Old 02-02-2004, 02:22 AM   #5296
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Will this car have an optional battery holder for stick packs
RKeasler is offline   Reply With Quote
Old 02-02-2004, 05:44 AM   #5297
Originally posted by RKeasler
Oasis2001, what motor was he running in the car?
He was running an 8x1
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 02-02-2004, 05:58 AM   #5298
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Yep it was an 8x1. The manual shows a stick pack battery holder and I believe, as the Mission, it will only be with the S1 kit. Dont hold me to that though. Final details are being sorted this week.
Oasis2001 is offline   Reply With Quote
Old 02-02-2004, 04:47 PM   #5299
Default bearings for mission
hi guys
you were talking earlier about mission bearings
what types and costs are there for bearings
im in australia so local prices are better for me
and also what type of maintenance is needed for them
cheers
djrfan is offline   Reply With Quote
Old 02-02-2004, 05:06 PM   #5300
King-G's Avatar
Send a message via ICQ to King-G
the blue seal bearings that come with the Mission and Mi2 are of a very good quality, excellent seals, and durability so far has not been an issue.
Keep them clean and lightly oiled and they will last...(i had mine for 1 full season)
I recommend flushing them every couple of track days, and re oil with royal oil.
I purchased some acer dual polyamide bearings from the accer website, a full set cost me around 100 aud, and I found them no better than the new schumacher blue seals, in fact they look strikingly similar!
King-G is offline   Reply With Quote
Old 02-02-2004, 05:16 PM   #5301
King-G's Avatar
hub bearings are 5x10x4: u2148
diff output support bearings are 10x15x4: U1410
layshaft and tensioner is 4x8x3: u1529
part numbers are schumacher,
Old 02-02-2004, 06:24 PM   #5302
Send a message via Yahoo to the shoe
Default Mi2 in the house!!
W-2 just came and off it goes to the taxman! I'll stop by the schumacher camp at the Birds and place an order.. See ya at The Bird boy's!
the shoe is offline   Reply With Quote
Old 02-02-2004, 08:43 PM   #5303
Good Luck at the Snowbirds.
Mr Warpspeed is offline   Reply With Quote
Old 02-03-2004, 12:58 PM   #5304
AN
Is ther possible to buy Take Off tires from the schumacher web shop?
/AN
AN is offline   Reply With Quote
Old 02-04-2004, 11:24 AM   #5305
AdrianM's Avatar
King-G Thanks for all the great updates on your Mi2!
Bearings...
King-G is correct about everything except the diff outdrive bearings. On the production Mi2 they will be 10x15x4 flanged bearings (U2762).
Adrian Martinez
Old 02-04-2004, 02:32 PM   #5306
King-G's Avatar
Np's Adrian...
I think he was asking for Mission bearings, not Mi2...
Old 02-04-2004, 02:37 PM   #5307
King-G's Avatar
FYI guys, when building the shocks, on the Mi2, i have done some expertimentation with lengths, and found fronts to be best set to 65mm, and rear 67mm (measured end to end)..The reason for this is to allow adequate bump and droop measurments...
originally I built mine to the Kit specs of 64.4mm, but found I couldnt then use the outer 2 holes on the lower rear arm as this was resticting length therefore droop. And as we usually run less droop up front you can get away with less length, permitting further travel in bump.
I found the lengths were affecting bump travel up front, and droop travel in the rear, due to the slightly different geometries of towers and arms F/R
just a suggestion to look out for when building for the first time
otherwise, start with the manual suggested kit settings, the thang is dialled out of the box!!, even with a front diff I was quicker than I was with my mission (using a oneway mind you), I changed to a spool late on the second day of testing, and thats another story altogether!!!
Old 02-04-2004, 02:39 PM   #5308
JusBox's Avatar
Originally posted by King-G
FYI guys, when building the shocks, on the Mi2, i have done some expertimentation with lengths, and found fronts to be best set to 55mm, and rear 57mm (measured end to end)..The reason for this is to allow adequate bump and droop measurments...
Are these lengths at full extension?
JusBox is offline   Reply With Quote
Old 02-04-2004, 02:42 PM   #5309
King-G's Avatar
geez your quick!...sorry I ammended the post, I already ammended the post, I meant 65 and 67...
lol..eager bunch!
Old 02-04-2004, 02:44 PM   #5310
King-G's Avatar
sorry yes, full extension, measure with verniers end to end
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
