Old 04-07-2003, 03:26 PM   #4141
Hey guy's, need a mission set-up for med. grip asphalt with CS-27 takeoff tire's, (track tire). Will run mod some, but mainly for stock. E-mail me at [email protected].
Thank's in advance, Hank
HENRYJ is offline   Reply With Quote
Old 04-08-2003, 04:12 PM   #4142
Hey guy's, Thank You for sending me some set-up's. Just starting out with two new mission's for my son and I, as well as being new to rubber tire's. This help is much appreciated, and I will update ya'll on our progress, Thank's again!
Hank and Joseph
Old 04-08-2003, 05:19 PM   #4143
Trader Rating: 244 (99%+)
Whats the current setup for rubbers cs27's on asphalt. Track is 160ft by 80ft. No one way. Thanks
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-08-2003, 10:38 PM   #4144
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Henry and Old Man, sorry I thought I posted this for you...
Setup sheets
BigDogRacing is offline   Reply With Quote
Old 04-09-2003, 03:59 AM   #4145
rcdougie's Avatar
Are the "old" mission diff able to be upgraded to the new "2003" diff, or do I have to buy the whole diff assembly? If so, what parts are needed? Thanks!
rcdougie is offline   Reply With Quote
Old 04-09-2003, 08:07 AM   #4146
Send a message via ICQ to MattW
Yes they can be upgraded. You need thrust race, outdrives, spring washers/spacer and centre bearings.
MattW is offline   Reply With Quote
Old 04-09-2003, 02:32 PM   #4147
PW
PW's Avatar
Send a message via AIM to PW
rcdougie....To rebuild diff part by part is $61.95 minus diff balls, rings and gear or you can get a assembled pro-diff (all carbide) for $49.99 complete. The part # for complete diff is U2451(front) and U2452(rear).
PW is offline   Reply With Quote
Old 04-09-2003, 02:52 PM   #4148
PW - does the roll center mod come with a front chassis brace?
DOTMAN is offline   Reply With Quote
Old 04-09-2003, 02:56 PM   #4149
PW, I did wonder about the costs as i was listing the bits needed!
Dotman, It doesn't really heed one as it spaces the origional moulded brace off the chassis.
Old 04-09-2003, 04:15 PM   #4150
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I'm installing my new RW pullies in my diffs. Do I still need to run those black covers that say left and right on the diff halves since the RW pullies come with those rings for the belts? The black diff covers still seem to fit but do I need to use them?
Old 04-09-2003, 07:56 PM   #4151
PW
PW's Avatar
dotman...Like MattW stated, you don't need one because the stock mount is still used.
wyd....The stock flanges are no longer needed with the RW pulleys. The RW flanges due have a radius edge and that edge should face in on the gear.
Old 04-09-2003, 08:01 PM   #4152
wyd
Tech Legend
wyd's Avatar
PW thanks. After putting them on I now know why everyone uses them.
Old 04-10-2003, 09:19 AM   #4153
wyd
Tech Legend
wyd's Avatar
Well I just finished cleaning out my bearings and putting my diffs in with the RW pullies. Damn it is the freest belt car I have ever had. It spins easier than my XXX-S did. I can't believe how much smoother is spins. The RW pullies are lighter too. Can't wait to try it out again this weekend. I bet it will make a huge differance.
Old 04-11-2003, 12:36 AM   #4154
adrian's Avatar
Yeah they sure do help, you wont beleave how fast it will accllerate now...
Has anyone ever had to replace the belt tentioner bearings? i had to... they just seeized..
Also do you think the alloy layshaft mounts are worth it?
i will get them for sure, just womdering.
Have any of you tried putting spacers between the bulk head amd the diff mounts? your thoughts?
Also is any one has any pics of there cars please post em ;-)
adrian is offline   Reply With Quote
Old 04-11-2003, 03:10 AM   #4155
rcdougie's Avatar
Anybody know the part number for the "castor clips?"
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
