Old 04-03-2003, 09:20 PM   #4126
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Mine had the brace in the kit. It went on the front great. Only problem was the steering arms rubbed on the o ring spacer and the o ring spacer was not big enough to remove all the slop from the front arms from moving back and fourth. I just used some small spacers and fixed the problem. Still a pretty nice setup.
Old 04-03-2003, 10:06 PM   #4127
fireblade's Avatar
Send a message via AIM to fireblade
Yeah. I would of liked to have that setup instead of measuring and cutting carbon fiber from my old chassis. You will feel a difference in the car, feels like you can push it harder in the corners
fireblade is offline   Reply With Quote
Old 04-03-2003, 11:09 PM   #4128
Default Schumacher mission not fast enough?
Hey guys,
I race at a small carpet indoor track, with about 2/3 straight and 1/3 corners. My Schumacher mission just can't keep up woith the other guys around the corners, because of it's loss of acceleration, and slips behind a bit on the straights too, can any of you tell me what pinion gear, spur or anything else to buy to make it faster and have more acceleration. Bear in mind i am running the 20t pulley, 86t spur gear, 25t pinion gear. Everything else is just standard.(p2k2 motor, only allowed 27turn stock)
Cheers
jackv202 is offline   Reply With Quote
Old 04-04-2003, 01:01 AM   #4129
try going to a larger spur gear
will give you moe punch and more top end
gdcopbadcop is offline   Reply With Quote
Old 04-04-2003, 04:21 PM   #4130
wyd
Tech Legend
wyd's Avatar
I would find out what the roll out is of the faster guys. Maybe your gearing is off some. Could be your setup on your car. your batteries. tire combination, or a number of other things. It is sometimes hard to pin point one thing. Start will running a rollout of what ever the faster guys run.
Old 04-05-2003, 05:46 PM   #4131
Racer X's Avatar
Inline turnbuckle solution:
No need to get longer turnbuckles. The solution is simple. Unscrew the turnbuckle a turn or two from the arm (bulkhead) side then unscrew the remainder needed from the ball end (hub) side (maybe 6-7 turns?). The only end that breaks is the arm side, I have NEVER seen the ball end side break. By turning the arm side out a turn or so, it gives you enough treads to make caster adjustments, but still be as strong as if you were running the offset ball link. If you break an arm now, you would have broken the arm in the offset setting too. By the way, I ALWAYS run the inline setting on my car: more traction and stearing and a general better feel to the car. Try it and you'll NEVER go back.
I'm BAAAAAACK...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-05-2003, 09:13 PM   #4132
STLNLST's Avatar
Trader Rating: 19 (100%+)
how does one go from 1st to 6th so fast....lol Good run today Racer X.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-05-2003, 09:24 PM   #4133
Matt Howard's Avatar
I've got that beat, I went from first to seventh in half a lap a couple weeks ago.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-05-2003, 10:06 PM   #4134
Send a message via AIM to Touringcardude
Cool this is a crazy question
Does anybody have a setup for the AXIS-2 for asphalt and gear ratio to use monster hp
Touringcardude is offline   Reply With Quote
Old 04-05-2003, 11:18 PM   #4135
fireblade's Avatar
mmmmmmmmmmm... Asphalt is back jack! Ripon went pretty swell, gonna head up to SWR in a few. All you guys runnin the SWR cup and NORRCA nats?
Axis 2 eh. The only person that I know that runs that car fast is Doug Lemmons. Heas usually not on the internet much, but ill tell him about your post.
Old 04-06-2003, 08:29 AM   #4136
Racer X's Avatar
simple, first you choke and brush a board so the car flips over the board and onto the straight with the whole pack coming. Went from 16.8 sec laps to 35.7 sec lap after having to run most of the track a second time. Hey, if it wasn't for me, they would have never caught me.
...and at least I raced, STL.
I'll be at the SWC, its my turn to win it. The NORRCA Nats are alittle close to the Reedy and I will be at the Reedy...
Schumacher Mi6
Integy
Old 04-06-2003, 08:31 AM   #4137
Racer X's Avatar
Touringcardude, Email me at JMaurer1@Concentric.net and I'll send you my old setup sheet for it. If it's for running on asphalt, I have the ticket...
Schumacher Mi6
Integy
Old 04-06-2003, 08:42 AM   #4138
STLNLST's Avatar
Racer X- We took the weekend off to give other car companies a chance to shine. I was just there to help the novice losi guys with some set up help. I even worked on a couple of cars yesterday I'm off to test this new set up Dujuan came up with.
Old 04-06-2003, 11:20 AM   #4139
racerx- you might have a chance since I'm not racing stock this year LOL
RCTech #361
Old 04-06-2003, 07:29 PM   #4140
STLNLST's Avatar
Ouch......
where's the love??????
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
