Old 12-23-2002, 05:29 PM   #3526
PW
PW's Avatar
Send a message via AIM to PW
Schumacher Inc would like to wish everyone Happy Holidays
PW is offline   Reply With Quote
Old 12-23-2002, 05:38 PM   #3527
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Merry Christmas and Happy holidays to all the racers. This is always a great soarce of information and good help. Thanks for the past year of info and good reading...hope 2003 is a great on for all of us!
Jeff Werner
Jeff Werner is offline   Reply With Quote
Old 12-23-2002, 05:50 PM   #3528
King-G's Avatar
Send a message via ICQ to King-G
hope everyone has a safe holidays...plenty of time to play with our new toys..
cya all back here in Jan...let the good times roll..
Cheers Gavin
King-G is offline   Reply With Quote
Old 12-24-2002, 05:13 AM   #3529
Send a message via ICQ to MattW
Holidays - plenty of time to build new car that has just arrived!!
Have a good christmas all.
MattW is offline   Reply With Quote
Old 12-24-2002, 07:49 AM   #3530
Racer X's Avatar
Merry Christmas to everyone here...I'm still around, just keeping quiet.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 12-24-2002, 12:12 PM   #3531
Merry Christmas guys!
P.S. Racer X - When are you racing carpet next. I hope to be racing again in a week.
James Nguyen is offline   Reply With Quote
Old 12-25-2002, 11:44 AM   #3532
Cole Trickle's Avatar
Happy Christmas everyone.
Will a 96 tooth 48 pitch spur gear fit on the Mission?
The 20 tooth Mission pulley corresponds to 1,8:1 ratio, right?
Currently I'm running a HPI Sport2, which got a relative heavy drivetrain - gear diffs, hardnend steel outdrives and "small" pulleys.
Is it a good idea to start out with the same final ratio on the Mission? (track + class are the same, tight technically carpet and stock). What is most common in this situation, to go up 1-2 tooth on the pinon or????
Thanks.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-25-2002, 11:52 AM   #3533
Cole, Not sure about a 96, i would think so. I have had a schumacher 95 gear on it, and it was very close to nearly everything, so not 100% sure about a 96. Different companies gears do vary slightly in size even for the same number of teeth.
Yes i would start with the same overall ratio, you may find that you are able to gear up a bit, but at least if you start on the same you should know that you are on the safe side.
Yes the 20 tooth pully is 1.8:1
Old 12-25-2002, 01:28 PM   #3534
Thanks.
Yep, your are right about being safe. However, due to the 1,8:1 ratio, I need new spurs/pinons anyway. I can just as well get the proper ones for the same overall ratio + an extra pinon or two to gear up a little, if nessecary/possible.
Old 12-28-2002, 10:52 PM   #3535
racerb's Avatar
Talking well tomorow is big day
It is my first race with my Axis 2 thank god for Xmas cause I finally got all the stuff I needed to race it I know axis 2 is kinda out now and the mission is the big thing but this is my first touring car (my last being an RC10DS 2wd) so this is a big step but I think it will be a good one
ciao for now
Blain
racerb is offline   Reply With Quote
Old 12-29-2002, 05:05 PM   #3536
Default Mission and batteries
Well, I finally received my Mission, now the big question. I have a set of 2400's that do not seat just right. Any thoughts/ideas? Also, I am getting some 3300's in, should expect that these do not seat in just right either?
rc-bdub is offline   Reply With Quote
Old 12-29-2002, 05:51 PM   #3537
fireblade's Avatar
Send a message via AIM to fireblade
Well, I just got a pack of 3300's too and they fit fine but you cant have your pinion all the way out equal to the spur gear. you just back it in a little twards the motor, other than that they fit perfectly fine
fireblade is offline   Reply With Quote
Old 12-29-2002, 06:27 PM   #3538
You need to sand your batt slots to get the batts to sit in the slots perfectly.
Old 12-30-2002, 06:31 AM   #3539
Hey Guys...ran into a problem this weekend...wondering if anyone else has seen it. Running the front steel drive axles, and one way diff...the right side axle barely engages the diff outdrive. Mine came out after a hit, and it ate the outdrive...has anyone else had this problem? The only change I made that I can think of that might have contributed to this was moving the lower hinge pin to the inboard 2 degree position...
THanks for any input...
Mark
markg is offline   Reply With Quote
Old 12-30-2002, 06:48 AM   #3540
James Nguyen You need to sand your batt slots to get the batts to sit in the slots perfectly.
Thanks James, I will try that, I had thought of that but I did not want to do it, if it wasn't needed.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
