Old 01-01-2003, 08:11 AM   #3571
It looks like the team PRP plates raise everything, including the servo saver, so you have to file off the top of the servo saver to mount the top plate. With the Team PRP you dont have to cut off the fronts of the steering mounts, where the rear lower hinge pins insert. In other words it should work with all of the existing parts...
FYI...Schumacher is going to release a kit for performing this mod pretty soon. You might want to check with them. I think there's will have the aluminum lower hing pin mounts front and rear.
markg is offline   Reply With Quote
Old 01-01-2003, 09:31 AM   #3572
Send a message via ICQ to MattW
Schumacher are releasing a roll center mod, pt no U2575H. Not sure about availability, i have ordered one but it hasnn't come yet. It is shown on the December Newsletter that can be found on Schumacher's web site in the On-line catalogue section.
It uses the std front brace and has a carbon plate to raise it. Then there is a new pin block and modified steering mounting block. You also get some plates to put under the rear plocks to raise the rear as well.
MattW is offline   Reply With Quote
Old 01-01-2003, 11:11 AM   #3573
Thanks for the set-up sheets PW, the Mcmahon sheet says he modified the plastic rear hubs to "simulate" the lowball position on the aluminum pieces, but makes no mention of teh same being done to the front. I a running the Al hubs front and rear, does this mean I should run the high ball position on the front with lowball on the rear??
Thanks agian!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-01-2003, 02:24 PM   #3574
PW
PW's Avatar
Send a message via AIM to PW
Impact...Yes. that is how he was running his car (cut rear & std front). The cut hub seems to lock in the rear of the car.
PW is offline   Reply With Quote
Old 01-02-2003, 11:48 AM   #3575
Schuieracer's Avatar
Send a message via AIM to Schuieracer Send a message via Yahoo to Schuieracer
Hey Paul, you'll be at the US TC Champs in Milwaukee next week right? Do you know if you'll have any of the roll mod parts with you then? Would be nice to have for the Nats in March.
Schuieracer is offline   Reply With Quote
Old 01-02-2003, 07:19 PM   #3576
PW
PW's Avatar
schuieracer....Yes, I will be there next week along with the rest of the team from FL. We don't yet have the roll-center kit, but we do have the alloy blocks that the team guys are currently using....They should be in stock within a week or two.
Old 01-02-2003, 11:30 PM   #3577
Ok thanks Paul. Are you going to be doing any racing there? Traction is up already, they aren't changing the layout that's been down for 2 race days already, and it will be used for the race as well. So don't expect a green track when you get there, it'll have pleny groove. FYI schumacher guys. Wanna win for the 4th year in a row?
Old 01-02-2003, 11:33 PM   #3578
Well, winning stock that is. A mod victory would be awesome.
Old 01-03-2003, 10:10 AM   #3579
Where can I get the carpet upper deck. I've looked all over and nobody seems to have it.
kmorast is offline   Reply With Quote
Old 01-03-2003, 12:02 PM   #3580
Cole Trickle's Avatar
As far as I can see on the exploded Mision diagram, then the use of the gear adapter (U2252) will add extra weight to the transmission, compared to use of Schumacher spurs. Correct?
Thanks.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-03-2003, 02:13 PM   #3581
Yes if you weigh it out, it will be heavier, but the advantages of using aftermarket gears like Kimbrough and RW in 64 pitch outweighs that.
Old 01-03-2003, 03:43 PM   #3582
Default EVO and EVO2?
Hi all... this might be a bit off the current topic, but here goes.
I used to race about 12 years ago (2wd-offroad). I mainly raced AE RC10's. About the time I got out, Losi was comming around. I am now trying to get back into it and am wondering what you all can tell me about the Fireblade EVO and EVO2. I have heard both names mentioned, but have only seen the EVO on the Schuie web site. Can someone give me some info on this car? I am really trying to avoid contributing to the AE and Losi domination that is going on right now (At least from what I have seen).
Any info would be great!
Thanx!
NHLFAN is offline   Reply With Quote
Old 01-03-2003, 05:13 PM   #3583
I can only imagine they are also great cars, but most people in the states prefer the old guard (Losi,Associated) so they are very overlooked. I could only imaggine them to be fast in the right hands with enough patience and set-up time....
Old 01-04-2003, 01:22 AM   #3584
Thanks. The reason for I might use the adapter, are to re-use my collection of 48 pitch spurs and pinons.
Old 01-04-2003, 04:51 AM   #3585
fireblade's Avatar
Send a message via AIM to fireblade
I put the RW's in my car, man what a difference. The car is so much smoother. It takes off faster and is not as noisy.
fireblade is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
