Old 03-24-2004, 04:23 PM   #5641
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The new Ti Bones are VERY NICE. I would say they are one of the first options to look at.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-24-2004, 07:22 PM   #5642
Send a message via Yahoo to the shoe
here is my layout in the MI2
the shoe is offline   Reply With Quote
Old 03-25-2004, 07:43 AM   #5643
Send a message via ICQ to MattW
My layout is essentially the same as the Shoe. I haven't got a digi cam handy here at the moment!! Reciever (novak xxL mounted with crystal up parallel with the belt. Then Keyence ESC mounted so wire pads point to the motor. Fits nicely. I then mount the PT on top of the servo.
MattW is offline   Reply With Quote
Old 03-25-2004, 10:45 AM   #5644
P-DUB's Avatar
Butter....That is currently top secret info
btw guys....The carpet nats are going well and McMoney and Cartwright are flyin....My ride is going pretty good as well
Larry Pryor
P-DUB is offline   Reply With Quote
Old 03-25-2004, 11:40 AM   #5645
RBLove's Avatar
Trader Rating: 72 (100%+)
Awesome Paul. Lay it down dude!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 03-25-2004, 07:51 PM   #5646
rcshark's Avatar
Send a message via Yahoo to rcshark
good luck paul and to the hole shue team!
rcshark is offline   Reply With Quote
Old 03-25-2004, 10:36 PM   #5647
STLNLST's Avatar
Trader Rating: 19 (100%+)
Good luck to all of the guys. Looks like the car is doing well.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-26-2004, 12:26 AM   #5648
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Thumbs up
ya, good luck to Team Schuy USA!!! LET'S get
=MisFitz= NuKe is offline   Reply With Quote
Old 03-26-2004, 07:21 AM   #5649
AdrianM's Avatar
Cartwright is was 4th with McMahon 5th in last nights similated qualifying. Good luck to the guys as they qualify today!
Oneways vs. Spools - We have not run into a situation where one ways are better than spools yet. Tight diffs aren't anywhere near as good as a spool. Everywhere we go spools are faster. You have to change the setup of your car to make the car turn in harder but that easy with the Mi2.
My car has just as much turn-in with a spool with my current setup as it did with my best one-way setup. BUT with a spool I can run into corners harder and exit steering/acceleration are way better.
In Mod you can run deeper in to corners and tap brakes to make a corner where one way guys have to lift 3/4 of the way down the straight to make a tight corner.
One word of warning...if you crash hard with a spool you will break stuff. Mi2 is toughter than ALOT of other cars in this respect but since there is no give with a spool something has to go. You be the judge of your skill level. If you crash a lot run a diff or a one way.
Adrian Martinez
Old 03-26-2004, 06:00 PM   #5650
Default mission
This is a little off topic but what are most of you guy's running for bearings...i have a Mission...run mostly foams on carpet....
6Cuda6 is offline   Reply With Quote
Old 03-26-2004, 06:07 PM   #5651
Trader Rating: 240 (99%+)
Kit standard
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 03-26-2004, 06:56 PM   #5652
koabich's Avatar
Send a message via Yahoo to koabich
I ran Acer Ceramics in the Mission. Schumacher metal sheilded bearings are the worst for running on carpet. But I am very impressed with the new blue sheilded bearings that came with the MI2. It may be a while before I switch over to the Acer ceramics with these bearings!
koabich is offline   Reply With Quote
Old 03-26-2004, 08:14 PM   #5653
STLNLST's Avatar
AdrianM- Are you in the office on Monday? If so I'll give you a call to place an order.
Old 03-26-2004, 08:16 PM   #5654
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
when running foam what do guys recamend for a setup spring,oil and sawybar wise, the rest i think i can figure out.
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 03-26-2004, 09:13 PM   #5655
When you say tight diffs, do you mean locked diffs or just adjusted tight?
what set up mods would you do, to get it to turn in harder with a spool compared to a diff?
thanks
Mick
ratter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
