Schumacher Corner
#5676
Originally posted by STLNLST
The car is working pretty well now. I'll post the set up that TQ'ed and won mod this weekend if I get off of work at a decent time.
#5678
k, cant wait to compare set-ups.
Ok, easy question.
Do you run a spool? Yes or no?
everyone quote this, then put your answer
I have access to a CNC mill/lathe at my school , and was going to make some pieces for my TC3, but since I am not running that anymore...., I decided that the one thing that I cannot find in the US, or maybe anywhere, is an actual spool for the Mi2, I am not going to go the lock-up-the-diff-way, so I have drawn up two main designs that I am going to show to my CAD/engineer teacher and get something going here. I want your answers to see if I should make a lot, or just a few, for a few select people.(as in buying the material in bulk or not)
Ok, easy question.
#5679
Ok, easy question.
Ok, easy question.
#5680
well, correct me if I am wrong, the way you guys are making spools, is taking a diff apart and putting sand paper and stuff in there, then locking it down right? if so, I dont trust that, and would rather have somthing much lighter than that.
#5681
#5682
P-DUB
Hello,
I was just wondering if there was any word on the P-DUB and when it will be available?
Joe
Joe
#5683
#5684
Must admit i wish there was a proper spool. I did make one last year for the mission by drilling the outdrives and bolting straight through so it was properly fixed. However i did have a big impact, and did brake one of the outrdrives (and MIP coupling!). I was then recomended to go with the route that is in the manual now. Seemed ok, but it did move, although i suspect that might have been impact related!!
There was some info on the Titanium Racing site that they were looking at makeing some spools, but i haven't heard anything more about that so not sure if they dver did.
#5685
i was woundering if i could get the pro's and con's on the MI2. and dont waste anyones time by saying its perfect because no car is. oh pro's and cons' for foam tires on carpet too
thanks lazy
thanks lazy
