Old 01-29-2003, 07:18 AM   #3751
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
OK, I just got home from work and Paul's new foam tire carpet setup is up and online- New Carpet Foam Tire Mission setup
BagofSkill- We used the AE .032" (I think that's right) white spacers like comes in their shock rebuild kits to space the lower arm between the hingepin mounts. They fit perfect and don't interfere with anything. They also make the castor tuning more finite.
Teacher- for stock racing you may be right. I've been running all 19 turn and mod, so I haven't been too worried about scrubbing a little speed in exchange for side bite. I won't be running stock on foams any time soon, so I'll let you guys do the fine tuning on the stock motor setup....
Paul W- looking at the new foam setup sheet, it looks as if Andrew wasn't running the roll center mod. Is that correct?
BigDogRacing is offline   Reply With Quote
Old 01-29-2003, 07:46 AM   #3752
PW
PW's Avatar
Send a message via AIM to PW
Thank you once again BigDog and yes, we are now running the stock roll-centers on foam and rubber tires.
PW is offline   Reply With Quote
Old 01-29-2003, 12:11 PM   #3753
Ian S's Avatar
DW - can you turn PM on so i dont have to clutter up this thread with non schumacher stuff.
Ian S is offline   Reply With Quote
Old 01-29-2003, 12:29 PM   #3754
The setup should be more stable and way easier to drive. Keeping the shocks in a more vertical position mellow the car out a lot.
andrew
deoff is offline   Reply With Quote
Old 01-29-2003, 01:32 PM   #3755
PW
PW's Avatar
The new setup posted by BigDog is for medium to low-bite conditions. That setup should be easy to drive and very stable.
The front shocks should also be in the #3 position on tower. I made a mistake on the setup set.
On a high-bite track Andrew runs 25lb AE springs front and rear in the same position and also runs 45wt oil front and rear. He will also run 0deg in-board toe in the rear. One step at a time is suggested
Old 01-29-2003, 02:25 PM   #3756
PW
PW's Avatar
I'm going to have BigDog post Andrew's "high-bite" setup so there is no confusion. This setup will be hard to drive and is for well experienced foam racers
Old 01-29-2003, 02:37 PM   #3757
Trader Rating: 74 (100%+)
Default Snowbird's
See everyone at the Bird's. I cant wait to get away from this freeze.
Raul
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-29-2003, 03:34 PM   #3758
King-G's Avatar
Send a message via ICQ to King-G
BagOFSkill. glad you like the R/C mod, I have been running the same setup for around 6 months now...I made my own front spacer out of 2mm carbon. and the same rear blocks...
as Big dog suggests, try running some thin shims instead of o-ring and C-clip, allows very fine tuning of castor.
The mod increases mid to exit steering, whilst taming down the mega initial turn in the car exibited previosly, overall a nicer feel throughout the turn.
Putnam has also installed the new kit, It's nice that schumacher included the steering post base and rear spacers also!.
I have found that once you do the mod, there is no need to revert back to the standard peices to change back roll centre, as you just flip the alloy blocks and remove the front spacer..neato!.
King-G is offline   Reply With Quote
Old 01-29-2003, 06:32 PM   #3759
OK guys, here's Andrew's high bite carpet foam setup- High Bite carpet
This one will be hard to drive, but really fast....
Old 01-29-2003, 07:03 PM   #3760
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Well looks like the dynamics of these cars do have some carry over from brand to brand. I have done much testing with roll centers in terms of working with the xxxs. I have found that next to tires that is the biggest adjustment on the car. I am now looking to get my mission on that same level.
On Front roll I take it that everyone feels that the car is more stable and has less initial steering as the car raises its roll center. On the losi, espessially in stock on rubber tires as you lower the front roll you allow the car to initiate corners faster. This can also make the car unstable....is this the same reasoning behind using the roll mod on the mission?
I also know that as you raise the roll center front and rear you can really get the car to break the tracks bite on the car. A high roll center front and rear on the losi has been much faster on high bite tracks. Do Mission owners mess with that combo of both high fron and rear? If it does I am going to really like this car! Love all the tuning stuff I can do already...just wanted to keep messing with roll centers...
Thanks for any info.
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-29-2003, 10:38 PM   #3761
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
PW- King G and I have been playing with your setups(TakeOff carpet) and slight variations. Some stuff works well but im keen to know why other things are as u used.
We are running on a tight asphalt med-high grip track. First of all why are people using the 20 toth pulley on small tracks? Shouldnt the 17 be better?
I like the upper links for top arm. Gave the car a lot more agility and rolled more. Wasnt so surte on the grey springs though. Seemed to allow the car to roll to much and scrape. Will try blue or red springs.
Oils im running 45 and 2 hole piston. Its a bumpy track in places but generally very smooth. 2 hole seems to handle everything. Thinking of dropping to 35 or 40wt.
I use the same shock mount which is good but the inboard toe we have been running as 2 in front and 0 in rear. I notice you run the opposite. Was your car loose and you had to use that? Our cars arent loose at all but we need more corner speed i feel.
Sorry to ramble
Oasis2001 is offline   Reply With Quote
Old 01-29-2003, 11:45 PM   #3762
fireblade's Avatar
Send a message via AIM to fireblade
This may sound dumb, but Chris are you talking about the Take off (tires) setup? I am currently running one like that but the setup is weird. 5th hole for the shocks on the rear and 1st in the front. 27s in the rear hooked up but I ran 20's to give a lil more bite.
fireblade is offline   Reply With Quote
Old 01-29-2003, 11:51 PM   #3763
Oasis2001's Avatar
Yeah thats the one im talking about. I have always like laid down shocks and been very successful with that setup. As for tires I am a firm believer in running the same tyre all round. Tyres are the most important part of a setup and they must be balanced
Old 01-30-2003, 03:43 AM   #3764
fireblade's Avatar
Yeah. My carpet setup did ok with 27s all around. But then I went to Sorex 20s with HPI greens in the rear. The car seemed to have more rotation of the back end. I did want to try to move the front shocks out to the 2end hole to get a lil more front end bite. On asphalt iam gonna try it with 27s all around. Then I will post my setup on this board.
BTW- My setups start mostly stock (45wt oil) and I use all AE springs.
Old 01-30-2003, 08:09 AM   #3765
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Just wanted to let you know that if you are looking for another source of parts for the Mission KT Hobbies has them in stock. If you don't see something you are looking for let us know and we will add it.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
