Old 07-14-2003, 11:22 AM   #4411
Paul is there C hubs for the misison now? I was rading in a magazine that shui had been using c hubs instaed of there normal system? Thanks
teamAE is offline   Reply With Quote
Old 07-14-2003, 02:27 PM   #4412
Send a message via ICQ to MattW
xcell, i know someone who used a 3mm one yesterday, and killed it in a few runs - not sure precisely how many, but single figures i think.
MattW is offline   Reply With Quote
Old 07-14-2003, 05:54 PM   #4413
PW
PW's Avatar
Send a message via AIM to PW
xcell...I heard the same as Matt, but worse. One of our team guys tried one and it skipped brand new with a mod motor. I would stick with the stock belt or the std xray belt.
teamAE....Nothing new for the Mission right now, but we have plenty of new things on the drawing board. Schumacher has to finish up our newest project first http://www.racing-cars.com/menace.asp
PW is offline   Reply With Quote
Old 07-14-2003, 08:02 PM   #4414
hey guys i was wondering what size i should set my shocks at?
jiggamacdaddy is offline   Reply With Quote
Old 07-14-2003, 10:21 PM   #4415
King-G's Avatar
Send a message via ICQ to King-G
most guys are running their shocks between 65 - 67 mm for standard shock positions.
Too long and they can cause the piston to hit the top of the body under full compression, too short and they can limit droop and ride height.
King-G is offline   Reply With Quote
Old 07-15-2003, 09:11 AM   #4416
king-g thanks also does anyone know if i can order a complete screw set from schumacher for the mission? and what is the part number for the front rw diff gear?
Old 07-15-2003, 02:42 PM   #4417
Thanks for the info on the belts guys.
XCELL is offline   Reply With Quote
Old 07-16-2003, 06:40 AM   #4418
PW
PW's Avatar
jiggamacdaddy....We no longer have a steel screw kit for the Mission, but we now have a Titanium screw kit.
RW1002 is the part number for the front pulley.
Old 07-16-2003, 09:37 AM   #4419
I just installed the rw pullys...WOW its the freest belt car I have seen yet. Just putting the pullys on made all the diffrence in the world. Anything else I could do to make is smother, maybe the xray belt in the rear?
Old 07-16-2003, 01:09 PM   #4420
Trader Rating: 238 (99%+)
Default Bearings
On the subjuct of bearings. I use Blue Seal bearings. They are very free and inexpencive, Front gray belt barely any tention and standard rear belt soaked in wd-40, rw pulleys front and rear. my car is freeer than a tc3 with ceramics!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 07-16-2003, 05:48 PM   #4421
Racer X's Avatar
AE: Did you strip the gease out of the bearings when you built the car? If not, take the bearings and soak them overnight in brake cleaner or motor spray to remove the grease the bearings come packed in. After letting the bearings dry, lightly lube them with a good bearing or teflon oil and reassemble the car. Hope that holps...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 07-16-2003, 06:44 PM   #4422
Has anyone installed a fan on thier car? and did you notice differance in motor temp after running?
Old 07-16-2003, 07:05 PM   #4423
Thanks RacerX I did the usuall stuff already, bearing wise,a dn just need to go try it out at the track. Still having rpoblems with finding the right rgearing I am geared at 89/23 for a monster which is 6.9 with other cars I was in the 7.2 7.3's but never down to 6.9 maybe 6.8?????
Old 07-16-2003, 08:30 PM   #4424
does anyone know what the turn around time is if i order parts off the schumacher website?
Old 07-16-2003, 08:53 PM   #4425
rcdougie's Avatar
I live in florida so its normally a 2 day deal. And seeing that you are in Atlanta, it shouldnt be much different. They are usually pretty good about shipping.
rcdougie is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
