Old 06-04-2003, 06:19 PM   #4321
See
Trader Rating: 49 (100%+)
Hey RacerX how come you didnt run the speedworld cup?
See is offline   Reply With Quote
Old 06-04-2003, 10:49 PM   #4322
RBLove's Avatar
Trader Rating: 72 (100%+)
PW,
Is McMahon still running for Schuie? Noticed his name was not mentioned or seen at the Reedy Race.... Hope he's still with you. Good guy!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-05-2003, 06:56 AM   #4323
PW
PW's Avatar
Send a message via AIM to PW
Hey Rob....Yeah, McMahon is still with Schumacher He has been pretty busy with school recently and he had some things going on during the Reedy Race. He will be at the Nats in 2 weeks and then carpet season will be right around the corner
PW is offline   Reply With Quote
Old 06-05-2003, 07:46 AM   #4324
Racer X's Avatar
See: After attending the Reedy Race for a week, teh SW Cup race would have resulted in a divorce for sure (and she has already said that the only thing that she will ask for is my R/C stuff). I really wanted to go, but the timing was just wrong this year.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 06-05-2003, 04:38 PM   #4325
King-G's Avatar
Send a message via ICQ to King-G
lol..Im with ya on that one X.....they are demanding beasts.
King-G is offline   Reply With Quote
Old 06-06-2003, 11:57 PM   #4326
beasts.
Jay Dub is offline   Reply With Quote
Old 06-07-2003, 03:20 PM   #4327
See
RacerX I feel ya on that one.Thats the reason I sold the motorcycles. The things we do for women.
Old 06-08-2003, 03:34 PM   #4328
PW
PW's Avatar
Hey guys....Just wanted to post our latest setup for hot weather racing (track temps 130-150) with CS 27GLR's:
Front
tower/2
bulkhead/lower hole/spaced bulkhead up 1mm
arm hole/1/arm in stock position
hub/inline
steering/2
arm sweep/2
piston/#3 vari
oil/40wt
spring/blue schuy
droop/2mm
swaybar/stock spaced 1mm
castor/middle
camber/neg 1
toe/ neg .5 out
ride height/4.5mm
tire/Take-off cs27glr
spool
Rear
tower/2
bulkhead/lower hole/bulkhead spaced up 1mm
arm hole/1
hub/inline
piston/#3 vari
oil/50wt
spring/red
droop/3mm
swaybar/stock
in-board toe/0
toe-in/2deg
anti-squat/1mm
rear arm/middle
camber/neg 1
ride height/5mm
body/protoform stratus 2.0
Car is very good, lots of steering....Tires can over-heat if over driven.
Old 06-08-2003, 04:11 PM   #4329
rcshark's Avatar
Send a message via Yahoo to rcshark
go up on motor and over drive its just tires!!!
rcshark is offline   Reply With Quote
Old 06-08-2003, 04:14 PM   #4330
Trader Rating: 240 (99%+)
Paul, Sway bar spaced 1mm? Where? and How? Have a pic?
Also hows the swaybars for the Fusion comming? any kit yet? If not Do you have a pic of the front and rear?
Fred
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 06-08-2003, 06:57 PM   #4331
PW
PW's Avatar
Fred....I have a 1mm shim between the teardrop shaped swaybar mount and the arm (moving out on the bar softens the bar).
Nothing more on the R12 swaybars, but recently most of the guys at the local level are not running a front bar....No pics, but I will work on that.
Old 06-09-2003, 12:49 PM   #4332
Thanks Paul you the man.
P.S. Do you have andrews setup from the reedy race?
Fred
Old 06-09-2003, 02:07 PM   #4333
PW
PW's Avatar
The setup I just posted is the same as Andrew's except he drilled a middle hole for the steering block.
Old 06-09-2003, 02:11 PM   #4334
You mean a middle hole in the block for the upper arm?
Old 06-09-2003, 05:41 PM   #4335
PW
PW's Avatar
Fred...No, a hole for the steering. The steering turnbuckle is moved forward to a new middle hole.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
