Schumacher Corner
#4864
Teacher....There are no plans as of yet, but its on the list to test
Setups for the champs will be close due to the lack of time Andrew & McMahon will have with the production car (4 days), but thats the fun part when getting a new car.....LOL
Hey Ray.....Welcome to the BEST car thread on R/C Tech.....hehehe Victor was one of the first to have a Mi2 on order and you know what means...
#4865
But your car looks amazing. I like a lot of the things I see that are different than the original Mission. IT makes me mad I never walked up to see Mcmahons proto at the Halloween Classic. DUH!!!
The mere fact youve got guys on the team testing on foam tires and using there feedback is AWESOME!!! Cause what works on asphalt is WAY different than on carpet!!
#4866
how much did they say it was going to run for? price wise??
#4868
Kraig is right on....$299.99 for the Graphite Pro-Kit
$239.99 for the S1 Pro-Kit (same spec as graphite but S1 chassis material)
BTW: KT Hobbies has some of the first kits coming into the country
Thanks Ray!!! McMahon's proto looks juvenile now compared to the new Mi2
#4870
Warpspeed Mission
Does anyone out there use the warpspeed chassis instead of the kit chassise? If so how does the car handling differ? Is it worth having?
#4871
Re: Warpspeed Mission
I have the chassis and it works excellent fast response
he had moved the batteries forward and at an angle
microtech racing located here in the uk has them in stock
#4872
I have the warpspeed chassis.. not really sure how it handles differently then the stock plate, I just know its more balanced.
#4873
Car looks great, and cheaper than I thought!
Are the Mi2 body posts in the same postition? Can I keep running my old Mission bodies?
#4875
BOS, I need to check on that myself, so i'll let you know if i find out for sure, however I am fairly sure that the front is the same, but the rear is moved back a little - about 4mm i believe. That said when i ran the proto car i used my own mission shells.
