Old 02-04-2004, 07:31 PM   #5311
Gav
Why have you played with both a diff and a Spool but not a oneway? would a oneway be your first thing to try
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-04-2004, 08:40 PM   #5312
King-G's Avatar
Send a message via ICQ to King-G
Hi Brad. Mi2 uses a different belt offset, therefore cant use the Missions oneway without some surgery...The Mi2 comes with a Diff, and exibits more steering out of the box using a diff, than our missions did using a oneway...
New and improved oneways are being produced, and should be out around the same time as the production kits...
Normally I would have tried a oneway straight away..car comes with a diff, and we were asked to test the car as it comes, the manual covers how to convert your front diff to a spool.
King-G is offline   Reply With Quote
Old 02-04-2004, 09:01 PM   #5313
JusBox's Avatar
diff to spool, huh? What does it tell you to do?
JusBox is offline   Reply With Quote
Old 02-04-2004, 09:10 PM   #5314
STLNLST's Avatar
Trader Rating: 17 (100%+)
King-G......thanks for all of the info. I only drove a mission a couple of times so I won't be able to compare the Mi2 to the mission. I do know that my Losi was dialed so that's what I'll be comparing the car to. I really want to look into the drive train since I've been hearing nothing but good things about it. At my local track the drive train king (efficientcy wise) was the TC3 then the Losi/SD
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-05-2004, 02:49 PM   #5315
Default WARPSPEED RACING
Good Luck at the Snowbirds.
Mr Warpspeed is offline   Reply With Quote
Old 02-05-2004, 03:28 PM   #5316
King-G's Avatar
Awol soldier...its pretty straight forward, as you would have guessed...remove the main diff balls, clean and reassemble...retighten so it wont slip
I went 1 step further by cutting out some thin cardboard into the shape of the diff rings and placed against the diff pully for extra padding out, as I was afraid of crushing the thrust assembly when tightening down...I also used some junk diff rings, so that I could save my good ones.
surprised how easily it locked, hardly any tension on the diff bolt, 4 runs and it hasnt shifted one bit...
Old 02-05-2004, 07:07 PM   #5317
Default 17 0r 20
hi guys
when setting up a car for 540 do you find you use the 17 or 20 tooth gear more
thanks cheers
djrfan is offline   Reply With Quote
Old 02-05-2004, 09:33 PM   #5318
King-G's Avatar
personally I would go for the 20 tooth, for all but the tightest of tracks...especially with 540..as these things work best geared up
Old 02-06-2004, 07:45 AM   #5319
AdrianM's Avatar
Snowbirds qualifying began very early this morning....
I'd like to wish good luck to all the Mi2 racers:
Teemu Lieno: Mod, Pro 19
Paul Wynn: Mod, Pro 19
Andrew Cartwright: Mod, Pro 19
Mike McMahon: Mod, Pro 19
Rob Love: Stock
Latif Michail: Sport 19
Tony Padilla: Stock
Steve McNichols: Stock, Sport 19
Adrian Martinez: Sport 19
Adrian Martinez
Old 02-06-2004, 08:02 AM   #5320
DaveVera's Avatar
Good luck guys...............Lay it down properly Adrian, thanks again for everything................................
DV
DaveVera is offline   Reply With Quote
Old 02-06-2004, 08:07 AM   #5321
coastaltony's Avatar
Like the King! TCB!
coastaltony is offline   Reply With Quote
Old 02-09-2004, 07:56 AM   #5322
STLNLST's Avatar
PW- how was the race? Did you learn anything new on the car?
Old 02-09-2004, 08:38 AM   #5323
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Thumbs up
good job rob love! makin' da show in only two weeks with the car. you da man. you coming up soon so i can see that ride?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-09-2004, 09:28 AM   #5324
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The Mi2 looked awesome at the birds, the guys did a great job with the car... Teemu was just plain ballistic. Nice to meet all the team drivers.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-09-2004, 10:51 AM   #5325
jrighter's Avatar
2 weeks.. Try one day of practice in Zanesville. He just got it last Wednesday.. real good job!
jrighter is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
