Old 02-12-2004, 08:58 PM   #5341
Trader Rating: 71 (100%+)
Default Snowbirds set up
If any of you are planning to get the new Mi2 and run carpet here is my set up from Snowbirds. Car was really good.
Front:
#3 piston
60 wt Losi
38 lb X-Ray spring
62 mm shock length
1 mm up travel (droop)
shocks are in on arm and all the way in on tower
camber link is up and in
6 degree caster block
.030 anti-dive
arms forward
no arm sweep
-1.5 camber
middle holes used on bellcrank
motor spaced out 2.5mm
5mm ride height
Rear:
#3 piston
45 wt. Losi
28 lb. X-ray lavender spring
62mm shock length
1.5 mm up travel (droop)
shocks are in third hole on arm and one in from outside on tower
roll center raised 1mm
arms forward
1.5 rear toe
-1.5 camber
5mm ride height
battery position angled (see x's below)
x
x
x
20 tooth pulley
132 PRS spur (coming soon)
solid top deck (coming soon)
Warpspeed shock towers (coming soon)
Protoform Stratus 2.0
BSR purple-orange front tire (2.20)
BSR purple rear tire (2.20)
Only change I made for 19t was double pink rear tires and double pink orange front tires.......
RBLove is offline   Reply With Quote
Old 02-12-2004, 08:59 PM   #5342
Battery picture did not turn out right....... Sorry.
I ran the battery in the forward position and ran the front at the inner most setting and the rear was in the outter most setting.
Old 02-13-2004, 01:12 AM   #5343
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Were the new Takeoff carpet foams available? If so, how did they work out?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-13-2004, 04:11 AM   #5344
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Mi2s are now available from Australia. Seling fast and are very popular!
Check your local Schumacher distributor. Metro Hobbies in Melbourne have them now.
Oasis2001 is offline   Reply With Quote
Old 02-13-2004, 07:02 AM   #5345
AdrianM's Avatar
We didnt have the TakeOff's ready for the birds. We are still working on them.
Adrian Martinez
Old 02-13-2004, 11:51 AM   #5346
rcshark's Avatar
Send a message via Yahoo to rcshark
PW.
could you give a close set up for asphalt close track for the mi2. if it comes with that med. track set up like most kits that will be great im sure it does. but would like to know thanks!
rcshark is offline   Reply With Quote
Old 02-13-2004, 05:17 PM   #5347
RCShark,
P-Dub is at the Winter Nats gas race. I believe he will be back in the office Monday.
Old 02-13-2004, 06:43 PM   #5348
Just saw that PW is sitting 6th after qualifying. AWESOME!!!!!
Old 02-13-2004, 06:59 PM   #5349
AdrianM's Avatar
PW TQ'd and Won Spec 19 and Mod at our first Florida State Series race with this setup.
www.fseara.com
Front:
Locked diff/Spool
#3 vari piston
40 wt Schu oil
Blue (17lb) AE Spring
shocks are out on arm and all the way out on tower
camber link is down and in
4 degree caster block
stock front riser plate no kickup/anti dive
arms middle
0 toe in/out
arms swept out
-1.5 camber
4.5mm ride height
Rear:
#3 vari piston
40 wt. Losi
Silver (14.5lb) AE spring
shocks are one in from outer hole and one in from outside on tower
roll center raised with stock plate and 1mm anti squat
arms middle
3deg rear toe
-1.5 camber
5mm ride height
battery position middle-middle
Protoform Mazda 6
TakeOff CS27GL (Florida Spec Tire) front and rear
Paragon FX2
Adrian Martinez
Old 02-13-2004, 07:25 PM   #5350
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Looking forward to the new car...This year should be a good one!!
ea
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 02-13-2004, 07:31 PM   #5351
rayhuang's Avatar
You know-I wasnt half bad at 0.12 touring the other summer.....Maybe its time to buy an R12!!!
Anyone want to buy one of the best, most competetive Serpent Impact WC02 packages in the country so I can buy an R12??
hehehe!!
Ray
Old 02-13-2004, 08:54 PM   #5352
ottoman's Avatar
R/C Tech Charter Subscriber
whats the link for the big nitro race?
ottoman is offline   Reply With Quote
Old 02-14-2004, 06:49 AM   #5353
STLNLST's Avatar
Trader Rating: 19 (100%+)
It shouldn't be long now. I can't wait. Testing different set up's will be fun. I'll see what the kit standard set up is like and I'll also run the set up Adrian posted and go from there.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-14-2004, 05:37 PM   #5354
Matt Howard's Avatar
Better get that car and hurry up, Me and Mo got our CGM's working pretty good today
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-14-2004, 06:19 PM   #5355
P2
P2's Avatar
Clint,
From what I've heard it's just a belt drive TC3
P2
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
