Old 06-09-2003, 07:20 PM   #4336
RBLove's Avatar
Trader Rating: 71 (100%+)
Talking
PW,
Glad to hear McMoney is still there...... Good luck to you guys at the Nats.... Get those cars dialed and keep those shaft cars out of the mix
Take care!
RBLove is offline   Reply With Quote
Old 06-10-2003, 05:02 AM   #4337
adrian's Avatar
hey all, p.w i was just wondering how you set your spool, im doing mine right now. Ive been told to take all the balls out and replace the hrust balls with another spacer the same size, is it supposed to have NO slip whatso ever?
thanks for your help.
adrian is offline   Reply With Quote
Old 06-10-2003, 06:07 AM   #4338
tonyp126's Avatar
Send a message via AIM to tonyp126 Send a message via Yahoo to tonyp126
PW,
What does spacing the bulkheads up 1 mm do to the handling of the car? Thanks.
TP
tonyp126 is offline   Reply With Quote
Old 06-10-2003, 07:59 AM   #4339
PW
PW's Avatar
Send a message via AIM to PW
Adrian...We are doing it a little differently now. All we do is superglue the std diff rings to a schumacher header card, then trim the excess away and remove the "diff" balls and reassemble with the header card facing the diff gear. Tighten the diff screw snug and the tighten the set screw stop very tight.
Tony...Spacing the bulkheads up will free up the car slightly in the corners. Please remember to adjust your shocks accordingly i.e. 1mm higher/shocks 1mm longer.....This adjustment is done when the car seems to have to much side-bite.
Thanks Rob!!!
PW is offline   Reply With Quote
Old 06-12-2003, 10:38 AM   #4340
racerb's Avatar
hey guys....this may or may not apply but....
I was wondering what is the measurement of the shocks on a mission??I just got rid of my axis2 and I know that when i set the measurment right it made a world of difference....I am looking at using the most recent setup that has been posted as my track gets quite warm...so i just want to make sure the shocks are the right size as well
racerb is offline   Reply With Quote
Old 06-12-2003, 02:12 PM   #4341
Racer X's Avatar
The most important thing is that they all be set the same. Currently, I believe that I'm running 56mm top to bottom. Most people run anywhere between 54-57mms. Hope that helps...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 06-12-2003, 03:00 PM   #4342
Ian S's Avatar
Racer X - where is that measured from? I measure mine fully extended and usually get them to 65-66mm.
Ian S is offline   Reply With Quote
Old 06-12-2003, 03:30 PM   #4343
racerb's Avatar
Cool when I did my Axis2 shocks I had 66mm
so I was just wondering if there was any difference
Old 06-12-2003, 07:28 PM   #4344
PW
PW's Avatar
Hey RacerX....I think you took to long of a break...LOL
racerb....Yes, they should be between 64mm to 66mm depending on the type of tires your using.
Old 06-12-2003, 07:38 PM   #4345
racerb's Avatar
Default oh that is a good question
I will be running on aspalt using rubber tires....I have quite a few used but good condition CS27's and some 22's and even some 32's....any hints???
Old 06-13-2003, 01:17 AM   #4346
adrian's Avatar
I measure my shocks at about 66mm (with calipers, get them all EXACT)
Hey racer B, all of your tires are great, run 22`s in teh cooler weather, 27`s in mid weather... (25 deg c) and your 32`s in hoter weather, i feel that the best thing you can do for your tires is put wd40 or Rp7 ( i think rp7 is better) on them, and wipe it off VERY well with a rag. Pop tire warmers on 5 min before you go out to have your run, this gets them nice and sticky, and not to hot. I wouldnt do this for take off 22`s unless its crazy cold! there great as they are. hope this helps
Old 06-14-2003, 12:29 PM   #4347
Racer X's Avatar
Huh? Wha...so my shocks are too short?
Too much of a break is right...
Schumacher Mi6
Integy
Old 06-14-2003, 05:33 PM   #4348
adrian's Avatar
yeah i think yours are a bit... try 65-66mm, thats what they use in the manual and all the team shumacher drivers do here.
Just make sure there even or your car will tweak
Old 06-17-2003, 11:19 AM   #4349
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
PW, thanks for the tip on spacing the motor out on the Warpspeed chassis, saved my weekend.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-17-2003, 02:33 PM   #4350
rcdougie's Avatar
Spooky, You sure did have your Mission hooked up at the Florida state race this past weekend.
rcdougie is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
