Old 04-04-2004, 10:07 PM   #5746
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'm running AE blue and silver springs on the car with 35wt and 30wt oil and Tamiya 3 hole pistons.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-05-2004, 06:23 AM   #5747
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
hmmm, and those springs are real soft right?, what hole on the shock towers are you using???
=MisFitz= NuKe is offline   Reply With Quote
Old 04-05-2004, 06:46 AM   #5748
STLNLST's Avatar
the springs are pretty soft. With the low bite that we have had here the softer set up seems to work better. The soft set up also worked pretty well on high bite carpet. I'm using the carpet towers front and rear and I'm all the way in on the front (may come out one hole or put on 2 degree caster blocks) and in the rear I'm one hole in from the outter hole.
Old 04-05-2004, 08:23 AM   #5749
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
My setup is gettting softer and softer. I am 15lbs all the way around, and I going to a lighter oil ( 45 right now ). Gonna try 40frt, 37.5 rear
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-05-2004, 02:10 PM   #5750
mo
mo's Avatar
Default Intro
Just thought I would introduce myself in this thread. My name is Jason Moberly and I am the newest member of the Schumacher Team. The last 4 years I have been running for Yokomo and before that was with Team Losi. I hope to bring a lot of quality help and advice to everyone. I have only run the car once so far but am very happy with the way it runs.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-05-2004, 02:40 PM   #5751
Cool man, welcome to the Team
Stlnlst, ya, I think I am definently going to go to 30wt and 35 like you, and stay with three hole pistons and try it.
Old 04-05-2004, 02:45 PM   #5752
mo
mo's Avatar
Thanks.
The setup that stlnlst was trying to post from a couple weeks back that TQ'd and won at Speedworld was actually mine. I have it posted on my website now for anyone who is interested. www.mo-net.ws
Old 04-05-2004, 04:38 PM   #5753
Send a message via Yahoo to the shoe
Default welcome
Welcome to the team Mo. My name is Mark Nortness aka "The Shoe" i've been runnin and racing Schumachers since 92 I'm the unofficial team mascot unofficialy! Its a good car and i'm sure to do better as i get use to it.
the shoe is offline   Reply With Quote
Old 04-05-2004, 05:14 PM   #5754
Trader Rating: 244 (99%+)
Welcome MO
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-05-2004, 06:35 PM   #5755
hey, what mid pulley are you guys running, that is one of the few things that I have not tested yet, mainly because I usually run 64 pitch, but I am waiting on the gear adaptor, so I am limited on 48 pitch pinions
Old 04-05-2004, 08:13 PM   #5756
STLNLST's Avatar
we have only run the 20. I plan on testing the 17 possibly this weekend.
Old 04-05-2004, 08:45 PM   #5757
haha, i forgot, but which is the one they show to install when building the kit?
Old 04-05-2004, 10:28 PM   #5758
MO, thats awesome, welcome to the team. Racer-x and i used his setup the last two weeks. racer-x took 2nd with it in the pro-19turn class on sat. awesome setup. thank you mo for your help.
the cop,
rich
gdcopbdcop is offline   Reply With Quote
Old 04-06-2004, 04:55 AM   #5759
Send a message via ICQ to MattW
Generally we use the 20t pully all of the time. I tested it a bit when we first got the mission. The 17t did give the car more bottom end, but the car didn't seem to have as much top end. Couldn't ever explain why this was the case, but it sure seemed like that.
MattW is offline   Reply With Quote
Old 04-06-2004, 05:24 AM   #5760
steveM3's Avatar
Default pulley
I have ran both the 17 and the 20 pulley. All the factory drivers use the 20t. I didn't notice a difference when I tried the 17. You have to use a larger pinion to get the same gear ratio with the 17t. In stock I usually gear a 64 pitch 124/33 or 34 and in 19t I would go with a 124/35 or 36 pinion.
Steve McNichols
Serpent- Desoto Racing
steveM3 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
