Old 08-14-2003, 12:42 PM   #4546
Trader Rating: 240 (99%+)
Talking
I agree need plyers some times. My fingers HURT!!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 08-14-2003, 01:12 PM   #4547
rcshark's Avatar
Send a message via Yahoo to rcshark
i have broke the studs nut the cup was still there!!!!
rcshark is offline   Reply With Quote
Old 08-14-2003, 06:49 PM   #4548
PW
PW's Avatar
Send a message via AIM to PW
All this about some ball-cups....LOL
PW is offline   Reply With Quote
Old 08-15-2003, 04:03 PM   #4549
rcshark's Avatar
PW your funny!!!! roflmao next subject Please
its the Mission syndrome!
Old 08-16-2003, 01:52 AM   #4550
Hi guys,
Im new to this site and reading through it all you talk about some great stuff to know about the Mission.
As your on the subject of ball cups, I have heard that some people cut these down by 2mm or so to get a lower ride height. This is my case i run the roll center mod with Fusion bulkheads and the alloy hub carriers with low pin at front and high pin on rear. but I can not get the ride height less than 8mm front and 8.5mm rear.
Is cutting the ball cups down the right way about this or am I doing something wrong, Im also running a shock length of 65mm?
adyb is offline   Reply With Quote
Old 08-18-2003, 02:16 AM   #4551
Send a message via ICQ to JesseT
Obviously you don't share my point of view. I've never had a problem with the cups popping off, but my point was about hte slack. The actual cup is way too big for the ball. When using the Schuie cups, there is just so much play in every corner of the car, even when new! When they used to be black in color they were a better fit. The best Schuie cup up to date have been the old "rose-joints". No need to argue me on this one, I respect your opinions. This is just mine, and I was surprised that you think differently.
BR/ JesseT
JesseT is offline   Reply With Quote
Old 08-18-2003, 08:27 AM   #4552
Send a message via ICQ to MattW
Jesse, I can see where you are coming from actually. If you want no play at all then you want the TiR ball studs as they are a little bigger.
MattW is offline   Reply With Quote
Old 08-18-2003, 09:02 AM   #4553
Sure you can, it says it right under my name there on the left.
Bad joke. Anyhow, I recall you have mentioned this about the TIR studs earlier.
Old 08-18-2003, 04:04 PM   #4554
rcshark's Avatar
I thank I like my care cause of this board message systems and the guys that are on here. how you can talk and work things out realy shows the sport of things and the kind of people that drives the finest and up to date car in the world.
it just my thoughts?
Old 08-19-2003, 06:18 PM   #4555
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
All I have to say is that I was TOTALLY STOKED when I received word that schumacher was developing a new touring! I cant wait to get my hands on one! I honestly havent been this exited about running a new car in a long time!!!
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 08-20-2003, 12:12 AM   #4556
Does anyone know if the new car is a totally new design or if there will be a conversion kit available for the current Mission owners?
Cheers,
Yorkie
Yorkie is offline   Reply With Quote
Old 08-20-2003, 12:19 AM   #4557
Default Schumacher
Schumacher prototype
We promised more infos of the new Schumacher prototype. So here we go:
Schumacher has changed the suspension geometry drastically. The prototype car has standard-type suspension arms with c-hubs in front. Another interesting feature is the sligthly changed transmission. The long belt which connects the front and rear differential has changed the position with the small belt so that it is near the spur gear. The great advantage of this belt setup is that you can put the battery more to the center of the chassis. Right now the team drivers have the possibility to change the position of the battery pack to test different weight distribution. The form of the main chassis plate is a little bit different as well.
The new car will be available in late Octobre/early November 2003!
Gezuz is offline   Reply With Quote
Old 08-20-2003, 06:36 AM   #4558
PW
PW's Avatar
Hey Yorkie....No conversion will be available, there are to many things that have changed from the Mission to the new car. There will be a few items that will carry over, but not enough to convert.
adyb....Not sure unless I duplicated your setup, but cutting the ball-cups 2mm should take care of the problem.
Old 08-20-2003, 07:37 PM   #4559
RBLove's Avatar
Trader Rating: 72 (100%+)
New car looks really good PW. Can't wait to see it.
Rob Love (Ohio)
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 08-20-2003, 08:16 PM   #4560
Hey Guys
I'm busting out onto the race scene after a long absence. Would anyone have a pavement setup for the mission that I could use for a starting point. I havent even ran this car yet.
Thank you in advance for any help.
PS the new car looks good, can't wait for more pics to see the suspension a little better.
Cheers
Paul
PaulP is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
