Old 08-20-2003, 08:35 PM   #4561
racerb's Avatar
Default hey Paul it Blain from Kamloops
I used this at our last race and found it was an awesome starting point and I just fine tuned from there
Hey guys....Just wanted to post our latest setup for hot weather racing (track temps 130-150) with CS 27GLR's:
Front
tower/2
bulkhead/lower hole/spaced bulkhead up 1mm
arm hole/1/arm in stock position
hub/inline
steering/2
arm sweep/2
piston/#3 vari
oil/40wt
spring/blue schuy
droop/2mm
swaybar/stock spaced 1mm
castor/middle
camber/neg 1
toe/ neg .5 out
ride height/4.5mm
tire/Take-off cs27glr
spool
Rear
tower/2
bulkhead/lower hole/bulkhead spaced up 1mm
arm hole/1
hub/inline
piston/#3 vari
oil/50wt
spring/red
droop/3mm
swaybar/stock
in-board toe/0
toe-in/2deg
anti-squat/1mm
rear arm/middle
camber/neg 1
ride height/5mm
body/protoform stratus 2.0
Car is very good, lots of steering....Tires can over-heat if over driven.
racerb is offline   Reply With Quote
Old 08-21-2003, 07:21 AM   #4562
New car pics look good...cant wait to see one in person. PW...Is there a waiting list forming?? I'd like to be on it if there is...
One question...that A-arm looks pretty fragile...reminiscent of the Yok arms a few years ago that would break if you got close to a wall...I'm sure testing will tell, but let's not forget the lessons of the past...
Cheers...Mark
markg is offline   Reply With Quote
Old 08-21-2003, 07:21 PM   #4563
rayhuang's Avatar
Paul.
Thanks for hooking me up with Michael of Mad Rip batteries.
Ray
Old 08-22-2003, 01:56 PM   #4564
rcshark's Avatar
Send a message via Yahoo to rcshark
if the chassis is rubing the ground on asphalt what would the first thing to change if im in the lead oil or springs?
rcshark is offline   Reply With Quote
Old 08-22-2003, 03:26 PM   #4565
If your chassis scrapes on the track, and there's no one around to hear it, does it make any sound?
Jay Dub is offline   Reply With Quote
Old 08-23-2003, 06:05 AM   #4566
rcshark's Avatar
lol i cant here it but the marks are on it and i thank if i make it little stiff that i might loose my tracktion but im going to change my oil from 30 wt. to 90 wt. and put one step up on the springs!
Old 08-23-2003, 11:03 AM   #4567
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
rcshark, don't you think 30 wt to 90 wt is a bit of a drastic change??? Maybe try 40 or 50 first man.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-23-2003, 02:27 PM   #4568
SHARK- I'm not trying to be funny here, but how much time do you spend on top of the berms/bourds at your local track? They can cause scrapes as well.
Old 08-24-2003, 09:43 AM   #4569
rcshark's Avatar
i tightened up my car alittle last night just but the shocks inboard like on the #4 setting all the way around it helped alot i ran one heat race tQ then won the a-main. fasted lap was 12.9 with the slowest lap 16.2 with a hack realy concestent track.
i have raced onroad on for the past few month but have goten over 6 national top 10 spots in the off road tuck class.
Old 08-25-2003, 10:54 AM   #4570
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
From what I am hearing testing on the new sedan is going A+ great! Can't wait, this car is going to be the best kit that Schumacher has ever produced. They are trying not to overlook anything. Please feel free to tell me or any other Schumacher ofiliated(spelling lol) driver any questions.
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 08-25-2003, 12:41 PM   #4571
rcdougie's Avatar
Definatley would like to see threaded shock bodies included in the kit. Its tough to spend $250+ on a kit and then have to spend another $40-50 on shock bodies. Especially when most of the other top tourers come with them. Also would like to see non posi screws, maybe some hex head screws would be nice. I am really excited about the new car and have heard a lot of good things during its testing so I cant wait to pick one up!
rcdougie is offline   Reply With Quote
Old 08-25-2003, 02:40 PM   #4572
PW
PW's Avatar
Send a message via AIM to PW
Threaded shocks will make their way into the new kit
Torx screws will also be included in the kit...A little secret about torx screws, 2mm hex wrench fit right in...hehehe
PW is offline   Reply With Quote
Old 08-26-2003, 05:30 AM   #4573
Send a message via ICQ to JesseT
Please please please include some proper sway-bars in the kit, or at least mounting points for ones.
JesseT is offline   Reply With Quote
Old 08-26-2003, 11:18 AM   #4574
Cole Trickle's Avatar
This new car definately sounds interesting. I believe a lot of parts like one way diff etc. from the Mission will fit?
Yep, sway bars got my vote too.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-26-2003, 12:31 PM   #4575
PW
PW's Avatar
Swaybars will have new mounting and the arms have a molded pivot-ball in them for the ball-cup
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
