Old 10-21-2002, 12:24 PM   #3196
Corey, I would also like a setup for carpet.
[email protected]
Mr. G is offline   Reply With Quote
Old 10-21-2002, 01:33 PM   #3197
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Since more then one person wants this setup, I will post it right here!
Front-
Oil:60weight Trinity
Shock Position: innermost on tower outer on arm
Wishbone Position: Upper
Caster:2clips on front one rear
Camber:-1.5
Toe:0
Droop: 4(on AE gauge)
Tire: TRC Plaid Fronts
Spring: Associated white
Ride Height: 4mm
Arm Spacing" Centered
Rear-
Oil: 60 Trinity
Camber: -1.5
Toe Inboard: 0
Toe Outboard: 2 degrees
Droop: 3 (on AE gauge)
Tire: TRC Purple
Spring: Associated White
Ride Height: 4mm.
Arm Spacing: Centered
Notes: Using Warpspeed chassis and carpet top-deck
Body: Trinity Carpet Stratus
Motor: 8x2 D5
Geared: 95/18
Battery: Trinity 3300
Tire size: 2.30 front/rear
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 10-21-2002, 03:45 PM   #3198
Company Representative
Thanks Corey, just a couple of ??. What position is the ball stud in on the knuckles f/r ? What piston are you running in the shocks? What are the size of the clips you are using on the upper arm? And where are you measuring your droop at? Thanks again.
Gary F.
Gary Fliegel is offline   Reply With Quote
Old 10-21-2002, 04:21 PM   #3199
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hey guys here is another setup that you guys might want to try along with Corey's...I ran this weekend and it was very good and easy to drive.
Front
80wt losi oil
#3 associated pistons
4 hole on the tower
Trinity congo Purple springs.....30lbs
outer hole on the lower arm
inline ball stud
upper hole on upper suspension mount
Roll center raised 1mm
arms apaced to front
6deg of castor
1 deg of camber
no toe in or out
ride height 3.5mm
droop 1.5mm over ride height
plaid TM foam tires at 2.27
Rear
60wt losi
#2 associated pistons
3 hole on the tower
Trinity congo Blue springs.....25lbs
inline ball stud
upper hole on the mount
arms spaced to the rear
1 deg of camber
2.5 deg of toe in per side
ride height 3.5mm
droop 2mm over ride height
purple Tm foam tires at 2.27
TQ orange use for compound
gearing 23/95
with 10x2 Ti motor
20t pulley
WarpSpeed 3mm chassis used with stock top deck
The track was 90 by 40 and had med to high traction
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 10-21-2002, 06:45 PM   #3200
WHoops sorry Gary,and others. Totally overlooked that. lol
Ball Stud Position: Inner
Pistons: 2 hole f/r
Droop: Measuring it by aligning the gauge flat on the chass to the bottom of the arms.
Castor Clips: Not sure how many MM they are. Can some help Gary out with that question, KevinK maybe?
Old 10-21-2002, 07:12 PM   #3201
Kevin K's Avatar
Corey I dont know what size you are using and where they are so I cant really say what your castor is.
Old 10-21-2002, 09:25 PM   #3202
fireblade's Avatar
Send a message via AIM to fireblade
Cory, Are you using the Kwik Klips for the castor?
fireblade is offline   Reply With Quote
Old 10-21-2002, 10:24 PM   #3203
you must be kidding, what are these supposed design flaws? The mission is without doubt the best kit I've ever owned with a Corally a close second. Associated doesn't even come close.
Godzilla is offline   Reply With Quote
Old 10-21-2002, 11:14 PM   #3204
King-G's Avatar
Send a message via ICQ to King-G
rangulo, are you trying to start some shit?..
there is no new mission for release, and the crap you are stating about using Losi Hubs is laughable..I doubt that they can possibly fit.
schumachers cvd's in my opinion are as good as any other I have used, Including Associated (m,i,p) Corally's, Tamiyas etc. I have yet to break one, and the wear rate on teh joints is fantastic.
King-G is offline   Reply With Quote
Old 10-22-2002, 12:38 AM   #3205
Kevin K's Avatar
Ohhhhh boy...........
Old 10-22-2002, 07:48 AM   #3206
I don't doubt that he has seen this... and remember the top drivers he speaks of are the ones from his track, NOT Schuie sponcered drivers. Racers will transform any part they can to make any car handle better, in their own minds.... I mean after the X-ray came out with a c-hub suspension for the T1 that uses the same geometry as the TC3/XXX-S alot of racers felt left out.... I mean we all didn't have a $200 option for our car that we need to compete...LOL!!!!
There is only one design flaw that the Mission has.... Schumacher made it too perfect the first time!!!!!
But I don't see Schumacher designing a new suspension for the car, after all the one on the Mission has worked flawlessly for soo many years and soo many chassis layouts.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 10-22-2002, 07:57 AM   #3207
fireblade's Avatar
Well, if there was a new kit, they would announce it. The losi hubs I heard fit WITH modification. Plus, its only been a lil over a year since the last one, they are probably gonna wait longer because the mission is dominating so well
Old 10-22-2002, 08:36 AM   #3208
yes I am using the quick clips..
People there is no new car, so just stop the propaganda! hah...
Why change something that works so well. Cheees
Old 10-22-2002, 08:55 AM   #3209
Kevin K's Avatar
Guys you can put just about any part on any other car with enough time and know how. Putting Losi hubs on the car will work but you would have to use cvd's from another car. And as far as them comming out with a new car Im sure that they are working on something for later. Schumacher is not a company that just sits back on a current design unlike some other companies.....they are always looking to make it better in anyway they can. So Im sure that there is a new car they are working on but how soon will we see it who knows a year maybe more.
Old 10-22-2002, 09:26 AM   #3210
AdrianM's Avatar
Hmm..Raf took his post off.
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
