Old 07-03-2003, 04:34 PM   #4381
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
looks good
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 07-03-2003, 04:35 PM   #4382
looks good
Old 07-05-2003, 10:36 AM   #4383
Trader Rating: 74 (100%+)
Default Whats Changed??
By the looks of the warpspeed chassis not much has changed. It looks like the chassis is designed after the kit chassis but has a adjustable servo mt, and motor mount. Possibly thickness? Someone please clarify? Thanks.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 07-06-2003, 05:30 PM   #4384
Hey guy's, gotta brag on my 10 year old son a little bit! He won the spec touring class A-main at the N.C. State Championship race on Saturday. He did so against a field of shaft car's, not bad considering this class has to run the Trinity 1600 spec batteries and the street spec motor's. So handling and smooth driving are a must as this is a lower cost class that a few veteran's run in!
He was running the latest set-up that Paul posted on here except with a front diff. Track temp was about 140 midday, so we ran the cs-32's, then ran the 27's as the main was at sundown.
Also good to meet you at the Nat's Paul. Your'e car looked pretty good in the main last Sunday. Do you guy's stock any of the lightweight driveshaft's such as al. or ti. Let me know if you do so I can order some.
Bye for now.....Hank and Joseph
HENRYJ is offline   Reply With Quote
Old 07-06-2003, 07:56 PM   #4385
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
HenryJ- Schumacher USA does stock Ti axles. Congratulations on your son's win. That's quite an accomplishment for a 10 year old!!!
Raul- this is a quote from Vic (aka Mr. Warpspeed) "The new changes are the batteries are moved 5.6mm forward, and 3 deg of an angle towards the front. As you can see it is an equal chassis. It will be available in 2mm and 2.5mm, with solid plate only. You still have the servo that can be moved in or out, or facing forward. I kept the chassis as narrow as possible. On the tweak station the car balances perfectly."
Again, I'll be curious to see if the chassis is actually an improvement over the stock chassis. I believe the balance might be better than stock, and the 2.5mm chassis coupled with the solid upper deck may be an improvement on carpet. We'll have to see.
BigDogRacing is offline   Reply With Quote
Old 07-09-2003, 10:05 AM   #4386
Does any know a good place to start gearing a monster?
teamAE is offline   Reply With Quote
Old 07-09-2003, 10:28 AM   #4387
Default gearing
I used a 95t spur, with a 26t pinion, 20t layshaft. 58mm tires, just about every track I ran it on. Hope this helps.
Old 07-09-2003, 12:31 PM   #4388
Smile
I run a 92/23with 20t pulley.
XCELL is offline   Reply With Quote
Old 07-09-2003, 03:10 PM   #4389
Thanks I will give it a try.
Old 07-09-2003, 04:29 PM   #4390
King-G's Avatar
Send a message via ICQ to King-G
where are you guys running your personal Transponders?..as they are advised not to be mounted over Carbon..
i was thinking ontop of the servo would be best, as there is the cutout underneath the servo..anyone had any probs running theirs?...
King-G is offline   Reply With Quote
Old 07-09-2003, 04:57 PM   #4391
I run mine on top of the servo with no problems what so ever.
Old 07-09-2003, 06:17 PM   #4392
Mopar's Avatar
I cut a recess in the top of the foam bumper, that way you use no screws or tape. And it's fully protected.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 07-09-2003, 07:48 PM   #4393
Racer X's Avatar
I servo tape mine to the top front bumper brace. Something about having the transponder cross the line as soon as possible makes me more...comfortable.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 07-09-2003, 10:04 PM   #4394
ottoman's Avatar
I just stick it to the top deck... never had a problem
ottoman is offline   Reply With Quote
Old 07-10-2003, 01:51 AM   #4395
BagofSkill's Avatar
Can people please add where thier transponder loop is, and I don't mean "at the start/finish line", I mean in a bridge over the track, or imbedded in the track, and if this makes a difference.
In my 1:1 scale experience, the signal from a transponder can pass through composites or plastic (obviously including Carbon, even with an aluminium honeycombe), but not through ferrous metals. We also use personal trannys by AMB, although, they are a bit bigger!
BagofSkill is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
