Old 12-11-2002, 05:59 PM   #3481
King-G's Avatar
Send a message via ICQ to King-G
there is no new car that I am aware of, perhaps running changes such as the new diffs...the mission is a brilliant design. Nothing stands out as being flawed
King-G is offline   Reply With Quote
Old 12-11-2002, 08:35 PM   #3482
Trader Rating: 74 (100%+)
Default Mission
I agree that the Mission is probabl;y the best car out there. Here, I race against, TC3's,XXX-S, Corally(X-Ray), Tamiya, Kuwada, and just about anything else that I forgot. No MATTER what track I go to, its always the same. Is that one of those Schumacher's????? How it run. ???
By the end of the race day they know. It runs circles around everything else. The only problem I have being in CT, is that there are no other Schuei's and setups are pretty much trial and error. You cant just go ask the fast guy @ the track.. But when you find the SWEET spot, watch out.
Not only are they the baddest car kit out there, but with all the cool stuff that Schumacher USA has, it is also the most wicked piece of eye candy at the track..
The Mission is definetly the way to go.
PS. Paul and Adrian are AWESOME.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, JSpec custom stickers and apparel.
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 12-11-2002, 10:00 PM   #3483
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Your wish is my command...
Alex's Cleveland setup sheet
Also, I fixed a few things on the editable setup sheet. Please download and save the new one over the old one. (that includes you PW)- Newest Mission setup sheet
BigDogRacing is offline   Reply With Quote
Old 12-11-2002, 11:01 PM   #3484
ottoman's Avatar
What does the "Losi steering blocks" mod involve and what is the benifit? (from Alex's Cleveland setup)
ottoman is offline   Reply With Quote
Old 12-12-2002, 05:46 AM   #3485
Cole Trickle's Avatar
Originally posted by markg
Cole...dont know why the kwik clips couldnt be used for wheelbase adjustment...except they may be too thick, but I'm pretty sure the dia of the upper and lower hinge pins is the same...
The kit comes with an 86 tooth spur...I notice on a lot of the setups the guys are running 92 tooth... the gearing is pretty tall with the 86 tooth spur and the 20 tooth internal gear which most prefer to run..if I remember you're running on a tight indoor track, and with the 86 spur and 20 tooth main gear you'd probably be looking at something like a 22 tooth pinion for a P2K2 stocker, or a final ratio around 7.1
Hope that helps....
Thanks again, MarkG.
I'm planning on starting out with the same overall gearing, that I'm using now. It'll probably be a starting point, since my Sport2 got a heavy transmission, compared to the Mission. By the way, I'm using P2K and spitfire for the moment.
And unfortunately, my current finansial situation, dont allow me to buy the Mission right now. Good part are, that dreams are sweet and it seems that my finansial situation are being better for a reasonably time.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-12-2002, 08:44 AM   #3486
Here's a potentially stupid question...
I've been using a Novak TC Speed control forever, and it still seems to be working fine...at least I don't know any difference. I'm wondering if upgrading to one of the new speedos, like the Keyence would make a noticeable difference? There are some cool new ones out there to choose from, just not sure if its worth the cash to switch. Anyone have any comparison info to share?
Thanks...
markg is offline   Reply With Quote
Old 12-12-2002, 11:54 AM   #3487
Send a message via AIM to ZER01
Fireblade, James Nguyen, or anyone else, anyone got a safe overall gear ratio for a 13X2 P-94? I haven't run the car in mod yet and have a pretty big 2 day race coming up this weekend.
ZER01 is offline   Reply With Quote
Old 12-12-2002, 12:37 PM   #3488
For a 13double i would usually start with a 7.7 overall gear ratio. I haven't ran any p-94s but would imagine that they run somewhat like the Ti series.
James Nguyen is offline   Reply With Quote
Old 12-12-2002, 12:59 PM   #3489
Thanks James, that's better than nothing.
Old 12-12-2002, 01:08 PM   #3490
fireblade's Avatar
Send a message via AIM to fireblade
Try with a 16 mabe. or a 14. Those p9-4s have a lot of torq mabe a 17 or 18 if the motor takes it. What pully you running too?
fireblade is offline   Reply With Quote
Old 12-12-2002, 01:44 PM   #3491
Jesse, it depends on how big the track is and whether you will be running foam or rubber tires. If you're running foam, then you have to use a rollout chart.
Why didn't you just call me and ask?
BTW, Alex's foam carpet setup is up a few posts...
Old 12-12-2002, 02:39 PM   #3492
Fireblade, thanks for the info, I'm running the 20 tooth pulley.
BigDogRacing, The track is 75X50, rubber tires.
Old 12-14-2002, 05:13 PM   #3493
PW
PW's Avatar
Send a message via AIM to PW
Wow, never seen this thread make it to the second page Everyone must be out racing
TOP
PW is offline   Reply With Quote
Old 12-14-2002, 07:59 PM   #3494
Jeff Werner's Avatar
Send a message via Yahoo to Jeff Werner
I know PW...us not lucky enough to go racing on sat night get an extra kick in the stomach because there is no action on these type of threads as well as no racing for us...going to a Event in OK though on sunday...will get to meet proudwinner there!
PW I did send you a PM...did not know if you got it?
Thanks,
Jeff Werner
Jeff Werner is online now   Reply With Quote
Old 12-15-2002, 01:57 PM   #3495
Well for the second time my brother had problems with his TB01 and had to use my Mission....... and he wipped up!!!! he won the main at the local track by 6 laps..... granted there where only 7 racers, but c'mon he's only 13!!!! can't wait for the outdoor season so we can hit the big outdoor track and watch him do his thing!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
