Old 04-11-2003, 07:08 AM   #4156
Originally posted by rcdougie
Anybody know the part number for the "castor clips?"
U2251X Kwik Klip, 1/8" - 2 x 8 pcs
olev is offline   Reply With Quote
Old 04-11-2003, 07:17 PM   #4157
Racer X's Avatar
43 day to the Reedy Race...(hey it was better than just putting TTT)
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-11-2003, 08:41 PM   #4158
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
The ones from Xray work best. They have a tiny hole in them so you can use a pick to pull them out.
BigDogRacing is offline   Reply With Quote
Old 04-11-2003, 10:10 PM   #4159
fireblade's Avatar
Send a message via AIM to fireblade
Have a question for you guys. When I installed my RW pulleys. I noticed when I tightened down the bulkhead on the diff, the diff didnt freewheel like it was supposed to. I backed out the screws and it helped. Are the CNC alum. ones more precise and will let it be more smoother?
Garrett
fireblade is offline   Reply With Quote
Old 04-12-2003, 05:23 AM   #4160
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I have the alum. bulkheads and I just put the RW pullies on and when everything was tightened down it never tightened up any. I would think it is probably because of the plastic bulkheads. Make sure you have the bulkheads slid over the bearing right before you tighten everything down.
Old 04-12-2003, 07:17 AM   #4161
Trader Rating: 238 (99%+)
I see on most setups you guys are using AE springs. Why? The shumacher springs are a progressive spring correct? The AE springs are not. What is the handleing differences between both?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-12-2003, 10:34 AM   #4162
What are the RW pullies?
jackv202 is offline   Reply With Quote
Old 04-12-2003, 04:51 PM   #4163
Racer X's Avatar
Old Man: The AE springs come in 2.5 lb rates (10, 12.5, 15, 17.5, 20 etc) while the Schumacher springs are in 5 lb rates (10, 15, 20, etc). Some peolpe use them to get that 'just right' rate. The down side is that they are much shorter than the Schumacher springs so if you are running threaded bodies, you have to flip the colors and still may need to run a spacer (or you have to run lots of spacers if you don't have the threaded shocks). Hopefully, Schumacher will come out with some...
Jack: The RW pulleys are machined diff pulleys that make the drive train much smoother and effecient. They also make machined 1/2 width drive gears, too. Availible from Schumacher...
Schumacher Mi6
Integy
Old 04-12-2003, 06:49 PM   #4164
fireblade's Avatar
Racer X- I was worried when I installed my threaded bodies. But flipping the color did the trick. I figured I would need a spacer too, but to my suprise, I acutually had a lot more threads than I expected extra. The AE springs as racer x said, are a little more tunable than Schumacher springs. But both are good.
Old 04-12-2003, 08:48 PM   #4165
To be honest, I like the way the AE springs feel better then the Schuie springs. Unfortunately, I can't explain why it would feel better technically speaking...
Old 04-13-2003, 12:33 AM   #4166
fireblade's Avatar
Well, since you say that bigdog. My mission came with the tank, Schumacher yellow springs. My dad had to hold the shaft with pliers while I pulled up the spring retianer. The weird thing is, AE 40lb springs seem softer than Schumacher 40lb. I cant explain this either, must of been the spray paint schumacher uses on their springs making it stiffer lol
Old 04-14-2003, 02:34 AM   #4167
rcdougie's Avatar
Are the schumacher titanium screws that are optional hex head or use a philips screwdriver? Im looking to replace the screws with a hex head type not really being concered weather they are titanium or not. Thanks!
rcdougie is offline   Reply With Quote
Old 04-14-2003, 06:13 AM   #4168
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
They are Hex Doug
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-14-2003, 11:31 AM   #4169
rcdougie's Avatar
Thanks Tim. That is the only complaint about the mission is those darn "pozi" screws!
Old 04-14-2003, 01:17 PM   #4170
Default SCREW SIZES.
Can some one tell me the screw sizes needed and how many are there to fit the schumacher Axis 2?
Edward from Canada
RACER XXX is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
