Old 02-28-2004, 06:24 PM   #5446
Racer X's Avatar
Just got back from the first run on the Mi2 and all I can say is awsome! Put PWs asphalt setup on the car and it was very good right out of the box. Normally I have a problem with new cars and getting the feel that I like, but this is the best a new car has ever felt to me. Only a few small changes for stock: 40wt all around and went to 20lb springs all around to free the rear end up some. In the end, however, the rust got me (haven't ran for awhile) and drilled a board taking me out of the main. The car is a pleasure to drive, but next time I'll bring a map so I know where those corners are.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-28-2004, 10:12 PM   #5447
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Thumbs up Easy Build!
Well, I got the car on Wednesday night. I sanded the graphite parts for sharp edges that night. On Thursday after school, I went at it. Time from start to finish, excluding shock build, was 3.5 hours. Very, Very easy build. The car went together very nicely. Only two tings I had to modify, sand the rear A-Arms to fit the E-clip onto the hinge pin, and a little "exacto-ing" of the front steering knuckes. I can't wait to run it this next weekend. I will post many updates.
L8r,
=MisFitz= NuKe is offline   Reply With Quote
Old 02-29-2004, 10:38 AM   #5448
STLNLST's Avatar
Trader Rating: 19 (100%+)
thanks for letting me run your car yesterday. Mine is now ready for some action but I'm going to hold off for the oneway and more caster blocks (if they're in stock) for next weekend. What changes did you make to the set up after I ran it? Are driving stlye are slightly different as you were looking for more steering and I wanted less. We have all spring and summer ahead so testing will be a blast.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-29-2004, 12:00 PM   #5449
P2
P2's Avatar
Trader Rating: 15 (100%+)
Yo STLNLST,
My friend MisfitzNuke has joined forces with you and will be running for Shumacher and Redline motors. Hook up with him cause he's a good guy and very fast!
See you in Cali sometime....are you going to Oregon?
P2
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 02-29-2004, 02:16 PM   #5450
STLNLST's Avatar
Originally posted by P2
Yo STLNLST,
P2
oh yeah....I'll be in Oregon for the nats. I have some folks out there that I haven't seen in years and I have already let them know when I'm coming into town.
What track does your boy run at? Since he runs for redline....then he's a mod racer and that will work out fine.
Old 02-29-2004, 02:20 PM   #5451
P2
P2's Avatar
I met him here at San Antonio and we race at www.hobbytownsatx.com I got him hooked up with Redline. There will be a group of us from SA going to the Nats in Oregon. See you the,
P2
Old 02-29-2004, 05:04 PM   #5452
Trader Rating: 71 (100%+)
Another good carpet set up. "MAYBE" better than my Birds set up.
Carpet/foams/medium traction
Front:
#3 60 wt. Losi
30 lb spring
shocks middle on tower and inside on arm
arms forward
camber link up and out (short)
4 degree caster block
low roll center (no kick up or anti-dive)
1mm up travel for droop
.055 sway bar
Rear:
#3 45 wt. Losi
25 lb spring
shocks middle on tower and out to the third hole on arm
arms forward
camber link full long (up and in)
low roll center (no kick-up or pro-dquat)
1.5mm up travel for droop
batteries forward and angled in
Proto Alfa body (I tried 2.0 and Mazda)
BSR pruple/orange front
BSR purple rear
motor shimmed out 2.5mm
solid top deck
RBLove is offline   Reply With Quote
Old 02-29-2004, 07:42 PM   #5453
PW
PW's Avatar
Send a message via AIM to PW
Hey RB....Looks like your weekend went a little better this time
btw....That setup looks closer to what I started the Birds with Keep up the good work!!!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 02-29-2004, 10:00 PM   #5454
Sweeeeeeeeeet, cant wait to get those castor blocks in to run this thing ( Paul)
Old 02-29-2004, 10:57 PM   #5455
PW: Do you know anything about Teemu's carpet setup (for rubber tires)? My car should be here this week
Tuure is offline   Reply With Quote
Old 03-01-2004, 07:05 AM   #5456
STLNLST's Avatar
Tell Paul that Clint said what's up! Did you get your Redline motors yet? You'll love em' I guess I'll catch you at the nats in Oregon.
Old 03-01-2004, 07:17 AM   #5457
JusBox's Avatar
P2
I used to go to that Hobby Town when I was living in SA. Is that still the only good place to race in SA?
JusBox is offline   Reply With Quote
Old 03-01-2004, 11:13 AM   #5458
P2
P2's Avatar
Hobbytown is the only place right now...I think the US Pan Car champs will be held there next year. There is another track opening up next month called Phat Boyz. Mainly 8th scale but they plan on running 10th too.
Old 03-01-2004, 02:59 PM   #5459
no, I havent gotten them yet, I know they will be fast, Paul always passes me on the straights, lol
Old 03-01-2004, 03:06 PM   #5460
JusBox's Avatar
so phat boyz will be an off road track only?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
