Old 01-13-2003, 01:27 PM   #3631
racerb's Avatar
layshaft ????
Hey there I have tried to post b4 on this thread but never got any answers..I have an Axis 2 and I was wondering if anyone could help me by explaining what a "pinned layshaft" is, (eventhough I have a pretty good idea what it is) I just don't know how to make it pinned or not ..and also what is the pros and cons to doing this...right now I am running on a tight carpet track with medium to high bite with foam tires....any help would be great thanx
racerb is offline   Reply With Quote
Old 01-13-2003, 02:17 PM   #3632
Ian S's Avatar
When measuring shocks for setup sheets should I be measuring them fully extended so that the spring does not touch either end of the shock or when they are on the car at normal ride height?
Ian S is offline   Reply With Quote
Old 01-13-2003, 02:35 PM   #3633
Hey Paul,
Could you post the setups used by yourself and Timmy this past weekend? I noticed that Timmy cut out some of his battery slots...why? Also, this past weekend I replaced my my one way outdrives and the first run on them the right one locked itself up and blew the one way bearing out...have you seen that happen before? I couldn't figure out why it did that...I could see it happening if I hit something but the car suddenly pulled to one direction and stopped.
Thanks.
James Nguyen is offline   Reply With Quote
Old 01-13-2003, 03:02 PM   #3634
Send a message via ICQ to MattW
ian, yes fully extended
MattW is offline   Reply With Quote
Old 01-13-2003, 04:30 PM   #3635
Default On Normal wear and tear
I recently picked up a used kit with mostly normal wear and tear on it.
2 bent hinge pins, a hub that wouldn't hold the bottom ball threads. some worn out bearings, all four upper arm turnbuckles were bent ... stuff you'd expect to see in a used kit.
But I was surprised to see that the layshaft was bent when I tore the car down. If the mesh was set right, then the spur was rotated, the mesh would go from just right to too tight to just right to too loose, etc...
Is this a common thing to go? I mean it seems like that would have to be one heck of a crash to bend the layshaft. Maybe he tried to build it up with the mounts in the 17T position but the 20T pulley on the shaft?
Is this an issue that others have seen?
Concillian is offline   Reply With Quote
Old 01-13-2003, 04:32 PM   #3636
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Man.. thats sounds like alot of "Wear and Tear" for a Schumacher kit I have not had any problems with the layshaft bending. Now you have a reason to the get the Ti one.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-13-2003, 06:09 PM   #3637
Send a message via AIM to ZER01
Anyone know what parts are needed to run the aluminum hubs? High/low ball pins? Is the camber link position the same as the in-line position on the composites?
ZER01 is offline   Reply With Quote
Old 01-13-2003, 09:46 PM   #3638
ottoman's Avatar
R/C Tech Charter Subscriber
I just want to thank Paul W for all his help this weekend at the Touring Car Nationals... with his help we put our Mission into the "Expert Stock" A main along with Timmy Heiser. Thanks again!
ottoman is offline   Reply With Quote
Old 01-14-2003, 03:46 AM   #3639
The Alhubs are sweet, they come with the high ball/ low ball studs, but i would get an extra set. The high ball studs bend easily. The lowball studs are stronger due to their compact design.....
Yes the All hubs are the same as the outer point on the stock hubs......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-14-2003, 07:37 AM   #3640
Thanks Impact.
Old 01-14-2003, 12:28 PM   #3641
PW
PW's Avatar
Send a message via AIM to PW
Default Re: layshaft ????
On the Axis series there was a oneway pulley (u1910) that could be locked with a pin, but the correct layshaft (u1913) is needed to do so. We would recommend a pinned layshaft for foam tire racing.
Hey guys, thanks for all the kind words I will get my setup post ASAP.
PW is offline   Reply With Quote
Old 01-14-2003, 01:43 PM   #3642
Send a message via AIM to Touringcardude
Cool Axis carpet set up
does anybody have a set up for the axis on foams on carpet
Touringcardude is offline   Reply With Quote
Old 01-14-2003, 05:02 PM   #3643
King-G's Avatar
Send a message via ICQ to King-G
Hi Lads...Im back from holidays,
hows was everyones christmas new years?...
got to have a few runs indoors, and starting to finetune a setup for indoors on control tires..Takeoff 27's..(asphalt indoors, very tight technical)
good to see the board has been active over the past 3 weeks...
look forward to seeing your setup P.W
King-G is offline   Reply With Quote
Old 01-14-2003, 06:51 PM   #3644
racerb's Avatar
Talking Ok thanx Paul
I was starting to get worried cause I have never got a reply on this thread b4 eventhough I have posted a few ??'s...I think tha is the layshaft I have.... the Problem is I bought the car used so I not sure what has been done to it and what hasn't..I just won my very first race (i have been racing for 6 months) and it was great plus my car is one of the fastest in my class so I just have to get the driving thing dwn
Old 01-14-2003, 07:47 PM   #3645
STLNLST's Avatar
Trader Rating: 19 (100%+)
PW- on the Keyence speedo what is a good drive freq to use for stock rubber on carpet and asphalt. Thanks for the mod info a while back.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
