Old 02-19-2004, 03:25 PM   #5401
AdrianM's Avatar
Adrian Martinez
Old 02-19-2004, 06:29 PM   #5402
RBLove's Avatar
Trader Rating: 72 (100%+)
King G hit it. There will be solid top decks offered for more stiffness, but the car is pretty [email protected] stiff the way it sits. We race carpet with foams and have no problems with it. Give it a chance and you will be impressed......
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 02-19-2004, 06:59 PM   #5403
PW
PW's Avatar
Send a message via AIM to PW
Hey Rob....Hit me with an IM if your still online or call me at work tomorrow!!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 02-19-2004, 08:03 PM   #5404
rayhuang's Avatar
Fleetwood-I scored another PT tonight at practice-Want it?
Ray
Old 02-20-2004, 03:50 PM   #5405
PW
PW's Avatar
Thanks Rob!! Lay it down this weekend!!!!!!!!
Paul Wynn
Old 02-20-2004, 06:27 PM   #5406
RBLove's Avatar
Just finished getting her ready for some Sunday action. I will give you an update Monday on my findings........
L8R P-Dizzzzzzzzzzub!
Old 02-21-2004, 04:20 PM   #5407
show'em how it's done. don't blow it! Let me know what you find.
andrew
Fartwright is offline   Reply With Quote
Old 02-21-2004, 09:25 PM   #5408
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Just got home from running the Mi2 for the first time. Only got to run 4 practice packs through the car but it was very good by qualifying. Ended up 3rd or 4th about 5 seconds off of Fernando. Car was easy to drive, carried very good corner speed and has great acceleration. Very easy to work on too!!
Bad news is I didnt get to run the main because I pulled the screw through the front of the chassis in the 4th qual Will have to figure out how to stop that (besides hitting the wall) for next time.
Good job Schumacher on the car.
ea
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-21-2004, 09:58 PM   #5409
Default alloy hubs
does anyone think the alloy hubs for the mission are worth the investment. ive never personally busted a hub so i cant see the need for alloy ones any opinions would be appreciated.
thanks
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 02-21-2004, 10:36 PM   #5410
Honestly if you don't break the regular plastic hubs they really aren't worth it. The plastic ones are more adjustable (the hub's height and ball stud location) and they are lighter (less unsprung weight). On the R12 gas sedan I think it's worth it though.
Old 02-21-2004, 11:36 PM   #5411
AdrianM's Avatar
NOTE TO ALL Mi2 FOAM TIRE CARPET RACERS!!!!
The Mi2 is better on foams with the suspension riser plates removed. However, when you remove these the chassis is weakend and a hit to the front can break your chassis or pull a screw through. If you run foam and remove your riser plates take the front one and cut it down so it acts as a strap and mount it on top of your forward front hinge pin mounts. If you do this you will not break the chasiss or pull screws through.
If you run rubber just run the car stock with the risers and your all good.
Adrian Martinez
Old 02-22-2004, 01:48 AM   #5412
MrEs's Avatar
Send a message via ICQ to MrEs
spoon worth running in 540?
MrEs is offline   Reply With Quote
Old 02-22-2004, 11:17 AM   #5413
Racer X's Avatar
Finished building my Mi2 last night...it was the easiest Schumacher I have ever assembled. The suspension arms are perfect and needed no reaming or shimming work at all. The rear hubs were just slightly tight, but that was it. The car went together in no time. The only points I can make are that with the rear diff, it goes left diff cover, spacer, front drive belt, spacer rear drive belt, right diff cover (but that is not hard to figure out). I also widened the battery slots so that 3300s would drop in easier (but it's not really needed, just a personal preference). I really like the bigger droop screws, and, of course, all the factory purplonium. Hands down, the nicest car Schumacher (and possibly any manufacturer) has ever put out! Only problem is that it's raining and I can't go and run it (yet). I'm headed back to the garage to see if I can find some rain tires...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-22-2004, 04:27 PM   #5414
PW
PW's Avatar
Sounds great Jeff!
One thing I don't recommend is opening up the battery slots in the battery tray. You will only need to file the slots if you run extra shrink on your cells. Schumacher made the slots over sized to allow the 3300 cells to sit flush with the chassis. If you file the slots your cells will drag....RB cough cough....LOL
What the heck are you doing on the message boards Andrew?? Your suppose to be working on setups for all of us racers that don't have a track to race on 24hrs a day....Give me a call tomorrow because we have to get flights for the carpet nats!!!!
Paul Wynn
Old 02-22-2004, 05:59 PM   #5415
Racer X's Avatar
...as a matter of fact, I do run shrink wrap on my cells.
Ended up raining most of the day (not hard, but too hard to run the car). Bet tomorrow the sun is out and its beautiful while I'm at work
Schumacher Mi6
Integy
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
