Old 12-08-2003, 02:48 PM   #5011
AdrianM's Avatar
SteveG - What do you need to know?
Regarding the shocks - You have to test the best to know where you stand. PW, Andrew, Jonas Andresson, Chris Ashton and Andy Wallis are all running Schuie shocks now with identical laptimes compared to the Tam shocks.
Adrian Martinez
Old 12-08-2003, 04:41 PM   #5012
Well the first question is are they still being manufactured and can spare parts be had easily and directly from Florida since my LHS does not stock them ? I heard the chassis tweaks quite easily, how thick is it and whats the material 7075, 6061 etc ? Hows the acceleration given it's size and .21 powerplant ? I read it has blazing top speed so thats covered but nowhere is there any mention of acceleration performance, like can it pull off a corner as well as a 10th nitro ? Hows the diff and brakes holding out given the size of the machine ? Any problems or required fixes to do right away should I buy one or two ?
SteveG is offline   Reply With Quote
Old 12-08-2003, 07:19 PM   #5013
alfa's Avatar
Exclamation
Nitro Big 6 + 1/10 Electric = .........
alfa is offline   Reply With Quote
Old 12-08-2003, 08:44 PM   #5014
PW
PW's Avatar
Send a message via AIM to PW
Congrats go out to Andrew Cartwright for his big win this past weekend!!!!!
In only his second race (2004 Northwest Indoor Champs) with the new Mi2, Andrew TQ'd and won both 19turn and Mod Sedan foam classes!!! Andrew learned a tremendous amout in Cleveland and things are paying off already.
The 2004 racing season should be exciting for Schumacher
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-09-2003, 05:42 AM   #5015
ozoner's Avatar
Can anyone tell me if I'm going to be able to use my Mission1 oneway diff on the mission2 ?
-Scott
http://www.harrisrc.com
http://www.funkygibbon.com
http://www.amishrakefight.org/gfy
ozoner is offline   Reply With Quote
Old 12-09-2003, 08:07 AM   #5016
PW
PW's Avatar
ozoner....The Mission 1 oneway will not work with the Mi2.
Paul Wynn
Old 12-09-2003, 11:22 AM   #5017
AN
Mi2 in US vs Mi2 in UK
Hello!
Is ther any difference between the Mi2 US version and UK version?
Do you guys know how much from Mi1 you can use as spare parts for Mi2?
/AN
AN is offline   Reply With Quote
Old 12-09-2003, 11:29 AM   #5018
Yes, the US version will be LHD, have DOT-marked windows and dual cupholders. UK version will be RHD and have E-windows
I don't think the MI2 shares too much parts with Mission. It is covered already earlier in this thread somewhere, but basically shocks, bearings, front bumper, driveaxles, belts and diffs(?) are carried over, the rest is new.
olev is offline   Reply With Quote
Old 12-09-2003, 11:34 AM   #5019
AN
Is it the same pitch on the spure/piniong gear?
/AN
Old 12-09-2003, 11:41 AM   #5020
The pitch is the same, most likely the gears themselves as well. One more thing that stays...
Old 12-09-2003, 01:24 PM   #5021
PW
PW's Avatar
Parts to carry over from Mi1 to Mi2 will be some of the obvious stuff like ball-ends, ball cups, roll pins, some screw sizes/lock nuts and spur gears.
Major parts to carry over will be lower arm mounts, bumper/body mounts, bearings, rear belt, CVD's (blades), wheel hexes with shims/roll pins, battery post, battery strap (flipped over), shocks and all shock parts, shock springs, shock mounts (recommend the Ti-Racing ones!!!), upper part of servo saver (arm, spring, bearing and post), servo arm, steering turnbuckles, internal diff parts (diff screw, diff rings, diff balls, thrust assembly, diff bearings and shims) and layshaft pulley (recommend alloy pulley)....I truly hope this covers all of it....oh, I forgot body clips....I'm sure someone will find something I missed.
If it isn't on this list, then its going to be new in some sort of way (materials etc)!!!!!
Please mark this post
Paul Wynn
Old 12-10-2003, 12:23 AM   #5022
Hmm... so the front belt will be new then?
What about rear toe settings? Will it be done inboard or outboard? Extra pieces to buy or included in kit?
Old 12-10-2003, 03:38 AM   #5023
Send a message via ICQ to MattW
Olev, Front/main belt is longer. Toe settings, i think you're looking at different hubs.
MattW is offline   Reply With Quote
Old 12-10-2003, 07:18 AM   #5024
AN
Ti-Racing shock mounts
Old 12-10-2003, 07:21 AM   #5025
ozoner's Avatar
Thanks for the information Paul - much appreciated. Does anyone know of any changes to dimensions such as wheelbase compared to the old car? Thanks.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
