Old 05-07-2003, 06:25 PM   #4246
TWiZTiD's Avatar
not super lose but not tight about 8 mm movement up and down
TWiZTiD is offline   Reply With Quote
Old 05-07-2003, 06:53 PM   #4247
fireblade's Avatar
Send a message via AIM to fireblade
It seems with spools that would work. I should make them run more evenly also, so one end dont turn more than the other.
Everybody thats goin to the Reedy that I have talked to that is running Schumacher is going to run the spool, since you cant run the oneways Try asking Dominic on that one also and see what he thinks about it. It makes sense with me because their is not forgiving diff action. But try it and see what goes.
fireblade is offline   Reply With Quote
Old 05-07-2003, 07:19 PM   #4248
King-G's Avatar
Send a message via ICQ to King-G
X....I recently played with a spool for the day, and would definately recommend running a longer ackerman link to reduce the amount of ackerman....this will also give you more turning angle for the outer wheel in the corner, as the inner lock is determined by the bump stop on the steering hub....by running less ackerman you get more lock on the outer wheel.
However, having said that, less ackerman makes the car less aggressive initially, and this is one area you suffer when running a spool, initial turn in tends to be understeer.
Give it a try, other things i did to really improve the car with the spool was to add around a mm of extra droop to what i would normally run with the oneway setup, and go in one hole on the front tower, as well as going slightly softer in oil to help with that initial response.
Good luck with it
Twizted, you shouldnt be breaking belts in stock....3 belts in one night is rediculous...what track was this at?...you may have picked up some debris, which is lodged in the pully, this will cut the belt...check both pulleys for any small rocks or glass.
RC shark...Associated silver which is what i currently have on the car is the same rate as schumacher blue (15 lbs)...howver the associated spring is more linear, as the schumacher springs seem quite progressive in rate, therefore start their compression quite soft, and apon full compression are considerably firmer...
the schumacher springs feel really calm on the track...whilst I feel the associated springs are more lively, as their rate is linear...also, the other reason for me running them is their rate changes between springs is only 2.5 lbs,,,alowwing much finer tuning.
King-G is offline   Reply With Quote
Old 05-08-2003, 12:48 AM   #4249
Racer X- I have gotten in a new shipment of wheel bearings in time for the Reedy. I should have an extra set or three. Let me know if you are interested.- Jeff
Jay Dub is offline   Reply With Quote
Old 05-08-2003, 03:53 AM   #4250
TWiZTiD's Avatar
King gav I was at borina nothing in the pullies I cant work out why my just a some bad luck it was a bad night 4 me did only 7 mins of driving for the hole night
Old 05-08-2003, 07:32 AM   #4251
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I did something with my Mission last night, that should not have done, but wanted to tell you guys as a testament to the cars durabiity.
Our local carpet track is co-located with a indoor skate park. After the park shut down I walked over to the Half pipe... said humm. that would be kinda fun... back and forth... So I went at it with my practice car... that car was whipping back and forth up the 10ft sides of the half pipe. not much traction in there on the masonite.. so it was sliding all over.... The car caught traction and shot up and out of the pipe.... over the catch fence and 15-18 ft down to the concrete. , only problem was a battery bar broke... thats it.... The car is soooo tough.
Next time bringing my Stadium Truck
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-08-2003, 09:31 AM   #4252
Send a message via ICQ to MattW
Gav, It's a little softer than i would normally run, but then my car is normally stiffer than most peoples!
Racer x, I hadn't thought about that, but yes it does seem to make sense. We have been running a spool at a few tracks recently but hadn't made any alterations to ackerman, but i might think about trying that this weekend. I generally run a long ish centre link.
MattW is offline   Reply With Quote
Old 05-09-2003, 08:36 AM   #4253
b_budianto's Avatar
Hi everyone, i got question about schumacher shocks:
- How often do we need to refill the oil on them ? Mine cannot
rebound after about one race meeting. Is it normal ? or i need
to rebuilt them ?
- How to do the bleeding proces on them ?
- When fill the oil .. does it need to fully rebound or just partially ?
b_budianto is offline   Reply With Quote
Old 05-09-2003, 05:55 PM   #4254
Trader Rating: 237 (99%+)
Hey guys. Haveing trouble with my misson. Dives the nose in the corners and over roatates the rear end. I am running big dogs asphalt setup. Pretty sure its not the springs or shocks. Could it be roll center? If so which one do I change upper or lower?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 05-09-2003, 06:31 PM   #4255
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Not sure if its the roll center, but I'd suggest taking rear droop out of the car if it's diving that hard.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-09-2003, 07:43 PM   #4256
done that too, just makes the car rotate more
Old 05-09-2003, 07:49 PM   #4257
adrian's Avatar
b_budianto Hi everyone, i got question about schumacher shocks
Hey
your shocks are fine, it happens to me and everyone else i know.
If anything its a good thing ... as long as there all even its all good.
rc-old man.. i had this happen to me as well... the problem was fixed when i used 2 front droop and 3 rear.
adrian is offline   Reply With Quote
Old 05-09-2003, 08:05 PM   #4258
Less rear droop made it rotate more?? It should allow the rear-end to travel upward less in deceleration which will eliminate your diving problem. Are you sure you took droop out (i.e. droop screws screwed in more [clockwise]) not put more in? I'm just asking objective questions to maybe help you figure out your problem...not trying to treat you like a know-nothing because i'm sure that you know a good amount.
USVTA Member #211
Old 05-09-2003, 08:23 PM   #4259
Axiom- yes, if you start with too little droop and you take more away then it will adversly effect the handling and actually intensify the problem.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-09-2003, 08:26 PM   #4260
Well yes that's true, but from his post it sounded like he had too much in the first place...
USVTA Member #211
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
