Old 01-18-2003, 12:00 AM   #3676
Send a message via AIM to ZER01
Thank you James, that's exactly what I needed to hear, will niftech's extension shaft work so I dont have to buy new pinions?
ZER01 is offline   Reply With Quote
Old 01-18-2003, 12:20 AM   #3677
The extension shaft should work, I had never thought about it before you mentioned it. I will have to try it out and see how it works.
James Nguyen is offline   Reply With Quote
Old 01-18-2003, 04:21 AM   #3678
Cole Trickle's Avatar
I've been pretty hooked on that I got to have a Mission - but now I'm in doubt !
Case is, that I've been offered a well kept Tamiya TB Evo II. The shocks seems better (threaded), nice shaft transmission and the ability to use springs with much finer steps (the steps between Schuies are pretty big). In addition, the Evo 2 can use progressive springs, which the Mission cannot.
On the other hand, the Mission seems to be more adjustable, and caster / rear toe-in are much easier to adjust than on most other cars. And I think the Mission should be very fast with that nice transmission. Problem is, that I've never seen an Mission in action !
The Evo 2 will cost me 2/3 of a Mission with one-way diff, which are standard on the Evo 2. And money really matters for me....
I'm primarily driving on very small high bite tracks, so punch and acceleration means a lot.
I believe, that I can setup both cars to suit my driving style. So what do you guys thinks? Are the Mission really faster than TC3's and Tamiya shaft driven cars, when it comes to pure acceleration?
Both brands are well supported around here.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-18-2003, 05:44 AM   #3679
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Got to looking and my car is missing the belt tensioner....would running thecar without it result in major problems? Othere than that got the car all ready and going to get this thing racing. Very happy since the rebuild.
Going to have to get me some new spurs for it. What spurs you guys like on the mission?
Jeff
Team Promatch
ps. I did not get to go to the Novak race this year. Several of the guys I race with when I go to OKlahoma did. I am making plans to go next year. Am going to try and make the NORRCA Carpet nats in the end of march!
Jeff Werner is online now   Reply With Quote
Old 01-18-2003, 05:48 AM   #3680
Personnal opinion baby!!! The TB EVO2 is a sweet car, the Mission is a sweet car.... the Mission can use springs from Schumacher, Associated, HPI, Tamiya, Atlas, Ofna, You name it and they an use the springs, even Losi if you want!!! So don't let thet be a deciding feature!!! However I don't think more adjustability is always a good thing!!! The TB can use allthe same sprigs the Schuie can..... ReasonsI would stay ways from the Mission are......
I run on a track that isn't swept very often..............
I am allergic to rubber ad it makes my eyes swell up and my penis shrink....LOL
The Mission is a great car, but if the TB is more affordable for you I would get it, I know you are also looking for anew speedo so that will save some more cash to get one of those too...... Or get a second ball diff for the TB......
BTW the Mission is a monster of acceleration!!!! I have had people swear I was running an illegal motor when I ran mine!!!!! If I could only drive!!!!!!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-18-2003, 09:07 AM   #3681
Impact, I got trinity congo yellow springs on my mission, you're absolutely correct that the mission can accept almost any spring.
Jeff, I like the stock schu spurs as the spur gear adapter offsetted my kimbrough too far over where it would rub the upper deck. It only rubbed on a small spot of the spur and it was probally cause the kimbrough was a little wider than others. Also, with my car the gear adapter makes the spur more wobbly than the stock spurs, to me, the stock spurs are quicker to change, you'll eliminate the offsetting problem, it'll be lighter and the stock spurs fit nice and tight to where there's no wobble in your spur.
Old 01-18-2003, 11:10 AM   #3682
Thanks, IMPACTPLAYR !
Your point about springs are good.
Due to the fact that money matters for me, I've decided to go for the Mission. Simply because, the Evo II dont turn me on. And if I buy it, I will probably have to live it for a couple of years.... Unless I would be able to re-sell it for a nice price....
Your comment about Mission acceleration are interesting. I hope it's true !
Adjustment, adjustment and more adjustment.... for me the adjustment make a huge difference. I really enjoy playing with these things and they allow me to make my car drive the way I want it to !
One funny thing about adjustment: My Sport2 are much more adjustable than the TB Evo II ! even when talking box-stock kits...
Old 01-18-2003, 07:34 PM   #3683
Now that I have the car in working order...in search of two setups or one that would get me going for either track...
Looking for a setup for a Tight indoor rolled gritted surface. (Tennis court type surface) Fun track just wanted to get some ideas. Also any good outdoor Mod concrete setups? Track is about 130x40. Thanks...will be running the car in some good sized carpet race but there seems to be many setups available in that surface.
Jeff Werner
Old 01-18-2003, 08:24 PM   #3684
Have you checked the Schumacher site.... seemd those wacky brits run on some really weird surfaces!!!! BTW: I have 2 carpet set-ups Paul sent me, Shoot me an e-mail and i will forward them to you.....
My e-mail
Old 01-18-2003, 08:44 PM   #3685
Jeff, is that tennis court type surface RCR's track in Tulsa? If, so, I can give you the setup I ran there for the Winter TC Championship.
Old 01-18-2003, 10:36 PM   #3686
Proud that is the exact place I was talking about...lol
Any info would be appreciated!
Jeff
Old 01-18-2003, 11:32 PM   #3687
Jeff, here's the setup from RCR.
Front
shock position-tower:3
shock position-arm:2(furthest out)
upper arm position-bulkhead:1(top)
upper arm position-hub:1(closest to wheel)
tie-rod location-hub:2(furthest back)
oil:45wt.(schu)
spring:schu blue
piston:schu vari#3
length:66mm
droop:4 on hudy droop gauges
inboard toe:0
anti-roll bar:yes
castor:6
outboard toe:0
ride height:6mm
camber:-1
arm spacing:rear
diff(very tight)
Rear
upper arm position bulkhead:1
oil:45wt. schu
spring:schu blue
piston:schu vari#3
length:66mm
droop:3
inboard toe:2(this could have been 0 as there was good bite)
anti-roll bar:yes
anti-squat:0
outboard toe:2
ride height:6mm
camber:-1
arm spacing:middle
take off 22's(pre-glued w/blue insert)
tire additive:none
stock schu carbon chassis/upper deck
servo:futaba 9450/expo:-10
body: protoform vauxhall
no additional weight added to the car
Old 01-19-2003, 04:21 AM   #3688
BagofSkill's Avatar
Default What am I???
Hi Guys,
I know it's a bit off topic but can anyone identify this for me? It was given to me yesterday, and other than it being some kind of Cat, I've got no idea. It's got a single belt (fine teeth) frp chassis, front one way and rear telescopic driveshafts, and bend back style front suspension. What I'd love most of all is a part number for the body shell. I'd appreciate any help from the Schu officianado's!
BagofSkill is offline   Reply With Quote
Old 01-19-2003, 04:37 AM   #3689
dw
It's a procat.
Single belt?
I thought they had three belts although the rear 2 are in parrallel so it is effectively a 2 belt design.
dw is offline   Reply With Quote
Old 01-19-2003, 07:42 AM   #3690
Ian S's Avatar
IMPACTPLAYR, what are these "wacky" surfaces you talk off?
Ian S is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
