Old 04-26-2004, 09:31 PM   #5986
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by racenut123
Thanks Clint.Yeah it was pretty bad saturday.You know I was just kidding with you on rcracing right?I know the drive down from Sac to the Bay area is brutal and to end up it not being what you expected is even worse.Cant wait to get on Billy's again.Maybe I can convince my buddy to give me a ride up there in his WRX STI.He says its usually about 1 hour and 15 minutes to get there instead of the 2 it usually takes me!Why cant that track be here?
edit
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-26-2004, 10:16 PM   #5987
Trader Rating: 28 (100%+)
any word on the P dub Chassis? Is it 3mm and does it still use some sort of riser plate for the suspension blocks? Thanks!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-27-2004, 05:40 AM   #5988
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
not sure when it will be handy, you can go to their website and check it out. It is 3mm, and yes they are taking the plates off.
=MisFitz= NuKe is offline   Reply With Quote
Old 04-27-2004, 02:26 PM   #5989
Location: Built By The Racers For The Racers. Corona CA
Default Don Vinkemulder wins with MI2!!!!
After four races with the same layout, over 510 entries, Schumacher Driver Don Vinkemulder was crowned the fastest on the track! Don ran the new Mission MI2 to victory! R/C Heat presented Don Vinkemulder a Silver Cup for 19T Spec and another for Modified Sedan. Way to go Don and Schumacher!
R/C HEAT is offline   Reply With Quote
Old 04-27-2004, 03:47 PM   #5990
32 rounds of qualifying???????? , did you multiply the 16 by two...anyways, that would make it two rounds of qualifying, with 16 heats. correct me if I am wrong, and there really were 32 rounds, that would suck, talk about battery kill, and motor cutting.
Old 04-27-2004, 04:01 PM   #5991
LOL, it was over a four month period, I guess I should have stated that.
I corrected the above post.....
Old 04-27-2004, 04:17 PM   #5992
What is P Dub, and where is the website it can be seen at?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-27-2004, 04:53 PM   #5993
http://www.pdubracing.com
go there, it is just a company started to make chassis components for the Mi2
Old 04-27-2004, 05:32 PM   #5994
mo
mo's Avatar
Default Setups
Now, not only will www.gearchart.com have the best gear ratio / rollout calculator, it will also have setups for many cars from factory drivers too. It was just started today so there aren't many setups posted yet but there will be many more to come.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-27-2004, 06:49 PM   #5995
Send a message via Yahoo to the shoe
I just finished a box to hold a power supply and power strip to keep clutter to a minium,and finished it off with a name plate with stickers sandwitched between to plates of plexiglass and only the Schumacher stickers color ran in the glue. I would have been sweet looking. Bad schuie bad!
the shoe is offline   Reply With Quote
Old 04-28-2004, 07:11 AM   #5996
AdrianM's Avatar
Way to go Don Vinkemulder for winning the R/C Heat Spec Mod and Mod Cups!
FYI, Mark Franko TQ'd and Won Stock at the Same Race with his Mi2!
Adrian Martinez
Old 04-28-2004, 07:22 AM   #5997
Cole Trickle's Avatar
How is the MI2 durability wise? Is it needed to have spare parts in the pitbox? I dont need any for my HPI Pro2
Which do you think is the toughest, XRay Factory Edition or MI2?
And I DO know the story about dont touch the boards, but thing is, I do from time to time.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-28-2004, 07:34 AM   #5998
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Cole, the only thing I have damaged on my car was and axel drive cup, and thats becuase I was running a spool. I have since switched to the ti dogbones and the car is as durable as any car I have had, if not moreso. I have had some pretty good hits, thought for sure the car was broken, and it came back in one piece. In comparison, the Xray I had, I broke a couple c hubs/ steering blocks with the same kind of impacts.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-28-2004, 07:48 AM   #5999
Tim, that's very interesting.
I havent tried a spool, but I believe that it's as hard as a one-way to the CVD's / outdrives.
Not that I'm getting a new car tomorrow, but at some point, I will. The XRay and the MI2 is the most interesting to me. Both are well supported and high quality and good adjustment options. And I want a belt car.
Best thing is, that the MI2 are cheaper than the XRay around here
For how long have you had your MI2? Have many times have it been on the track for practise and races?
Old 04-28-2004, 07:48 AM   #6000
Default Base Set up Mi2
I have just received my Mi2, and am looking for a base set up for a flowing tarmac circuit with medium grip (Take Off tyres). Can you please give me some advice on where to position cambers link, shock positions etc so I can have build the car with a reasonable base setting. I was running 30wt Oil with 1 hole and this worked well on the Mission. Have any of you guys run the Mi2 with similar shock set up.
Also are there any useful options parts that I should buy before building the car. (I have the steel dogbones from the mission that I will be using on the Mi2).
Matt
mattcaney is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
