Schumacher Corner
#4681
Hey Fred.....Thats AWESOME Great job to both of you
racerman...Check with Fred and Latif on their setup from this weekend and shoot me an e-mail and I will send you a setup that I run....Foam or Rubber tires? [email protected]
#4682
Front and Rear belts for Mission
Hi,
Need some help from the experts.
Like to find out whether Xray front and rear belts can fit the mission?
I read in the earlier threads that some guys use the Xray rear belt for their missions. Then what abt the front belt? Can Xray do or maybe from other manufacturers, eg Tamiya, Yokomo..?
Thks in advance!
Thks in advance!
#4683
Originally posted by racerman
hmm, anybody have a good set-up for stock racing on high bite tracks for the mission?
As far as the belt's I run a gray shumacher in the front and a standard schumacher soaked in wd40 in the rear. Some people have been using the X-Ray rear belt, but as far as I know the front wont fit.
P.S. Thanks Paul!!!
#4684
Looking for Axis 2 w/parts
Hi Guys... I'm jumping back into TC's...
I sold off everything I had about a year and a half ago, and now deeply regret it (DOH!!)
I got very accustomed to and really enjoyed my Axis2...
Anyone out here have one with piles of parts??
It seems when I wasn't looking to buy one, I'd see several that were all hopped up and had tons of spare parts...
I am also interested in trying the Mission... Anyone have anything, drop me a line, or PM me here.
Thanks!!
Ron
[email protected]
Thanks!!
Ron
[email protected]
#4685
Sent you a pm Ron
#4686
BELT SKIPPING
After racing my mission for 2 months the (gray) front belt has begun to skip. Is it time to replace it or can i just tighten the tensioner?
#4687
I don't know but.........
my car violently hops/jerks when I first get on power...is this the belt skipping??? I can't really hear anything (such as a clicking)and my belt is kinda worn but I have seen worse??? how tight can I adjust the belt b4 it is too tight??? I s there a rule to go by when tightening the tensioner??
#4688
The belt skipping wouldn't affect the cars manner on the track other than less acceleration. If your car is hopping/jerking than there is a much greater problem
#4689
well??????????...........
I still have the notches in my outdrives ( the blades that get notches in them from your cvds) (I am sorry but I call them this cause that is what I called them and somebody said I was wrong) but other than that that is the only thng i can see visable....it only happens when my car is at a stand still...all other times it seems to be fine and it rolls nicely and my diffs sound allright...it just started doing it not long ago so I don't really have a clue as to what could have made it start??
#4690
racerb....I have not seen that before, so I would have to inspect your car in person for a solution. From the description, I would suggest new outdrives and blades. Its important to check & maintain the blades as needed because any damage to the blade will carry over to the outdrive.
#4691
i can recomend 2 things
1st ,with the pinion off put a mark on the long belt with a marker and then slowly turn the spur untill the mark has returned and listen closely. If it is running free with no disernable noises you have elimanated the drive train as the problem.2nd ,Take off your pinion and put in a charged pack turn the car on then punch it! is the motor reving freely.You have to have your radio on too!!! Now you know if its your electrics or not. Whats the condition of your motor?
#4692
Maybe one of your cvds is bent and when you turn it casues chatter making it feel like its hoping or makeing a noise??
#4693
well the only time the car gets upset is
when I am at a complete stand still....it does not do anything when racing it around the track...actually it is the fastest best handling car i have had the pleasure to own.....my biggest guess is that it is the notched blades....I have not gone to the hobby store yet but i realize that this might be the solution to all my probs....my motor is in excellant condition...it is freashly cut and brushes are all good as well.....I have tried a different motor as well
#4694
Post some pics if you can, I have never seen something like this before?
#4695
time to rebuild
Go through the whole car check for slop in ALL joints and pins and shafts ypur problem should be in there some were,then let us know!
