Old 04-18-2003, 03:49 PM   #4186
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Originally posted by PW
Actually guys, the Schumacher springs are slightly more progressive than say AE or Xray. We seem to like the Schumacher springs outdoors and the others for indoors.
I bet they're perfect for the heavier Fusion R12 nitro car!!
Quick note to all- I ran outside on asphalt at our club race last weekend, and there were 3 Missions (2 were mine). One of mine and the other one were running the basic asphalt setup I posted last fall. Find the setups here with the exception of red springs in the rear and less droop front and rear. I'll make the chenges to the setup sheet ASAP. I tried changing a few things, but I couldn't find anything better on our meduim bite track.
BigDogRacing is offline   Reply With Quote
Old 04-18-2003, 05:04 PM   #4187
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hey guys check out this car that some French guys are playing with.....its part Schumacher..........
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 04-18-2003, 05:04 PM   #4188
Kevin K's Avatar
here are some more pic's........
Old 04-18-2003, 05:05 PM   #4189
Kevin K's Avatar
some more.......
Old 04-18-2003, 05:05 PM   #4190
Kevin K's Avatar
still more....
Old 04-18-2003, 05:06 PM   #4191
Kevin K's Avatar
yep another one.......
Old 04-18-2003, 06:12 PM   #4192
hey paul, 100 to go to hit 100,000
Mr Warpspeed is offline   Reply With Quote
Old 04-18-2003, 07:08 PM   #4193
Default SETUP!!!!
Hi i need to know what a very good setup would be for outdoor raicng its a very tight track without any straits !!! i am running brushless system so i will need like a mod motor setup!!!-please help need before tommrow's races!-gg and also it's a schumacher mission!!!
1FaStClubRaCeR is offline   Reply With Quote
Old 04-18-2003, 07:11 PM   #4194
send some pics of your schumacher missions to me and some good setups! thanks-gg
Old 04-19-2003, 08:35 AM   #4195
1FastClub- if you had looked up 7 posts you would have seen a link to a setup page with some really good setups for different surfaces.
There is a reason for having forums where you leave all of the posts on them... so people can read back and find the information they need. If you don't find what you need after reading a bit, then you post your question.
Good luck at your race tomorrow.
Old 04-19-2003, 11:05 AM   #4196
I got custom chassis few weeks ago..It's 3mm thick with 2,5mm upper deck..Car is very stiff and way easier to tweak.Batteries are moved 11mm closer to center and layshaft+front one-way are turned around to get some room for batteries..I'll post some pics,if I have time..
Tuure is offline   Reply With Quote
Old 04-19-2003, 09:30 PM   #4197
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Quick question guys-On the Mission wet weather undertrays is the top supposed to go over the bottom or vice versa?
I guess top over bottom as then its easy to put the velcro together. Also does it have to be screwed down in any way?
Oasis2001 is offline   Reply With Quote
Old 04-20-2003, 08:49 AM   #4198
Racer X's Avatar
Oasis: My guess is top over the bottom, but here in the states, if there are any ugly clouds in the sky, we usually don't race, and NEVER when its raining (although I wouldn't mind trying it once). I don't think its even possible to get the wet undertrays in the U.S. Good luck with that one...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-20-2003, 10:43 AM   #4199
STLNLST's Avatar
Trader Rating: 19 (100%+)
Racer X- You had some ponies yesterday. It should be a fun stock class next weekend. It should also be weird for me running mod 12th scale for the first time. Can I call oneways???
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-20-2003, 12:36 PM   #4200
Ian S's Avatar
oasis - i screwed mine to the chassis using the 4 "lower diff mounts" (the little things the bearings sit on), doing this just stops it rattling around when you are racing.
Ian S is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
