trickle
How is the MI2 durability wise? Is it needed to have spare parts in the pitbox? I dont need any for my HPI Pro2
Which do you think is the toughest, XRay Factory Edition or MI2?
And I DO know the story about dont touch the boards, but thing is, I do from time to time.
Cole, and just to add to what others have said, last weekend, I hit a chicane, where you are traveling VERY fast, same speed as on the straight, and it is going up a hill. (The plastic walls are held to the track with re-bar) I hit the wall, the wheel rode up the wall (running a spool) launched the car up, up and away. the car went about 8 feet in the air, landed on the front right corner, hard, and I mean HARD. Guess what I broke...the chassis. , now you want to talk about a strong car, and that was with the front raiser plate removed, and the chassis just split, didnt snap in two or anything, just the layers kind of split on that corner.
=MisFitz= NuKe is offline   Reply With Quote
Old 04-28-2004, 07:19 PM   #6007
rcdougie's Avatar
What does removing the front riser plate do?
rcdougie is offline   Reply With Quote
Old 04-28-2004, 07:32 PM   #6008
Trader Rating: 239 (99%+)
Lowers the roll center and decreases traction.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-28-2004, 10:44 PM   #6009
AdrianM's Avatar
I posted a while back that if you remove the riser plate you have to turn the front part of the front riser place into a strap that ties toghter the tops of the forward fron arm blocks. If not you will rip apart your chassis in a hard frontal hit.
I cut my front riser into a strap and 2 tabs that can be used in the stock location as a 3 piece riser of with the strap on top for carpet/foam racing.
Adrian Martinez
Old 04-29-2004, 03:35 AM   #6010
rcshark's Avatar
Send a message via Yahoo to rcshark
okay guys friday april 30 th is my birth day and it would be cool to have the car in the mail you still have time.
rcshark is offline   Reply With Quote
Old 04-29-2004, 11:47 AM   #6011
Trader Rating: 28 (100%+)
Default maiden voyage
Ran my MI2 for the first time today.Trying to see if I can get a feel.I say wow.
Car accelerates like a shaft car, carries a ton of corner speed and is quick in transition.Couldnt ask for more then that.Inspires confidence for sure.Cant wait for saturday now!Btw i know everyone is running spools but I put in the oneway and its dialed.Setup is very close.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-29-2004, 11:47 AM   #6012
Team I'm Over It
Old 04-29-2004, 12:00 PM   #6013
HarshGuy's Avatar
racenut, what setup did you use for the oneway? ..is it one of the schumacher ones here: http://www.gearchart.com or ..do you have it in a pdf file you can email me? javiera@arroyoc.com
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-29-2004, 12:19 PM   #6014
To be honest,its part Mo's spool setup and part Paul wynn's.I have made changes but for the tracks I run on it is good.Where can Ifill out a setup sheet to post?I will send one to you if you can point me in the right direction.
Team I'm Over It
Old 04-29-2004, 01:07 PM   #6015
HarshGuy's Avatar
Yea if you fill one out and email it to me I can post it up (and use it , get a blank one here:
http://www.gearchart.com/setup/setupfiles/mi2_blank.pdf
(gonna be adding blank sheets to gearchart.com listing soon, but for now...) I added the 3rd hole on front towers, did it "after the fact" so they don't look the same or line up exactly but at least we have a spot for them now
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
