Old 03-15-2004, 08:56 PM   #5581
STLNLST's Avatar
Trader Rating: 17 (100%+)
P-Dub...Thanks. Sorry that I didn't get to fax that set up over to you today. Work was too much after a three day weekend. I'm working on an asphalt set up this weekend. I liked the set up that Rich and I ran but I I have something that I want to try. I'll keep you informed on all changes.
Here's a link to the set up that I ran this weekend on carpet with rubber tire's.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-16-2004, 06:03 PM   #5582
P-DUB's Avatar
No problem Clint....I have no doubt you guys will get it rolling at Speedworld, I just hope Billy puts down some traction
Well I will be running carpet for the next 2 days in preperation for the carpet nats. The facilty ( www.rpmraceway.com ) I will be running at has to be the best I've been to in my 18-years of racing!!! I will post pics of the new place when I get back from testing
P-DUB is offline   Reply With Quote
Old 03-16-2004, 08:24 PM   #5583
Send a message via Yahoo to the shoe
Default PW Troy
I got one of thoes first kits from Superior,now on to the build! Troy any set up help for the race at the speedway would be good . Can we pit together? I will start with my Strickland set up from my mission and any other segestions you may have.
the shoe is offline   Reply With Quote
Old 03-16-2004, 08:38 PM   #5584
P-DUB's Avatar
Hey Shoe....Congratulations on your new Mi2!!!
The setup will vary slightly from your Mission and I would recommend starting with some of these basics:
Front:
3 hole/45wt
Blue spring
Tower/middle hole
Camber/Inside lower
Swaybar/Stock
Toe/0deg
Arm/outer hole
Rear:
3 hole/45wt
Blue spring
Tower/2nd hole in
Camber/middle lower
Toe/1.5deg
Arm/2nd hole from outside
Swaybar/Stock
Remember this is just a basic setup to start with
Old 03-17-2004, 02:45 PM   #5585
turbodog's Avatar
Shoe, are you sure you want to pit with Team Daytona?! lol We can be brutal, but you're more than welcome. P-Dub's setup should be a good place to start, but just ask and we'll help set your ride up.
Troy Schafer
turbodog is offline   Reply With Quote
Old 03-17-2004, 02:50 PM   #5586
turbodog's Avatar
Just shut up Padilla! lol
Troy Schafer
Old 03-17-2004, 10:01 PM   #5587
PW
PW's Avatar
Send a message via AIM to PW
Finally, the Mi2 kits arrived and shipped today!!!! If you had one on back order with a local dealer, please contact them for your new Mi2!!!!!!!!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-18-2004, 07:23 AM   #5588
STLNLST's Avatar
PW- I'm going to try the spool out again on Saturday. I'm sticking with it to test for the Reedy race. The set up might end up being slightly different from what we'll run at the Tamiya track but any practice I can get with it will only help me. Since there's no motor limit this year what winds do you think we should run?? 8x2 or 9x2
Old 03-19-2004, 11:21 PM   #5589
Thumbs up WARPSPEED RACING
We here at WARPSPEED RACING would like to wish GOOD LUCK to all Schumacher drivers at the Nats.
Mr Warpspeed is offline   Reply With Quote
Old 03-20-2004, 01:01 PM   #5590
Default mission
What are you guy's running for piston hole # with 50 weight oil on front shocks...this is for a foam set-up or better yet post me some set-ups for foam on carpet [i know im behind a bit but it's just a standard Mission with a Dirt Trix chassis]...thanks...
6Cuda6 is offline   Reply With Quote
Old 03-20-2004, 02:41 PM   #5591
Trader Rating: 237 (99%+)
cuda,
a #3 or losi #60
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 03-20-2004, 07:19 PM   #5592
Default Motor break in
G'day from a fellow aussie mission owner,
I'm new to the sport and have read all the posts in this section over the last few weeks and have gained some valuable knowledge.
I'm still learning to drive my car, but have got to the stage where I'm starting to chase some more speed from the car.
I have started to stiffen the car up (after eliminating understeer) and have a set up that I can drive fairly easily, but my car is still down on speed (I know some may be in the lines I'm taking)
I've just started to lube the motor brushes and add com drops to help the motor, I've just soaked the belts in wd40 and removed the sheilds from the wheel and diff bearings, but I feel my motor may be lacking speed.
I run in 540 pro at boronia, which uses a stock johnson silver can motor, I have just purchased a new motor and wanted to know about breaking it in, I have heard about breaking it in, in water and was after some info about doing this, if someone could either give me step by step details or give me a link to a website that may give me details.
Thanks for all the helpful advice in all the previous posts and thanks in advance for any help about breaking the motor in.
Mick
ratter is offline   Reply With Quote
Old 03-20-2004, 08:01 PM   #5593
rcshark's Avatar
Send a message via Yahoo to rcshark
Ratter,
Hi, Im a old racer all my moters are just as fast and do just as good as the fastest guy on the track. I just have to drive concistant laps. I dont thank motors that win races are that much better cause on time into the wall or a slip of the tires makes every one else even. cause 200 rpms is not anough to be seen. and even if every thang is great your car still has to be set up right. know matter how fast we are. if your laps are with in 5/10 of a second of each and every on then yes try fixen the motor if not lift your body! lol
rcshark is offline   Reply With Quote
Old 03-20-2004, 08:05 PM   #5594
Default break in
the trick with sealed can motors is to break them in using low vols <3 volts for a long time 25-30 mins this is cause they have very hard brushes that need to be bedded to get max performance. remember to keep the motor lubed while doing this to. gearing is crucial in 540 class so find out what the local guns are using and start there.
hope this helps
Gary
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 03-20-2004, 08:28 PM   #5595
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Default P-Dub
Hey P-Dub how did the testing go with the chassis? Are they going to be ready soon?
Thanks and see you in a few days!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
